Tundra tow mirrors
Discussion in 'Towing & Hauling' started by Robtosaya, Sep 19, 2018.
  1. Sep 19, 2018 at 9:39 PM
    Robtosaya
    Robtosaya [OP] 2015 Platinum
    Rob
    2015 platinum tundra 4x4
    Bought tow mirrors for my 2015 platinum Tundra from Trail Ridge through 1A auto.
    The install was easy. Only problem is the running lights and blind spot monitoring do not work. Although the turn signal led works. I talked to 1A auto and they gave me a lame excuse that since my Tundra has power folding mirrors and the tow mirrors are not “power folding” that is the reason my running lights and blind spot monitoring light dosnt work! I cant tell if the heated mirrors actually heat until it gets into winter. Anyone else come across this weird situation??
  2. Sep 19, 2018 at 9:44 PM
    ARamirez73
    ARamirez73 El Coyote del los rieles de Texas TTC#158
    THE LONE STAR STATE...RGV TEXAS
    2014 CM TSS 4WD SR5 5.7 MGM
    Rough Country 6" lift / 35x12.50R20 Cooper Discoverer ST Maxx/ 20x9 +20 Fuel wheels "Mavericks" (Came with) / S&B CAI/ 2-10" Rockford Fosgates R2/ Massive Audio Nano N2 amp (Came with)/ KatSkins seat covers (Came with)/ Weathertechs window vent visors and floor mats/ 1A-AUTO.com aftermarket tow mirrors/ Undercover tonneau bed cover/ Viper alarm 3305V/ Flowmaster Super 40 Dual in-out/ 40" led light bar/ TRD Pro grille/Rough Country 30" LED light bar/TRD rear sway bar/ Ranch Hand legend grille gaurd/ Nfab nurf bars
    I'd send back, send a PM to @Roman and get OEM mirrors
    Roman and Sas like this.
  3. Sep 19, 2018 at 9:45 PM
    ColoradoTJ Professional Cat Herding Expert Staff Member
    White 3500HD
    Fuzzy Mirror Dice
    Welcome to the site Rob.
    I do believe what they told you is correct.
  4. Sep 19, 2018 at 9:48 PM
    Robtosaya
    Rob
    Ok. FYI, i also asked my local Toyota parts department if the Toyota OEM tow mirrors come with the blind spot monitoring and they said no.
    ColoradoTJ likes this.
  5. Sep 20, 2018 at 4:31 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    The running lights will not work on the tow mirrors if you have a Platinum without running additional wires. Also, it may seem like a dumb question but I have to ask - does your Tundra have blind spot monitoring? The mirrors alone will not add this functionality. To test the heat just turn the switch on, wait a minute and put your hand on the mirror. You'll be able to feel the heat.
    Pro-Yota and Sas like this.
  6. Sep 20, 2018 at 7:11 AM
    Robtosaya
    Rob
    Yes, my platinum has working blind spot monitoring , heat and auto folding mirrors.
    831Tun likes this.
  7. Sep 20, 2018 at 7:29 AM
    831Tun
    831Tun IMA BasTRD
    Warren
    Santa Cruz
    '16 CM limited
    ADS C/O w/clickers, ADS bypass rear, Icon UCAs, Toytech shackles, chrome delete, Pro grille, TRD dual exhaust dumped, de-badged, black LED tail lights. BHLM w/projectors, 295 70 18 Cooper STT pro on stock rims w/1.25" Spider Tracks. N_Fab bumper w/Baja Design fogs and ditch lights, 13" antenna x, RCI skid, All Pro sliders, ARB compressor
    Welcome Rob. I think I've read a post on here about re-pinning the connector to get the BSM to work? Do you notice any vibration of the mirrors when driving?
  8. Sep 20, 2018 at 7:30 AM
    2015Crewmax
    2015Crewmax New Member
    Cory
    VERMONT
    15 Crewmax
    Rough Country 3" Lift kit, TRD Swaybars, TRD dual exhaust,
    :worthless:
    I am interested in what these look like.
  9. Sep 20, 2018 at 7:33 AM
    Robtosaya
    Rob
    No vibration, they are awesome mirrors. Just a little dissapointed about the lights!
    At least the turn signals work!!
    831Tun likes this.
  10. Sep 20, 2018 at 1:10 PM
    Robtosaya
    Rob
  11. Sep 20, 2018 at 3:15 PM
    209TRDPRO
    209TRDPRO New Member
    2016 Tundra TRD PRO
    Just lights for now
    selling your mirror?
  12. Sep 20, 2018 at 3:25 PM
    Pro-Yota
    Pro-Yota New Member
    Rick
    2019 TRD Pro Tundra CM
    after the install did you get a BSM error message on your dash? I really like those mirrors and need tow mirrors, I have heat and BSM but not powered and would welcome the additional LED lights.
  13. Sep 20, 2018 at 3:38 PM
    Robtosaya
    Rob
    I did not get that error, and when i pushed the BSM button on the dash, it beeped and green light came on like business as usual. Thats why i’m so frustrated with this. I am keeping them since i only tow my travel trailer maybe once a month. Its an easy 20 minute swap out.
  14. Sep 20, 2018 at 3:49 PM
    Robtosaya
    Rob
    Going camping at the end of this month, i will post pics of the full truck/trailer/tow mirror setup.
  15. Sep 21, 2018 at 4:16 AM
    SOB
    SOB Big Member
    Ohio
    I have the same mirrors but power folding and no BSM. I like them however I've had to have them replaced under warranty 3 different times for 3 different reasons over the last 1.5 years.
  16. Sep 21, 2018 at 7:04 AM
    Robtosaya
    Rob
    Can you elaborate on the 3 reasons you returned them?
    My attitude now is that the mirrors work for the main reason i got them,
    to see behind a 8’ wide trailer. And back it into camp sites. The bells and whistles, while nice, are just that.
    I even tried the cheap clip on mirrors which cost $45 so i can keep my stock mirrors with BSM but they vibrated and the actual viewing area was so small. Some one commented that when you are pulling a 26’ trailer, you dont really have the problem of that blind spot anyway. That is true!
  17. Sep 21, 2018 at 7:11 AM
    SOB
    SOB Big Member
    Ohio
    First time at install, passenger side had faulty wiring from the factory, second time the passenger side developed lots of play in the folding arm and it would move while driving down the road - just enough to catch out of the corner of the eye and was annoying, third time the power fold stopped working occasionally and would only fold/un-fold half way. Warranty return process has been quick and easy though.
    I personally would have bought OEM mirrors if I didn't want to keep the power fold feature. OEM power fold tow mirrors are $800 and I wasn't willing to shell out that much.
  18. Sep 21, 2018 at 2:45 PM
    Pro-Yota
    Pro-Yota New Member
    Rick
    have you checked the TRD site for your mirrors? im like on the edge of buying OE and skipping all the drama with aftermarket https://trdshop.carlocktoyotaoftupelo.com/
  19. Sep 22, 2018 at 6:23 PM
    Silplat17
    Silplat17 New Member
    MA
    17 Platinum Tundra (Silver Sky Metallic)
    I just purchased the same mirrors for my 17 platinum. The lower set of leds on the side of the mirrors typically used as running lights is what is lighting up for my bsm lol.. I need to get a pinout of my truck wiring so i can change the wiring inside of the mirror itself before color matching.
  20. Sep 22, 2018 at 6:58 PM
    Robtosaya
    Rob
  21. Sep 24, 2018 at 4:42 AM
    SOB
    SOB Big Member
    Ohio
