Tundra payload is under rated
Discussion in '3rd Gen Tundras (2014+)' started by Stumpjumper, Oct 3, 2018.
  1. Oct 3, 2018 at 3:18 AM
    Stumpjumper
    Stumpjumper [OP] New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Based on experience hauling heavy loads I believe that Toyota has built in a significant safety factor. Last Friday I had 31 sacks of corn (1550 lbs), tool box, chainsaw, ice chest, gun, and other misc stuff including myself and everyday gear including floor jack. Probably another 300+ lbs.. Truck was squatting but not significantly.
    equin and dcsleeper408 like this.
  2. Oct 9, 2018 at 11:26 AM
    Diver Dee
    Diver Dee New Member
    DEE
    Gun Barrel city Texas
    2008 and 2019 Tundra
    I haul heavy loads all the time. The 1/2 ton Chevy Z71 I had was a sissy compaired to the last 2 Tundra's that I bought.
    I THINK THE SUSPENSION IS MORE LIKE A 3/4 TON.
  3. Oct 9, 2018 at 12:00 PM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    The amount your truck sags isn't an indication of payload capability. You can put some air bags or beefier springs on to prevent sag - but your payload is still whatever it is on your door sticker. The GAWR and GVWR are still the same.
    The Tundra rear axle is fairly beefy - but it isn't a 3/4 ton axle.
    But, carry on. Ignore safety warnings and ratings and continue overloading your vehicles. :facepalm::frusty:
  4. Oct 9, 2018 at 12:09 PM
    Steve89gt
    Steve89gt New Member
    2018 Limited CM
    De-badged, De-chromed, TRD CAI, TRD Exhaust, Bilstein 5100s, Fuel 18 x 9 wheels, BFG KO2s 275/70/18, ESP Underseat Storage
    I'm not advocating for knowingly overloading one's vehicle, but the Tundra has a 10.5" ring gear (equivalent to Dana 70) in the rear. If that doesn't qualify as heavy duty, I'm not sure what does....just my .02.
  5. Oct 9, 2018 at 12:58 PM
    Atomic City Tundra
    Devin
    New Mexico
    There is more to the rear end than the ring gear.
    Tundra 10.5" rear axle weight rating is 4,150 lbs.
    A Dana 70 weight rating is 7,500 lbs (or higher depending on config).
    As I said, the Tundra rear axle is pretty beefy ..... for a 1/2 ton.
  6. Oct 9, 2018 at 1:08 PM
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    Maybe so... but I think I need some air suspension.
    mike11895, Skey44, RBDTx and 11 others like this.
  7. Oct 9, 2018 at 1:12 PM
    PA452
    PA452 New Member
    2018 Tundra SR5 DB TRD O/R
    Any idea how much weight that might be?
  8. Oct 9, 2018 at 1:13 PM
    Boerseun
    Boerseun Super White
    Ferdie
    Sarasota Florida
    2018 White TRD Sport CrewMax 4x4
    There is no reason why the Tundra can't handle those loads. I am actually surprised that the full size trucks are 1/2 tons and 3/4 tons.
    In other parts of the world Toyota Hilux and Ford Rangers are 1 ton trucks. Maybe the leaf springs are beefed up a little but the chassis, axles etc. are not near what any full size truck in the US is.
    JohnLakeman likes this.
  9. Oct 9, 2018 at 1:59 PM
    GeoJoe
    This is 3 yards of mulch, so I'm thinking ~2000lbs? Pulls fine, just sags a bit. (a lot)
    I got this from this site: http://mulchstoremn.com/faq.html
    "Typically, mulch products weigh between 400-800 lbs. per cubic yard"
  10. Oct 9, 2018 at 2:26 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    :bikewheelie2: how's it steer?
    JohnLakeman, Sunnier, Casper3 and 3 others like this.
  11. Oct 9, 2018 at 2:40 PM
    landphil
    landphil Socially distant and prone to wandering.
    Phil
    BC, Canada
    ‘08 TRD doublecab and ‘01 rockin’ ‘rolla
    Learn the diference between a “full floating” and “semi-floating” axle, and it will make sense. ;)
    BTW, one tons ARE light duty - heavy duty would be 46K lb drive axles. :D Or 69K tri-drive. :rofl:
  12. Oct 9, 2018 at 3:47 PM
    GeoJoe
    Steering was fine, not even noticeable. Seems air would help level my towing too... so probably next mod.
    equin and Watt maker like this.
  13. Oct 9, 2018 at 3:57 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Nice long bed
    WrigglingWilly and OBXTundra like this.
  14. Oct 9, 2018 at 4:05 PM
    GeoJoe
    Hey thanks! Tough to find, even more rare to see a lifted long bed.
    georgiey22 and Alexstundra like this.
  15. Oct 9, 2018 at 4:06 PM
    Professional Hand Model
    Hand Protectors
    Get a 1st Gen. They have a higher ‘Payload Rating’.
    Tundra2 likes this.
  16. Oct 13, 2018 at 7:29 AM
    Diver Dee
    DEE
    Air bags are inexpensive and easy to install to help level the truck. As long as you don't go crazy with the load.
    I HAVE AN '08 that I load the bed full of camping gear and then hook up a 26 ft. RV AND drive 620 miles each way
    To Terlingua ranch in south Texas. Been doing it for 9 years with no problems at all. I kept the '08 and just bought
    A 2019. Heading out again in November with the new one. Only thing I'm not sure about is the integrated transmission
    coolers on the new Tundra vs. the cooler bolted to the front of the radiator on my '08.
    equin likes this.
  17. Oct 13, 2018 at 12:44 PM
    PMG
    PMG New Member
    Hey, nice S30. Have anymore info, pics, build thread on her?
  18. Jun 12, 2019 at 10:54 AM
    TundraTRD5300
    TundraTRD5300 New Member
    2017 Tundra TRD
    2inch Leveling Kit
    I'm curious after hauling all that mulch, have you noticed your bed drop slightly in height? I recently hauled about 1200lbs of flooring with my 2017 Tundra TRD and I noticed a slight drop in height in my bed. Especially towards the tailgate. No one else notices, but since I drive it everyday, I can tell. On a quarter of a tank, I've measured from the ground to the top of the wheel well of the bed. Driver's side is about 39 1/2". Passenger side is about 39". Two Toyota shops says that it's within standards, but I'm wondering if they don't want to do the work to fix it since it's still under warranty? These are the same guys that think that a slight leak (they called it seaping) in the rear differential is normal and just tightened the bolts. Thanks!
  19. Jun 12, 2019 at 12:07 PM
    ColoradoTJ O'Keefe Music Foundation Staff Member
    GMC 3500
    Usually the “Toyota Lean” is on the drivers side ~1/2 inch.
    Things to look for:
    Flattened springs
    Damage to other suspension components
    Frame damage (highly doubt that)
    Coolhardy likes this.
  20. Jun 12, 2019 at 12:36 PM
    TundraTRD5300
    2017 Tundra TRD
    2inch Leveling Kit
    Thank you! I'll check for that!
  21. Jun 12, 2019 at 2:13 PM
    Batel
    Batel New Member
    2019 Tundra SR5 TRD Offroad
    What landphil said! Half tons are all semi floating, thankfully we don't have c-clips holding the axle in. I see those around these parts fail when our local firewood guys overload their truck and the c-clip breaks and lets the axle and wheel out of the housing. Or the axle just shears at the wheel and the driver breaks out in a refrain of "You picked a fine time to leave me loose wheel". If I need to haul in excess of payload capacity for the truck I will hook up to a trailer. If I ever need to haul large loads again it will say Kenworth on the hood. Or maybe Pete.
    Hbjeff and Atomic City Tundra like this.
  22. Jun 12, 2019 at 2:40 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Amount of sag does indicate how well the vehicle will handle. Start taking too much weight off the front tires and handling degrades I'm a hurry. I don't care what the door sticker says as long as my truck still handles well
  23. Jun 12, 2019 at 2:49 PM
    Atomic City Tundra
    Devin
    New Mexico
    How well your truck handles is very subjective. You might think it handles well - others may not.
    I love how so many think that they know better than the people that designed the damn truck when it comes to weight ratings. As I said before - carry on and ignore the ratings. Effing frustrating.
    Best of luck.
  24. Jun 12, 2019 at 3:15 PM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Either airbags, Timbrens or SumoSprings will help with the sag and improve rear handling while under heavy loads or towing but you should never overload your truck.
    GlobalGuy and Hondoman like this.
  25. Jun 12, 2019 at 4:19 PM
    texasrho83
    texasrho83 Teacher in a Tundra
    Charles
    Conroe TX
    2016 DC MGM 4x4
    I've done a little..
    That’s pretty much what I’ve always wanted Tundra-wise. Did you special order from the local dealer?
  26. Jun 12, 2019 at 5:39 PM
    Rider0120
    Rider0120 New Member
    Bucks County, Pa
    2018 White double cab SR 4x4 long bed
    Ranch Hand full replacement bumper
    Yup let them get jammed up with DOT or sued then it will get threw thick heads
  27. Jun 12, 2019 at 6:45 PM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    I believe that the ratings are there to cover the worst case scenarios. If you exceed the load or towing capacity and never experience an emergency stop, an unexpected large pothole, or one of many other driving hazards, you are likely fine, but those unexpected things do happen sometimes.
  28. Jun 12, 2019 at 7:08 PM
    tAcomaPueblo
    tAcomaPueblo New Member
    Keep in mind what those regulations say. Its no different than expiration dates on food. That was literally just in the news about the required dates have little to do with how long the food will last. Regulations numbers are regulations numbers, not based on some logical real world testing.
    I still completely agree I would never go past what the number says mostly so I wont be liable and I can always blame someone else if something goes wrong. But to think those numbers are a reflection of actual truck capabilities is laughable.
  29. Jun 12, 2019 at 7:50 PM
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
    Personally, I installed the Sumo Springs (far less hassle than airbags, etc), which really smoothed out my trailer towing (bounce, etc). However, I still stay within the vehicle's load specifications.
    GlobalGuy likes this.
  30. Jun 12, 2019 at 8:24 PM
    Atomic City Tundra
    Devin
    New Mexico
    They are called factors of safety. Engineers use them to help prevent the unexpected. Manufacturing defects, changes in material quality, assembly errors, blah, blah, blah, blah. So you are correct - the truck can "handle" more than the advertised or rated load. That is how they design it. With a (sometimes large) factor of safety built in. That keeps things safe. That keeps people from dying. You never know when you might have something go wrong a steel processing plant that creates abnormalities in grain sizes, excess precipitates or contaminants, heat treatment errors, etc - that causes a relatively serious degradation in the strength of the material. You never know when a welding process might suffer some type of systemic issue that allows some seams to go through with weaker properties. Etc, etc, etc. They test these things regularly and do catch a lot of things that come up with processing. But, they don't test all of them, and they don't catch all of them. I have worked in industry as a Mechanical Engineer in a production environment - things slip by from time to time. Recalls happen, but still.... That is one of the reasons factors of safety are built into the design. Because people and processes fuck up.
    Sorry, this shit pisses me off to no end. I get ridiculed and laughed at sometimes for it. "The weight police". Usually it is by people that have no clue about any of the physics or Engineering involved in the design process. The factors of safety are there for a reason. Why fuck with them?
    I should stop posting to this and other similar topics. It doesn't do any good. People will continue to overload their vehicles (sometimes grossly) because it "handles well" to them - or because they think that their mighty Tundra is really a 3/4 ton truck in disguise - or because they are only driving for a few miles on back country roads at 25 under the speed limit. I'll continue to keep my eye out for them and do my best to avoid them.
