Ultimate OEM Toyota Parts Thread for 2nd gens (2007-21)
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2017.
  1. Jan 9, 2021 at 12:36 PM
    #3331
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Anyone know the part number for the hose cushioning material around the ATF lines?
  2. Jan 9, 2021 at 2:31 PM
    #3332
    Team4M
    Team4M New Member
    Anthony
    2016 - Tundra - 1794 - Black
    Bilstein 6112 / 5160 lift
    had the end caps and center section wrapped and I like how it turned out.
    Good luck with yours.
  3. Jan 9, 2021 at 2:33 PM
    #3333
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    This truck looks
    gooooooooooooood!!! :thumbsup:
    MillMatter and Team4M[QUOTED] like this.
  4. Jan 9, 2021 at 7:51 PM
    #3334
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Hi,
    I believe it to be the following connector harness. However, the wire leads will have to be sourced separately.
    90980-12217
    Hope this helps
    RainMan_PNW likes this.
  5. Jan 9, 2021 at 8:01 PM
    #3335
    Do58
    Do58 New Member
    So that part number is for the connector but no pins or wires? Is this correct is assuming from your post? Thank you!
  6. Jan 9, 2021 at 8:15 PM
    #3336
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Yes, that is correct or at least in my experience ordering connectors it has been.
    The wire leads (terminals) can be ordered as “pig tails” but have been very illusive for me to get the right ones from Toyota. I have done it one time before but you have to know the exact part number for your parts guy to order it. My guy at the stealership says that only his techs can look into those specific wiring schematics to order the leads...:notsure: as he is “not” authorized to do so...
    So what I do now is match any leads I need from my RAV4 parts car and pilfer the wiring from there, salvage yard, or from digi-key.
    https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/1123343-1/3488572
  7. Jan 9, 2021 at 8:19 PM
    #3337
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Hmm...:monocle:
    Just found this too...
    https://www.ebay.com/p/26014175998
  8. Jan 9, 2021 at 10:31 PM
    #3338
    RainMan_PNW
    RainMan_PNW SSEM #82 RGBA #4 “That Guy” Vendor
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    From Toyota direct, you are right - the part number is only the connector. The actual terminals are retarded how much they want for them...but I do have copies of the data for every connector in the Gen 3 now (based on connector name from the EWDs), and those data sheets give the terminal/pin sizing and Toyota part numbers for the leads themselves if a guy was going to go that route. Personally, I bought a crimper and buy the terminals from Digikey once I find the right size/configuration.
    Do58 and ElNopal[QUOTED] like this.
  9. Jan 10, 2021 at 3:03 AM
    #3339
    Toptalktoyota
    Toptalktoyota New Member
    2020 DC SX
    Sorry bro. I have the bottom gray cloth seat cover for you. PM me if you still need it.
    Tundra-dude[QUOTED] likes this.
  10. Jan 10, 2021 at 6:44 AM
    #3340
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Nice to know about that so I will be inquiring with you on such from here on out. Thanks.
    RainMan_PNW[QUOTED] likes this.
  11. Jan 10, 2021 at 9:43 AM
    #3341
    Glennjermin
    Glennjermin New Member
    Glenn
    2014 Toyota Tundra SR5 Crewmax 4x4
    Icon Add A Leaf springs Bilstien 5100 shocks Freedom Off Road UCAs Snugtop rebel camper shell Prinsu Roof Rack Decked System
    @Roman
    I’ve got some worn out tie rods ends, upper and lower ball joints... The quality of my ride and steering is appalling. any suggestions on parts? Please & thank you.
  12. Jan 20, 2021 at 3:13 PM
    #3342
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    Anyone know if power folding mirrors from a 2017 are plug and play on a 2008 Limited? Will the wire harnesses work as is?
  13. Jan 20, 2021 at 9:23 PM
    #3343
    Aktavate
    Aktavate New Member
    Am I crazy or did the price of the pro grill and bulge go up $200?
  14. Jan 21, 2021 at 10:56 AM
    #3344
    French Avocado
    Utah / Wyo
    Are those two choices mutually exclusive?
  15. Jan 24, 2021 at 12:51 PM
    #3345
    EZDoes It
    EZDoes It New Member
    Ed
    LSD (Lower Slower Delaware)
    2020 MGM CM SR5 TRD exhaust, TRD wheels
    Tint, tow mirrors, remote start, Razormotor taillights, Genuine trans cooler, tailgate light strip, Extang tonneau, TRD rear sway bar, trans cooler…(thanks TRD)
    No you’re not crazy, but I’m bummed. I’ve been waiting for the store to open back up, now that ship sailed. I guess I’ll try to get it wrapped. I’m having a hell of a time finding someone to do it. They all say, nope it will chip. I don’t care, I’ll deal with that later. I had it in my cart waiting too.
  16. Jan 24, 2021 at 12:58 PM
    #3346
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Diy wrap. It's not hard.
  17. Jan 24, 2021 at 1:33 PM
    #3347
    Steve66
    Steve66 New Member
    2017 Tundra SR5
    Did you try sparksparts.com?
  18. Jan 25, 2021 at 6:24 PM
    #3348
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    Anyone know if stock oem front bumper from 2016 will fit a 2020? Both no sensors
  19. Jan 26, 2021 at 2:23 AM
    #3349
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    I would think they'd fit fine, but I would weight for @Roman to confirm nothing internal changed.
  20. Jan 26, 2021 at 5:34 PM
    #3350
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    Checking if Romans’ Parts shop is ready for new orders?
    XPTUNDRA likes this.
  21. Jan 30, 2021 at 11:25 AM
    #3351
    TxLock21
    TxLock21 Bought a truck, got bit by the bug.
    @Roman do you know the part number for the matte (or satin) black exhaust tip for a 2018 Tundra 4.6?
  22. Jan 30, 2021 at 4:44 PM
    #3352
    Do58
    Do58 New Member
    Honestly, you’re better off creating a thread for help than this one. Maybe dm him but he hasn’t been on in 2 weeks. This thread is pretty much dead until if/when he comes back. There are plenty of people on here that can probably help along with a little googling. Just my opinion considering the store he works for online orders are STILL shut down. As for pricing, once you get the correct p/n, there are plenty of online Toyota dealers that offer just as good if not better prices with discount codes and discounted shipping and even free. Hate to be the bad guy here, just offering advise. I’ve been told numerous times that the shop is opening up in a week. That was almost 2 months ago. Just sayin
    FirstGenVol likes this.
  23. Jan 31, 2021 at 9:49 AM
    #3353
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    The website doesn't say they are closed anymore, at least not on mobile.
  24. Jan 31, 2021 at 9:55 AM
    #3354
    MatD13
    MatD13 New Member
    2018 Limited Cement Crewmax 4x4
    On my iPhone it looks like that too, but if I pull down to refresh the page, it shows it’s still closed.
    FirstGenVol[QUOTED] likes this.
  25. Feb 4, 2021 at 6:50 AM
    #3355
    GoldenGoon89
    GoldenGoon89 New Member
    Houston,TX
    2018 CM -1794 BLUEEE- 4x4
    Getting ready to do this same thing..
    Want to makes sure fitment is correct.
    Purchasing a 2019 honeycomb, insert only. To put on my 2017 Limited.
    Any fitment problems??
    Thanks.
  26. Feb 4, 2021 at 7:09 AM
    #3356
    Wyoming
    The insert isn't sold separately.
  27. Feb 4, 2021 at 7:23 AM
    #3357
    YotaTruckLtd
    YotaTruckLtd Secret Squirrel
    2014 MGM Limited CM
    Bilstein 6112/5160 Boss 4x4 shims Boss 4x4 shackles Fuel Off-Road Vector wheels 20X9 Nitto Terra Grappler G2 35" tires SPC UCAs OEM TRD Pro Grille OEM 2020 LED headlights and OEM LED fog lights OEM color matched mirror caps and door handles OEM black exhaust tip Ecoological color matched metallic grey front and rear bumpershellz Go Rhino RB20 running boards XPEL Prime XR Plus ceramic tint 30% front 15% rear 70% windshield BAKFlip MX4 tonneau cover Dasaita 13in Vivid Headunit AJT interior chrome delete black kit AJT climate control black knobs AJT V3 shift knob TVD exterior emblem black inlays 3BMakers Yota hitch cover Husky front and back floormats K&N Select engine air filter GTR Lighting Armor Series LEDs Reverse lights Cargo lights 3rd brake light License plate lights
  28. Feb 4, 2021 at 7:57 AM
    #3358
    GoldenGoon89
    Houston,TX
    Oh yes. I know.
    I’m purchasing from an individual.
  29. Feb 4, 2021 at 8:29 AM
    #3359
    Team4M
    Team4M New Member
    Anthony
    Unfortunately I can’t speak to the fitment of just the insert… I Replaced the whole assembly and got it from a dealership as well. Good luck
    GoldenGoon89[QUOTED] likes this.
  30. Feb 4, 2021 at 8:50 AM
    #3360
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Nope. Zero fitment issues.
