Tune up 15 tundra 66k miles yay or nay?
Discussion in 'General Tundra Discussion' started by Kalashnikov 47, Sep 24, 2019.
  1. Sep 24, 2019 at 7:13 AM
    Kalashnikov 47
    Kalashnikov 47 [OP] New Member
    Minnesota
    2018 Sr5 double cab gang
    I have a 15 trd pro, 66k miles. Still runs great should i get a tune up or no? Opinions please
    WrigglingWilly likes this.
  2. Sep 24, 2019 at 7:38 AM
    bigandtall
    bigandtall New Member
    Indianapolis Motor Speedway
  3. Sep 24, 2019 at 7:57 AM
    Dontra
    Dontra Newer
    Don
    AR
    2021 Ram Big Horn
    2021 Ram Patriot Blue, Lonestar or Bighorn, Crew cab 4x2, 5.7 bed, 5.7 Hemi etorque, Level 2, anti-spin 321 rear end, Air ride, 33 gal tank, 18 in wheels, Multifunction tailgate, Ram box, Wheel liners, MT Brown Deluxe bucket seats, 8.4 no navigation, Trailer brake controller. Front and rear rubber mats. Mopar power steps,8 yr 85K extended Mopar warranty.
    If it is running great, leave it be
  4. Sep 24, 2019 at 8:07 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    What do you mean by tune up? Have all the regular scheduled maintenance items been done?
    I just hit 40k and decided to change the front and rear differential and transfer case oil along with oil change and tire rotation.
    If you are due for maintenance then my all means maintain.
  5. Sep 24, 2019 at 8:08 AM
    blizz86
    blizz86 New Member
    How did your front diff and tcase fluid look? I've only done my rear so far at 50k.
  6. Sep 24, 2019 at 8:14 AM
    Pudge
    CT
    The front isn't done yet, I hope to do it tomorrow, the Tcase and rear I did a few days ago. T case was pretty clean, not brand new looking oil clean but pretty clean. I replaced with Ravenol 75w, for $35 and 15 minutes it's worth it. I don't use 4wd very often, maybe a few times per month in winter and whenever I remember to run 4x4 for a few miles in the warmer months.
    The rear, as you know was nasty, black, stunk badly and the magnetic plug was gunked up.
  7. Sep 24, 2019 at 8:16 AM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    If you live somewhere salty(do they salt roads up there in Minnesota?) , maybe just bust the plugs loose and clean up and lube the threads.
