Tundra DC vs CM?
Discussion in 'General Tundra Discussion' started by Nevada girl, Jun 7, 2019.
  1. Jun 7, 2019 at 4:02 PM
    Nevada girl
    Nevada girl [OP] New Member
    Teri
    2013 Tundra DC
    What is needed for towing?
    I love my Tundra... but have had some issues with parking. (I’m a nurse and hospital parking is tight)
    Is the Crewmax easier to park? Does it have a shorter wheel base making it easier to turn.
    I also need to pull a horse trailer.. which is equipped better for towing?
    Thanks in advance!
  2. Jun 7, 2019 at 4:10 PM
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    2019 Tundra CM Super White
    wheels/tires suspension protection
    its the same exact truck.
    Do you want more bed or less bed?
    More room in the back of the cab or less room in the back of the cab.
    Tundyfundy, TXDrifter and Black Wolf like this.
  3. Jun 7, 2019 at 4:34 PM
    Nevada girl
    Teri
    2013 Tundra DC
    I was told that the wheel base is different... not true? Are they the same length (DC with 6’5” bed & CM with 5’5” bed)
  4. Jun 7, 2019 at 4:39 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Nope. Same wheelbase. Only difference is the DC just looks way better.
  5. Jun 7, 2019 at 5:25 PM
    Welcome from NY.
    I love my double cab.
    Do you need more cargo space or interior space?
    Double cab for more cargo space.
    Crew max for more interior space.
  6. Jun 7, 2019 at 5:27 PM
    Blueknights75
    Ron
    Clayton, NC
    Or a crew max with a tailgate extender and you have the best of both trucks...
    Patch999, YeeYeeTundra and Fishman57 like this.
  7. Jun 7, 2019 at 5:40 PM
    TRDZ28
    TRDZ28 New Member
    Southern California
    2014 Tundra TRD 4X4 BRM
    Do you back in or face into parking spots?
    And more useful. I feel like the back seat is roomy. Not a limo but comparable to most suvs or full size sedans.
  8. Jun 7, 2019 at 5:47 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Then you need a bed extender. You also get strangely proportioned rear doors. The rear doors look bigger than the front. Makes it look like a minivan.
    Tundyfundy likes this.
  9. Jun 7, 2019 at 5:50 PM
    TRDZ28
    TRDZ28 New Member
    Southern California
    Do you not worry about having things bouncing up and damaging your tailgate while it's down and driving?
  10. Jun 7, 2019 at 6:38 PM
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    Same width too. I came from a DC to a CM. The only difference is leg room in the back as far as the cab goes. Even then there’s still plenty of leg room any way.
  11. Jun 7, 2019 at 6:46 PM
    pigweed61
    pigweed61 New Member
    Austin, TX
    2014 Grey 1794
    This was a point I was going to make. If you back into the parking space, you're taking advantage of swinging the front around as you back into the spot. Like an outboard motor boat.
  12. Jun 7, 2019 at 6:59 PM
    Wutachampion
    Wutachampion New Member
    DFW
    used to own - 2016 MGM SR5 CM Texas Edition
    Both are equally difficult to park going forward. I recommend backing in if possible.
  13. Jun 7, 2019 at 7:19 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    :burnrubber:
    rebmo, Tundyfundy and joonbug[QUOTED] like this.
  14. Jun 7, 2019 at 7:21 PM
    Aurora CO
    ....or a bed extender on a DC and be best...
  15. Jun 7, 2019 at 7:42 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    After reading all this I'm confused. Do you want a longer truck? A longer bed? A shorter truck? A shorter a bed? Queen bed? Bunk beds?
    I'm going to bed. Good night.
    Tundyfundy and Black Wolf like this.
  16. Jun 8, 2019 at 6:59 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    40 plus hours a week ! Tight parking lot ? Buy a box car for daily driving !
    YeeYeeTundra and Black Wolf like this.
  17. Jun 9, 2019 at 10:57 AM
    gdisarray
    gdisarray Short term member
    MGM SR5 TSS
    ??Huh??
    YeeYeeTundra likes this.
  18. Jun 9, 2019 at 11:29 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    To further add to your dilemma, DCs weigh less but have the potential to get slightly better mileage. CMs weigh more, probably get slightly worse mileage, but won't be pushed around as much by no steenking horse trailer. So, what's it gonna be, girl?...DC or CM? :D
    And, oh yeah, DCs do look better. :thumbsup:
    Trooper2 likes this.
  19. Jun 9, 2019 at 2:10 PM
    Nevada girl
    Teri
    2013 Tundra DC
    Thank you everyone! I guess I will stick to my DC Tundra as there seems to be no advantage for me to get a CM Tundra. I rarely use the back seat... I like the 6’5” bed... so I better learn how to park and drive what I have! I’m going to start backing in to my parking spaces.. maybe it will even put the outside wear on my tires.. lol
    gosolo likes this.
  20. Jun 9, 2019 at 2:11 PM
    Nevada girl
    Teri
    2013 Tundra DC
    “Out”
  21. Jun 10, 2019 at 1:26 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    DC also has a higher tow/cargo capacity! That extra foot of cab space weighs a bunch!
    YeeYeeTundra and JohnLakeman like this.
  22. Jun 10, 2019 at 6:36 PM
    Nevada girl
    Teri
    2013 Tundra DC
    Thank you. I pull a horse trailer
  23. Jun 10, 2019 at 6:49 PM
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    Agreed... But everyone who thinks a DC looks better isn't getting an invite to the dance party I'm having in the back of my CM! There's so much room in there for my kids (one with two legs/one 88lb'er with 4 legs AND the wife can still lay the seat back go sleep - as the kids say nowaday #winning)
  24. Jun 10, 2019 at 7:02 PM
    Blueknights75
    Ron
    Clayton, NC
    Plus we have a power window....just sayin..:poking:
    Tundyfundy and gdisarray like this.
  25. Jun 10, 2019 at 7:21 PM
    Tundyfundy
    Bay Area, CA
    I know that is an awesome space!!theres a tundra for everyone!
