Tundra shocks for sequoia?
Discussion in 'Sequoia Builds' started by Bigfatlonghorn, Oct 27, 2021.
  1. Oct 27, 2021 at 7:51 AM
    Bigfatlonghorn
    Bigfatlonghorn [OP] New Member
    Dean
    2001 Toyota Sequoia Limited RWD
    2.5 Inch rancho quicklift(front), 2 inch daystar lift(rear)
    Does anyone know if aftermarket bilstein rear shocks for a 1st gen tundra with fit a 1st gen sequoia in the rear
  2. Oct 27, 2021 at 8:08 AM
    des2mtn
    des2mtn Third Member
    Where my wheels stop rolling
    2004 Black DC Limited 4x4
    Tonto cover
    Pretty sure the shock mounts are different for the Sequoia. @empty_lord
  3. Oct 27, 2021 at 10:56 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I genuinely do not know I’m afraid
  4. Oct 27, 2021 at 1:25 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Easy way to check is to search for rear shocks for same year tundra and your sequoia- if same -part numbers could match.
  5. Oct 27, 2021 at 2:47 PM
    des2mtn
    Tonto cover
    Cummins3500 likes this.
  6. Oct 27, 2021 at 5:11 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    From what I can tell, they’re different. My wife’s truck has rear air suspension, which has a different set of part numbers.
    I wanna say the sequoias rear axle is setup different than a tundras of the same years. But I don’t have a for sure answer, I just now started hunting replacement for our truck.
  7. Oct 27, 2021 at 5:14 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome
  8. Oct 27, 2021 at 7:00 PM
    farnsrocket
    farnsrocket New Member
    They look similar, especially the mounting points (holes on bottom, posts on top)but I’m guess the geometry/travel/length is different.
