Tundra transmission issue
Discussion in 'General Tundra Discussion' started by antrolopitecus, Feb 19, 2018.
Why start shaking
  1. Why
    0 vote(s)
    0.0%
  2. How fix
    1 vote(s)
    100.0%
Multiple votes are allowed.
  1. Feb 19, 2018 at 7:37 PM
    antrolopitecus
    antrolopitecus [OP] New Member
    Javier
    2008 tundra
    Hi I have a problem with my tundra 2008 transmission start shaking when speed is between 30 and40 miles , who can help me with some answer why happen?
  2. Feb 19, 2018 at 7:42 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Welcome!
    How do you know it’s the transmission?
    Do you have a lift installed?
    How worn are your tires?
    When is the last time you got an alignment?
    Did this suddenly just start happening or did it come on slowly?
    Probably either tires or the driveshaft imbalance. If you have a lift installed you might need to add a drop to the carrier bearing.
    ColoradoTJ and 15whtrd like this.
  3. Feb 19, 2018 at 9:58 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Sounds like driveline balance issue....like Brian mentioned
    Y0TA PR0 likes this.
  4. Feb 19, 2018 at 10:30 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome.
  5. Feb 19, 2018 at 10:35 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Didnt think of that :bowdown:
    Watt maker likes this.
  6. Feb 19, 2018 at 10:44 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    Welcome!
  7. Feb 20, 2018 at 1:05 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
