Tundra vs. Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by TundraDan723, Jan 31, 2018.
  1. Jan 31, 2018 at 8:32 PM
    TundraDan723
    TundraDan723 [OP] Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    Quick Question:
    I have a totally stock 2011 Tundra TRD and my buddy at work as a 2008 Tundra with an exhaust upgrade (MBRP I think). While his truck is 3 years older than mine, with double the miles, it is much more responsive/snappier than mine. He also gets noticeably better gas mileage (both hand calculated). Could the exhaust make that much a difference?
    Marty McFly likes this.
  2. Jan 31, 2018 at 8:37 PM
    Marty McFly
    Morty McBoonJug
    Not sure about the exhaust making a difference, but you can throw it in beast mode and it will put some pep in your step :burnrubber:
  3. Jan 31, 2018 at 8:47 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Exhaust alone wouldn’t amount to much difference in mpg. Maybe 1mpg at most.
    Are the tires the same size?
    Wheel and tire weights the same?
    Is there any added weight on yours?
    Same driving style?
    Same amount of Hwy vs city driving?
  4. Jan 31, 2018 at 9:01 PM
    TundraDan723
    Good catch. I have 275/75/18 and he has stock 265/75/18. That could be it. Forgot about that.
  5. Feb 1, 2018 at 7:23 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    They tweaked the throttle settings around 09-10. The earlier 2nd gens have very "jumpy" throttle tip-in.
    Rex Kramer likes this.
  6. Feb 1, 2018 at 7:31 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    ^^^^^ My '07 was very touchy on the throttle. I really had to focus leaving stop signs to avoid jerking passengers heads back while taking off. By comparison, on my '16 I feel like I need to get out and help the truck forward by pushing it. I installed a BD tuner and now the '16's response is similar to the old '07.
    joonbug and Black Wolf like this.
  7. Feb 1, 2018 at 7:33 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Yep. Took me a while to get used to that.
  8. Feb 1, 2018 at 7:34 AM
    Aurora CO
    Even more jumpy with tow haul on....Hoo..wee...
  9. Feb 8, 2018 at 2:16 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Our newly acquired 07 5.7 is very jumpy, sensitive accelerator pedal. After driving my Duramax 6.6, which requires leaning into the pedal to go, I have to be very careful not to throw passenger's heads back when taking off from starts.
    Is there a way to make it less sensitive?
  10. Feb 8, 2018 at 2:25 PM
    15whtrd
    15whtrd Mr. Blonde
    I think you guys should drag race to find out whos is faster LOL. On a closed Street of course. He will probably get you in tire size alone. And it’s obviously going to sound way better too!:boink:
    bicklebok likes this.
  11. Feb 13, 2018 at 2:29 PM
    GrayBear
    GrayBear New Member
    Coach Rich
    2016 Magnetic Gray Tundra CrewMax
    Purchased September 4th 2016
    Biggest factor would be # hwy miles vs. city.
  12. Feb 13, 2018 at 4:27 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    A BullyDog tuner will allow you to change the throttle sensitivity. TechStream may also but I don't know for sure.
    Mountun Goat likes this.
  13. Feb 16, 2018 at 2:34 PM
    bicklebok
    bicklebok New Member
    Ronnie
    Good to hear all the posts about throttle response because I have wondered about my 2010 since I bought it last year. It is very touchy! I have to be careful taking off as it feels like it would light the tires up.
