Turn Signal Stuck On
Discussion in '1st Gen Tundras (2000-2006)' started by rritch01, Nov 23, 2020.
  1. Nov 23, 2020 at 10:05 AM
    rritch01
    rritch01 [OP] New Member
    Randy
    2000 Tundra Limited
    I have a 2000 Tundra Limited which our daughter now drives.
    When I left the house this morning, I noticed that the front passenger turn signal was stuck on (not blinking). I checked the back and it matched the front.
    She cleaned the battery terminals and check the fuse, which is fine.
    Open to ideas.
    Thanks!
  2. Nov 23, 2020 at 10:22 AM
    hammeron
    hammeron New Member
    2002 Tundra v8 Blue 2wd
    sometimes these issues are because of a trailer converter. make sure nothing is plugged into the trailer harness
    near the hitch if you have one.
  3. Nov 23, 2020 at 10:32 AM
    rritch01
    Randy
    2000 Tundra Limited
    Thx. We have wiring for a hitch. We'll check that, too.
  4. Nov 23, 2020 at 9:58 PM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Check bulbs and sockets for the turn signals. Corrosion can cause shorts.
    1lowlife likes this.
  5. Nov 24, 2020 at 7:15 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Also listen for the flasher relay to click.
  6. Nov 24, 2020 at 10:31 AM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    That would be my guess. Replace.
    Do they blink when the hazard light button is on?
  7. Nov 24, 2020 at 12:19 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    +1
    Nice call, SP.
    SouthPaw[QUOTED] likes this.
  8. Nov 30, 2020 at 7:13 AM
    rritch01
    Randy
    2000 Tundra Limited
    All - thanks for the input.
    We replaced the flasher unit, which didn't fix it.
    I forgot to mention the after market trailer lights. I pulled the fuse and all is good. I am not planning on towing anything in the near future. If something comes up, I'll take it somewhere to have it traced out. I'm lousy at chasing electrical issues.
    hammeron likes this.
  9. Nov 30, 2020 at 8:44 AM
    Glad you got it sorted
