Turn signal hyper flashing
Discussion in '2.5 Gen Tundras (2014-2021)' started by Blazing Blue, Nov 20, 2019.
  1. Nov 20, 2019 at 2:18 PM
    Blazing Blue
    Blazing Blue [OP] New Member
    Hi everyone,
    I have a 2016 cm; which I just did the led headlight upgrade and everything went smoothly. I have an issue with the turn signal hyper flashing. The bulbs are led switchbacks and after repining the purple/white wires, I got the switchback to work. The only problem is that they hyperflash when the headlights/turn signals are on, but not when the headlights are off and the emergency lights always work fine. This only happens when the headlights are on. I do have resistors. Any ideas how i can get this set up to work properly?
    Thanks in advance
    Gee Dub likes this.
  2. Nov 20, 2019 at 2:26 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    When I did mine, I just pugged in the switchbacks, then put the resistors on the tail lights' wire. Easy and quick. May have connected incorrectly? What brand? Hazards working, but not turn signals is normal...as mine did this as well before I put the resistors on.
  3. Nov 20, 2019 at 2:30 PM
    Shephard_Of_The_Tundra
    Shephard_Of_The_Tundra DIY try guy
    Corpus Christi, TX
    2016 Black Tundra SR5 4.6 DC 2WD
    Morimoto 2 stroke H4 LED Headlight Bulb VLEDs 3157ck Amber Triton V6 TurnSignal Auxito LED reverse bulbs OEM Toyota LED smoked fog lights Auxito LED T10 license plate bulbs Auxito LED T10 Side marker headlights LASFIT LED T10 3rd brake light Xenon Depot T10 LED Bed/Brake Lights TRD Off-Road Black/Chrome Wheels Bridgestone Duellers 255/70/R18 Front & Rear TRD Sway bars MBRP Dual side exhaust exits Drop-in K&N air filter TRD air flow accelerator Toyota Rubber floor liners OEM Rear under seat storage box Kenwood DMX7706S head unit TRD Shifter knob Center console organizer tray Dual USB fast chargers center stack
    Do you have led turn signals on the rear?
  4. Nov 20, 2019 at 2:33 PM
    Blazing Blue
    Sorry, I didn’t mention I upgraded to the newer led headlights.
  5. Nov 20, 2019 at 2:40 PM
    Blazing Blue
    It came with Spyder tail lights these which are led.
  6. Nov 20, 2019 at 2:54 PM
    Corpus Christi, TX
    That is the problem...
    I had the same issue, same taillights and upgraded my turn signals to triton v6 amber LEDs from VLEDs.
    I believe the issue arises from the circuit not having enough load when LEDs are on the front and rear turn signals.
    You'll need stronger resistors that create more load
    Fotnot likes this.
  7. Nov 20, 2019 at 3:05 PM
    Broncoman
    Broncoman New Member
    I did the same to my 2017 1794 edition and had to get a bigger flasher relay to stop the hyper flashing even with resistors on the front and back. i soent a lot of money for the switchback blinkers to figure out that the 2017 doesn't use those for running lights but still installed because of the brightness of the blinker itself. I installed new LED Fogs, HID headlights, LED puddle lights, LED Interior, Reverse and LED brake lights. Looks like a Christmas Tree at night and when it unlocks can't even tell there is any glass in the truck. LOVE LOVE IT
  8. Nov 20, 2019 at 3:18 PM
    Corpus Christi, TX
    I just snipped the purple wire to the amber drl. It got rid of the hyperflash, and now when the headlights are on, the amber turns off until the turn signal is activated. But amber drl function still works!
  9. Nov 20, 2019 at 3:24 PM
    Blazing Blue
    Do you have white/amber switchback bulbs?
  10. Nov 20, 2019 at 3:28 PM
    Corpus Christi, TX
    No, just the ambers.
  11. Nov 20, 2019 at 3:29 PM
    Blazing Blue
    I have a 50W 6ohm resistor on each side how much bigger do I need? Is a flasher relay better? Do you have a link to the right ones I should get?
  12. Nov 20, 2019 at 3:33 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
  13. Nov 20, 2019 at 4:07 PM
    Blazing Blue
    Do you have the led switchbacks or just the amber?
  14. Nov 20, 2019 at 4:49 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Regular led amber, but I believe these work with switch backs. Shoot them an email
  15. Nov 22, 2019 at 4:03 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    When I installed my switchbacks, I had connected the harness wrong. It seems intuitive but it’s actually tricky. Vled has a separate page on their website that shows this correct connection method for the resistors and ballasts.
    Once I called them I switched around the connectors and they worked perfectly.
  16. Nov 22, 2019 at 6:12 AM
    timsp8
    NY
    Yeah, like others said the voltage is off. Fast blinking means the truck thinks the bulb is out. Since you verified it isn’t, that means the truck isn’t getting the voltage reading it is expecting and giving an “error code”.
    Maybe the leds take too much power and nothing is returned from the blinker when they are on? Or not as much power and regular headlights?
