Tundra rear chase light/CB antenna mounts
Discussion in 'Marketplace - Other' started by Jwood562, Apr 17, 2021.
  1. Apr 17, 2021 at 10:52 PM
    Jwood562
    Jwood562 [OP] New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    These are steel brackets that line up with the existing holes in the tundra beds.
    perfect for chase light mounting or CB antenna mounting.
    I fell in love with the sdhq mounts but could not justify $100 for two of them.
    These are 14 gauge steel (5/64) and powder coated black and come in at .080 after powder coating.
    1/4” holes drilled, perfect for 6mm bolt needed for existing bed holes.
    $25 shipped per pair, no hardware.
    I can tell you what hardware to get to properly mount (spacer and bolt required)
    I have one “blemished” pair, used for mock up. I was testing hardware and stripped the powder coating under the bolt head. $17 shipped for that.
    these will bolt up and be flush with the top of the bed rail.
    check out my pics.
  2. Oct 4, 2021 at 7:21 AM
    zriel10
    zriel10 New Member
    Ariel
    2018 Tundra
    Do you still sell these?
  3. Dec 22, 2021 at 7:09 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    yes do you sell these?
  4. Dec 22, 2021 at 7:50 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Would be nice if there was a mount that was bolted from the other side of that bed wall so that folks with tonneaus can use it. I'd buy it.
    Silv333 likes this.
  5. Dec 22, 2021 at 7:52 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    Yeah I want to bolt it on that end on the corner of window. I like the rago one but don’t like how it’s all the way in rear of bed.
  6. Dec 22, 2021 at 8:33 PM
    Jwood562
    2013 Tundra 4x4
    I think I have a few sets left.
    Let me check and I’ll update the post
  7. Dec 22, 2021 at 9:06 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    Awesome thank you
  8. Dec 26, 2021 at 4:55 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    I have the same want…any luck?
  9. Dec 26, 2021 at 6:54 PM
    Jwood562
    2013 Tundra 4x4
    Ok. I found 2 sets and a blemished single mount
    Silv333 likes this.
  10. Dec 26, 2021 at 6:55 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    Able to be used with a cover in place?
  11. Dec 26, 2021 at 6:59 PM
    Jwood562
    2013 Tundra 4x4
    not sure. I don’t have a cover but the mount sits flush with the top of the bed.
    But if you mount a light or antenna it will be above the level of the bed.
    I actually ended using these mounts on my roof rack for chase lights and don’t have them mounted in the bed anymore
    Silv333[QUOTED] likes this.
  12. Dec 26, 2021 at 10:38 PM
    Jwood562
    2013 Tundra 4x4
    @Silv333
    if you want, i'll send you the blemished single one I have to test out. for free. let me know
    for the remaining two sets I have left.
    $20 shipped per set. first come first serve
    Silv333 likes this.
  13. Dec 27, 2021 at 9:01 AM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    That’s awesome. Thanks man. I’ll DM you.
