2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Jan 14, 2019 at 2:01 PM
    #1051
    SG TRD
    SG TRD New Member
    would the noauka ip68 night vision 170 camera work with the trd pro grill? and will it work with the FRAC?
    Norfolk757 likes this.
  2. Jan 16, 2019 at 2:41 AM
    #1052
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @SG TRD, Yes that camera is compatible with the FRAC Harness. Any 12 volt automotive camera with an RCA video output will work. A lot of guys have installed that camera on their TRD Pros.
  3. Jan 17, 2019 at 1:10 PM
    #1053
    SG TRD
    SG TRD New Member
    Thank you for the reply. Does the FRAC come with install instructions?
  4. Jan 17, 2019 at 1:28 PM
    #1054
    Video in first post.
  5. Jan 18, 2019 at 6:26 AM
    #1055
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    As Jim said, there is a video in the first post of this thread. I also provide written installation directions once your order is paid and shipped. You can also PM me for any specific questions.
  6. Jan 18, 2019 at 6:37 AM
    #1056
    SG TRD
    SG TRD New Member
    Thank you for the reply. I did see video. glad to know about written install for that was the root of my question. Exellent thread!!!
  7. Jan 29, 2019 at 10:47 PM
    #1057
    cjscinta
    cjscinta New Member
    Nashville TN
    Hey Lou. @TundraTex Any luck getting the dvr installed in the system? Seems like it would be a nice add on.
  8. Feb 1, 2019 at 7:57 PM
    #1058
    acmesupply
    acmesupply New Member
    2018 SR5 CM Silver TRD
    Thanks Rustynutz, the picture made for a quick install with the same rocker switch.
    Kept my nutz from getting rusty sitting in the seat with a multimeter. :cheers:
  9. Feb 5, 2019 at 8:56 PM
    #1059
    cjscinta
    cjscinta New Member
    Nashville TN
    B979C831-E0EF-48DA-9259-BAB08DB3A323.jpg 0D698A01-4C46-4B5E-8F1D-2F6F18BC421D.jpg 53AF1ABE-53E8-45AF-B9DD-CF6E2DEFCF3A.jpg 6002A1D2-F3F8-474D-9C30-6F9133658085.jpg Thank you @TundraTex. Another successful FRAC install. What an awesome upgrade to my truck. As stated above somewhere, if you buy the same camera be sure to cut the white wire NOT the green wire as the instructions that come with the camera say. 2FA2CBC5-F26B-4A7F-B58D-6275172F4012.jpg
    escuzi_me and TundraTex[OP] like this.
  10. Feb 10, 2019 at 12:59 PM
    #1060
    4X4Phil
    4X4Phil New Member
    2018 Tundra SR5 TRD OffRoad
    Just Joined, this is a really great mod, too bad can't get it in Canada
  11. Feb 10, 2019 at 2:00 PM
    #1061
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
    I have the same camera and cut the wrong wire! They need to fix their instructions! I’m switching to a PRO grille like yours soon, did you drill a hole for the camera and just put the nut on the topside?
  12. Feb 10, 2019 at 3:09 PM
    #1062
    Welcome from NY.
  13. Feb 10, 2019 at 6:04 PM
    #1063
    RJN55
    RJN55 New Member
    2018 Tundra LIMITED DC (Flares, Rear Sway Bars, Timbrens, B&W Gooseneck Hitch, Running Boards, Visors, 18 inch rims with 10 ply Michelin AT/2's, Bed Lights, Tow Mirrors
    Hi.
    Like all the posts on the FRAC Harness.
    I'm looking for a front add on camera plus a camera up on the top of the cab (for hooking up gooseneck trailers), and another in my horse trailer plus I'd like to add the AV input (saw your posts on quality etc).
    What I was wondering is:
    i) if I added the AV addon's ( something like https://www.amazon.ca/dp/B00QGRFJN4...olid=2HUIT85HTSMX1&psc=0&ref_=lv_ov_lig_dp_it ) that are supposedly plug compatible on the 28 pin connector, would that fit in between the FRAC connector and HU allowing me to have the AV input and keep the FRAC functionality?
    ii) has anyone got a dash mounted switch for more than just going between the front and rear camera? I would have four potential (front, rear bumper, rear cab top, trailer (which won't always be attached). Presumably a
    'keep it simple' approach would be to have the three addon (Front, Cab, Trailer) RCA camera plugs accessible with an extension cable from the FRAC harness so one could switch them (eg plug in the camera desired) around as needed for a particular trip.
    Thoughts?
    Thanks
  14. Feb 10, 2019 at 7:30 PM
    #1064
    cjscinta
    cjscinta New Member
    Nashville TN
    Yes. I just drilled a hole. Pretty easy actually. Good luck.
  15. Feb 12, 2019 at 3:57 PM
    #1065
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    I drilled a hole in the bottom row of my grill, but I only am getting half of the coverage because half of the camera is just picking up the bottom chrome part of the grill. I need to take the grill off and fabricate some kind of bracket to get the camera farther forward and/or higher up. Is it hard to take off the grill? I have a 2018 CrewMax with the honeycomb grill. The install that I did previously I did just by reaching through the access hole. I scraped my arms up pretty good. LOL.
  16. Feb 12, 2019 at 4:25 PM
    #1066
    RJN55
    RJN55 New Member
    Could you make a tapered washer to change the angle?
  17. Feb 12, 2019 at 7:42 PM
    #1067
    cjscinta
    cjscinta New Member
    Nashville TN
    Taking the grill off is not difficult. There are several YouTube videos to help you out.
  18. Feb 12, 2019 at 7:53 PM
    #1068
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    I didn’t think of that.
    Thanks!
  19. Feb 12, 2019 at 11:24 PM
    #1069
    ZPMAN
    Minnesota
    If you watch the videos on removing the grill then I might add that if you take a long screwdriver and push down here one side at a time
    The grill comes out very easy.
    Tundra805, WAtundra4x4 and okcowboy like this.
  20. Feb 13, 2019 at 12:18 AM
    #1070
    acmesupply
    Thank-you ZPMAN, sometimes I'm in such a hurry I didn't think about that. One thing I do is when I know I'm taking the grille off the next day after work to do more work, use heavy zip ties and lightly put the grill in without snapping in. Tie one on each end on the top were the black plastic push down holes are and around the metal part. This will hold it without having to even use the upper 10mm screws.
    ZPMAN likes this.
  21. Feb 13, 2019 at 7:03 AM
    #1071
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Thanks a lot!
    ZPMAN[QUOTED] likes this.
  22. Feb 13, 2019 at 7:32 AM
    #1072
    escuzi_me
    escuzi_me Shut up baby, I know it!
    William
    Nashville, TN
    2019 Super White TRD Pro
    Do you recall what size nut you used for the camera bolt? I don't recall seeing one included in the box when I got the camera. Started the install last weekend, one of the RCA connectors was bad and wouldn't send the feed unless you pushed it into the harness and held it there. So going to splice it with a replacement.
    @TundraTex I was trying to find how to mirror iPad/iPhone with it as one of your posts mentioned it. I couldn't find it in the instructions though, am I missing it somewhere?
    Truck is at the dealership for other things so will be finishing up this install this weekend. And REALLY glad I saw the part about cutting the correct wires in here. Dodged that bullet for sure!
  23. Feb 13, 2019 at 12:03 PM
    #1073
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    The other day I got a bunch of error messages - Trailer Brake Malfunction, Cruise Control Malfunction, Pre-collision System Malfunction, and Check Engine light. I just left the dealer and they couldn’t figure it out. They are convinced it is the FRAC system and told me I had to remove it before they would go any farther. So tomorrow I need to uninstall my FRAC system and then take it back so they can find something.
    Has anybody with the FRAC system had this problem?
  24. Feb 13, 2019 at 5:10 PM
    #1074
    RJN55
    RJN55 New Member
    Is there 'one' fuse that disables the complete entune system...and wouldn't that potentially eliminate that system from the issue? I don't believe that 'entertainment' system is tied into those systems. Wonder what they would say if you'd put in a android friendly system. Certainly the truck runs without those codes when the Toyota 'radio' dies.
  25. Feb 13, 2019 at 10:36 PM
    #1075
    escuzi_me
    William
    Nashville, TN
    Yes I got all those errors when I forgot to reassemble the grill 100%. I didn’t have the covers on or the wiring hooked back up. Once I completely put everything back together it worked together fine
  26. Feb 14, 2019 at 6:21 AM
    #1076
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @Bappa, I have not heard about this issue before but it seems unlikely the the FRAC Harness would be causing it. The harness only ties in to video and power. You might check your TSS grill emblem sensor and make sure it is properly reconnected.
    Please keep me posted on this.
    escuzi_me likes this.
  27. Feb 14, 2019 at 7:55 AM
    #1077
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    I never disconnected it. I never took my grill off. I wiggled my arm through the small access hole to install the camera.
  28. Feb 14, 2019 at 10:00 AM
    #1078
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    I just took the entire FRAC system out; harness, cables and camera. It is completely stock for my dealership appointment tomorrow. When they still cant figure it out, I’ll try not to say I told you so.
    However, I f this is going to be an issue every time I need warranty work, then I’m questioning whether I’ll reinstall the FRAC system.
  29. Feb 14, 2019 at 11:08 AM
    #1079
    PinoyRN
    PinoyRN Manila Gorilla
    Sammy
    Phoenix, AZ
    ‘06 Tundra
    If you don’t end up reinstalling, I’ll take it off your hands. :hattip:
  30. Feb 14, 2019 at 12:45 PM
    #1080
    goldldr
    goldldr New Member
    Andy
    Spring,TX
    2019 SR5 CrewMax (Cavalry Blue)
    This looks like exactly what I am looking for. I'll need to get it installed as I have no mechanical or electrical prowess at all, but a front facing camera would make parking much easier in a tight spot. I will need to do some additional research and find a place to get it installed, but I am very excited to find something like this is available!
