Turn signal issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by SR5beatsF150, May 30, 2020.
  1. May 30, 2020 at 3:24 PM
    SR5beatsF150
    SR5beatsF150 [OP] New Member
    2016 toyota tundra sr5 4x4
    Hey guys
    When i use my left turn signal, its flashing fast and the front turn signal bulb is NOT flashing, however when just my running lights are on, the bulb is illuminated fine, just when i cycle the left turn signal, it doesn't flash.
    Checked turn signal fuse, the fuse is fine
    Anyone else ever have to deal with this?
  2. May 30, 2020 at 3:25 PM
    Flasher fluid
    AZTundra and TokerJoker like this.
  3. May 30, 2020 at 3:26 PM
    There are two filaments in the bulb, running light and flasher, one is burned out
  4. May 30, 2020 at 3:33 PM
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Some running lights and signal elements are 2 separate elements in the same bulb. I'd check the bulb and make sure the signal element isn't burned out. Easy to pull and check. I think the SR5's from your vintage have dual element bulbs. The signal is a element is different and brighter than the running light element when 12v is applied.
  5. May 30, 2020 at 3:43 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Howdy from DFW and :worthless:
  6. May 30, 2020 at 4:56 PM
    Jim LE 1301 Camaro Lover, SSEM # 11
  7. May 30, 2020 at 4:57 PM
    X2
  8. May 30, 2020 at 5:21 PM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    Like Jim said X2, plus the '16 SR5 uses that bulb for the DRL's and tend to burn out quicker than normal.
  9. May 30, 2020 at 8:47 PM
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    Damn, I showed up and they had just passed out their last bottle!
  10. May 30, 2020 at 8:57 PM
    They get deliveries on Monday, just go back then.:thumbsup:
  11. May 30, 2020 at 9:00 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    The hyper flash is telling you a filament is burned out.
  12. May 30, 2020 at 9:00 PM
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    :burnrubber:
    Tundyfundy likes this.
  13. May 30, 2020 at 9:01 PM
    Tundyfundy
    Bay Area, CA
    Make sure you get the high weight blinker fluid if you have high mileage.
    TokerJoker likes this.
  14. May 30, 2020 at 11:25 PM
    2manytoys
    2manytoys New Member
    Lupe
    Carlsbad, New Mexico
    2017 black tundra crewmax
    Fab fours premium bumpers frt & rr, retracing bed cover, 5% window tint cept frt which is 60%, has lift from dealer maybe 3 inch
    That's pretty good price mine was $20
  15. May 31, 2020 at 6:49 AM
    2manytoys[QUOTED] and TokerJoker like this.
