Tundra pulling 5th wheel
Discussion in 'Towing & Hauling' started by Bigtex1, May 13, 2019.
  1. May 13, 2019 at 12:03 PM
    Bigtex1
    Bigtex1 [OP] New Member
    Kim
    2016 Tundra Crewmax
    Super Springs
    Our new Mesa Ridge Lite 2804RK
    Downytide, RRR1C0, plumber802 and 9 others like this.
  2. May 13, 2019 at 12:06 PM
    KeetAz
    KeetAz New Member
    Gilbert AZ
    2020 SuperWhite PRO
    I’ve yet to see a tundra pulling a 5th wheel in person. How’s it doing? Weight?
    plumber802 and PRO BLANCO like this.
  3. May 13, 2019 at 12:14 PM
    Bigtex1
    Kim
    2016 Tundra Crewmax
    Super Springs
    It’s pulling fine. The UVW is 7495 with a pin weight of 1100lbs. Couldn’t be happier. I’ve already been on I-70 and I-80 with it. So much better than pulling a TT
    CO_Native and Tundratoofun like this.
  4. May 13, 2019 at 12:29 PM
    KeetAz
    KeetAz New Member
    Gilbert AZ
    2020 SuperWhite PRO
    That’s awesome. Glad it’s working out for you!
  5. May 13, 2019 at 12:55 PM
    Nm6300'asl
    Nm6300'asl New Member
    2018 dc 2wd sr5 with sr5 upgrade
    6112-5160's, airbags with cradles, toytec shackles, 295-70-18 pathfinder a/t, tonno pro tri fold, trd duals, trd cai, trd pro skidplate, curt a16 5thwheel hitch, toyota bed mat [from last tundra], tinted windows and white paint cuz its the fastest color!
    Very nice! Are you useing a sliding hitch? Our 5er looks very similar but we are a bit heavier.
  6. May 13, 2019 at 1:03 PM
    koditten
    koditten New Member
    With a crew max, the sliding hitch is mandatory.
    I've been towing a 26 foot 5th wheel for the last 4 years and am planning to move up to a 28 footer.
  7. May 13, 2019 at 1:25 PM
    Nm6300'asl
    Was wondering about the hitch, we have the reese revolution pinbox, so we dont pivot at the hitch on my DC. Was curious if that setup works on CM as well.
  8. May 20, 2019 at 11:47 AM
    Bigtex1
    Kim
    2016 Tundra Crewmax
    Super Springs
    I have a Reese 15k hitch in the bed with a sidewinder on the pin. It lets me do more than 90 degrees and love it. The 5th wheel is 30’. Our next run will be up the 299 then take the 96 from there.
    Nm6300'asl likes this.
  9. May 20, 2019 at 12:03 PM
    Bigtex1
    Kim
    2016 Tundra Crewmax
    Super Springs
  10. Sep 16, 2021 at 9:37 AM
    Rbeard18
    Rbeard18 New Member
    Ricky
    2018 Tundra Crewmax Shortbed
    I know this post is a few years old. Been hauling my TT for a year now with my 2018 Tundra CrewMax. Just traded up to a Starcraft Telluride. Installing the Pullrite Superglide 3100 hitch and leaving the current pinbox. I was torn to do the reese sidewinder or so the Autoslide hitch. I'm anxious and nervous all at the same time. Will be hauling from Iowa to Arizona here in a few weeks.
    Half Assed and Leo's first like this.
  11. Sep 16, 2021 at 12:13 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Eibach Pro Truck Stage 2 suspension, HD RAS, 275/70-18 Wildpeak AT, LoPro bed cover, TRD rear sway bar, DD 10 inch exhaust, and various other goodies
    Guessing the OP traded the Tundra for a HD truck. He has not been logged on this site since June 2019 and this was his only post.
  12. Sep 19, 2021 at 4:42 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    My payload number won't get me anywhere close to being able to tow even the smallest fifth wheel.
  13. Sep 20, 2021 at 12:51 PM
    Retired...finally
    Maybe the Scamp if you can find one.
  14. Sep 27, 2021 at 8:20 PM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    Escape 5.0 is about perfect for a Tundra.
    ATHiker likes this.
  15. Oct 9, 2021 at 7:37 AM
    Rbeard18
    Rbeard18 New Member
    Ricky
    Bit the bullet, and proceeded with the 5th wheel purchase. I have sumospring bumpstops, Michelin 10ply, Pullrite Superglide 3100 with their 3 inch lift for their receiver. So far, very pleased with the performance of the Tundra and also the Pullrite setup. Headed back to AZ from IA next week, will be the true test.
    Picture of superglide does not show with 3inch lift. Determined after installed it was needed.
    I put 65psi in my tires, apparently Toyota stock TPMS only goes to 50psi(Per Discount Tire Rep), so TPMS light stays on, but tires are rated to 80psi cold. Have an aftermarket TPMS on trailer to watch their PSI and Temp.
    The Dude, jrquist, JDR76 and 3 others like this.
  16. Feb 16, 2022 at 5:24 PM
    Rbeard18
    Rbeard18 New Member
    Ricky
    I failed to post sooner. Hauled from Iowa to Arizona. No issues whatsoever. 2 items I'd like to upgrade, better rotors, but learned to do Engine Breaking to eliminate that issue for downhill, and airbags. With the bumps tops, any bumps, hit a bit hard. Leaving Arizona in 2 weeks for South Texas, then work my way back to Midwest. Beyond happy with my set up and truck performance. A few funny looks, but hey, Think it's expected with a Tundra Hauling a 37th 1/2 Towable 5th wheel.
  17. Feb 16, 2022 at 5:32 PM
    Kanobi13
    Kanobi13 New Member
    @Rbeard18 How much that bad boy weight? Hitch weight and total between the two? My current set up. 20210606_160034.jpg
  18. Feb 16, 2022 at 5:34 PM
    Rbeard18
    Rbeard18 New Member
    Ricky
    Trailer fully loaded is 9900lbs. Right at Max. DRY is 8300lbs. Get about 7-8.5 mpg, but don't use cruise control, plummets to 5 to 6.
  19. Feb 16, 2022 at 5:36 PM
    Rbeard18
    Rbeard18 New Member
    Ricky
    I do wish I went with Sidewinder pinbox vs autoslide. Really lost use of my bed. But, saves me from helping people move stuff.
  20. Oct 12, 2022 at 5:59 PM
    Rbeard18
    Rbeard18 New Member
    Ricky
    Been a while since last post. Went from Iowa to AZ Fall, Left AZ in Feb for San Antonio TX to St Louis,MO, back to Iowa. Now getting ready to depart and head to CA for winter. Only upgrade/change since last post, dumped the sumosprings and had airbags installed on rear. Fingers crossed for a smoother ride. Can't complain, Tundra has done wonderful hauling the Telluride!
  21. Oct 12, 2022 at 6:22 PM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    Out of curiosity why not upgrade to a 3/4 or 1 ton gasser? Or I guess why did you pick the tundra over an HD truck?
  22. Oct 12, 2022 at 6:26 PM
    koditten
    koditten New Member
    Putting air bags on mine Friday.
  23. Oct 12, 2022 at 6:39 PM
    KNABORES Elitist forum troll
    2000 Limited TRD AC 4X4 Thunder Grey. 2019 Limited TRD CM 4x4 Cement Grey
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Westin bull bar with 20" LED Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers trim and tool box 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter Red tow hooks for that +15 grip bonus
    Dry hitch weight on that 5th wheel greatly exceeds payload for a crew cab Tundra. All the bandaids in the world won’t make that setup safe. You’re over payload, GCVWR, tow rating and likely pushing rear axle weight rating if not grossly exceeding it. And that’s with a DRY weight and not counting the hitch, people and fluid jugs in your truck. Be safe out there man.
  24. Oct 12, 2022 at 9:46 PM
    blenton
    blenton New Member
    This is the way…
    Sounds like fun. Glad to hear the 5er is working out well. And glad to hear you are ditching the sumo’s for air bags! I’ve run bags on mine for several years and with a little bit of fiddling, I can usually dial them in just about perfect for whatever combination of payload/trailer/road I encounter.
    koditten likes this.
  25. Nov 24, 2022 at 5:49 AM
    22whatwedo
    22whatwedo New Member
    Mark
    This all seems like too much work when there are plenty of 2500/3500 capable trucks out the box that were made to do this SAFELY!
  26. Nov 24, 2022 at 7:14 AM
    bfunke
    bfunke New Member
    South Carolina
    2018 Tundra, 2000 Tundra
    My neighbors tows a big horse trailer with a under bed gooseneck using his Gen2 Tundra
  27. Nov 30, 2022 at 8:00 PM
    koditten
    koditten New Member
    Just got done with a mountain run thru east Tennessee.
    These air bags are a game changer!
    The truck runs great dragging a 9k 5,er.
    blenton likes this.
