UCA question!!
Discussion in 'Suspension' started by BlueRibbon4x4, Dec 1, 2021.
  1. Dec 1, 2021 at 5:21 PM
    BlueRibbon4x4
    BlueRibbon4x4 [OP] Let’s color match it
    Geno
    2015 Blue Ribbon 4x4
    Yo folks! I’ve always wondered if you “feel” a difference with upgraded UCAs. I know that alignment is more accurate with a lift. But I’ve heard you don’t need them under 3”. I have a 2-1/2” lift. Bilstein 5100s all around, but I intend to upgrade those later.
    So do they enhance the performance of your suspension at all?
  2. Dec 1, 2021 at 5:51 PM
    Other than allowing for a better alignment, I don't notice a different handling feeling.
  3. Dec 1, 2021 at 5:57 PM
    BlueRibbon4x4
    Geno
    Gotcha. Do you do a lot of off-roading?
  4. Dec 1, 2021 at 6:01 PM
    Not in FL lol.
  5. Dec 1, 2021 at 6:02 PM
    diablodalton
    diablodalton New Member
    Dalton
    Oregon
    2021 Crewmax Platinum MGM
    8" Ready Lift, SPC UCA's., Bilstein B8 8125, Amp Steps, 37/12.5R 20 Cooper STT PRO, On order: Valhalla Armor, Dirty Deeds Exhaust
    Short answer it YES. Take a hard look at your OEM UCA... while they will hold up, they aren't built as well as aftermarket UCA's and do not have the same adjustments. If you don't plan to do any medium off-road trail stuff I wouldn't upgrade. If you plan to off-road and run bigger tires with a lift kit, etc. I would recommend swapping UCA's.
  6. Dec 1, 2021 at 6:02 PM
    Rubberdown
    Those simply help your ability to align. So if you can’t align it they are worth it. If you can’t... uca.
    there is no difference in the ride. Show me someone that has wadded a stock UCA on 5100s and I would be dang impressed.
    BlueRibbon4x4[OP] likes this.
  7. Dec 1, 2021 at 6:02 PM
    BlueRibbon4x4
    Geno
    Dang. No mud boggers and hitting the swamp?
    Toyotoholic likes this.
  8. Dec 1, 2021 at 6:03 PM
    BlueRibbon4x4
    Geno
    I off-road a ton. I’m on 2-1/2” lift up front and 1-1/2” rear. On 35’s.
  9. Dec 1, 2021 at 6:05 PM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    I felt a difference since it’s poly bushings vs rubber bushings. It is only obvious on rough terrain though, I loved the TC uppers I used to run.
    Cruzer, BlueRibbon4x4[OP] and 2mchfun like this.
  10. Dec 1, 2021 at 6:08 PM
    diablodalton
    Dalton
    Oregon
    I bent a UCA, Spindle and ruined a steel wheel off-roading in my FJ. Ever since then I have always upgraded my UCA's, Spindles (with gussets), and Coil Overs. I run SPC's as they are bulletproof, have a ton of adjustment, and are somewhat affordable. (They are the Ashtabula BMX forks of the 70's) I ran Icon's once and had ball joint issues under 4k... needless to say I moved to SPC's and haven't looked back. There are a ton of great aftermarket UCA's out there. (I have had them on 3 FJ's, a Taco, and 2 Tundras... I currently still own an FJ and Tundra)
  11. Dec 1, 2021 at 6:11 PM
    Rubberdown
    Were you on 5100s?
    because if you’re wheeling hard enough on them to bend all that on 5100s... well I’m not saying you deserved it but it was inebitable (say it like in Team America)
  12. Dec 1, 2021 at 6:11 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    If you have no problems right now with OEM, then I’d wheel em till they fall off. That’s what I did :rofl: took me only 6 months after buying the truck to tweak them out of shape.
  13. Dec 1, 2021 at 6:29 PM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    I like the fact that my spc's can be greased. Nothing like good clean lubrication on mechanical moving parts.
  14. Dec 1, 2021 at 6:58 PM
    BlueRibbon4x4
    Geno
    I dig that. I don’t wheel crazy as hell, but since I got my sliders I’ve gotten much more brave as far as challenging stuff. So I assume breakage isn’t far in my future. Haha.
    saybng, Cruzer[QUOTED] and RobertD like this.
  15. Dec 1, 2021 at 7:00 PM
    Cruzer
    Cruz
    Sunnyvale, CA
  16. Dec 23, 2021 at 10:09 AM
    BlueRibbon4x4
    Geno
    Just an update. After installing my UCAs, there’s a small difference on the road. But off-road, there’s a huge difference in ride quality. The truck absolutely feels more planted. Less body roll over rolling whups and uneven ground. High speed driving over the trails make the truck feel more solid, and I definitely have more control. They are amazing, and I recommend this upgrade to anyone who off-roads or needs them for a more accurate alignment. 001D7291-6C46-462D-AE81-3F7FD8AE2A56.jpg
    Toyotoholic, Cruzer and Wallygator like this.
  17. Dec 23, 2021 at 10:23 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Shit, the hell with performance... Those look amazing!
  18. Dec 23, 2021 at 10:28 AM
    BlueRibbon4x4
    Geno
    Thank you, sir!
    Toyotoholic[QUOTED] likes this.
