Tundra 4.6 Long Tubes
Discussion in '2nd Gen Tundras (2007-2013)' started by mopanda265, Aug 21, 2019.
  1. Aug 21, 2019 at 10:42 PM
    mopanda265
    mopanda265 [OP] New Member
    2013 4.6 Tundra 2x4
    Hello fellow 4.6 tundra and all tundra owners. :)
    I have recently installed Long Tubes for my 13 Tundra 4.6 Long Tubes that I purchased from DirtyDeeds. I know this isn't a common install for the 4.6 guys so for anyone that is interested in installing these, here are some tips and lessons that I learned. I have a 2x4 so I don't know how its like to install on a 4x4.
    Total install time: ~16 hours.
    For the most part follow DirtyDeed's instructions for the 5.7 up to removing the stock headers.
    Both Sides,
    remove the heat shields for more clearance.
    Drivers side,
    stick a jack under the engine to remove the engine mount. I took off the bracket and the mount itself. it slips on way easier. when installing the mount and bracket back on, it will be a tight fit for but it is do able. There wont be a lot of space to tighten up the nut that secures the mount to the engine. it takes a while to slowly screw it on with the open side of wrench. just take your time.
    Passengers side.
    when you remove the stock headers the stud pattern isn't the same as the 5.7 so youll have move the two middle studs ( one on top and one on the bottom) one hole over. youll see what i mean if put the gasket on.
    remove the dip stick tube when sliding the tubes on. Before you install the long tubes, install the dip stick back in above the motor mount. i made the mistake of installing this last. i had to straighten it and bend it back to install it.
    again with the jack under the motor, remove the nut for clearance. i had to wiggle the long tubes into place. i didn't have to use a hammer at all. it is a very tight fit at first but keep wiggle it in. the secondary air tubes will get stuck so use some force to the stud in the hole.
    unbolt the transmission line, the rubber hoes will be touching the long tubes. get a insulation sleeve is it doesn't cook the rubber line.
    again the engine mount nut will be hard to install, so take your time.
    the o2 sensors are the same. as before. Just measure before you tighten them down.
    get the gaskets from auto zone, i just went to some muffler shop around the corner to get some.
    why did i install these. my truck is paid off and i don't want another car payment for a 5.7.
    Yes the truck now pulls harder. its a noticeable difference.
    I used a lot of different type of 12mm wrenches and sockets. long, short, deep. be patient. Its doable.
    Im still missing around with the v bands, i have a slight exhaust leak by the cats.
    This is just my 2 cent. ill post some pictures when i get a chance.
    Silverghost, Rex Kramer and Brian0414 like this.
  2. Aug 22, 2019 at 7:38 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    :worthless:
    14burrito likes this.
  3. Aug 22, 2019 at 7:41 AM
    Brian0414
    Brian0414 Doomsday
    Tucson, AZ
    2017 Tundra Limited 4x4
    - Winjet Black/Smoke Fiber Optic LED Tail Lights Bilstein 5100
  4. Aug 27, 2019 at 10:17 PM
    mopanda265
    2013 4.6 Tundra 2x4
    Here are some pictures after I installed the exhaust.
    I didn't take any before pictures :/ sorry guys
    YES! I know these are some shitty pictures, feel free to laugh. if yall want a specific angle please let me know.
    the second to last image was the transmission line that I was taking about. as you can see here, I just got some heat wrap and zip tied it on there.
    Silverghost, Brian0414 and YardBird like this.
  5. Aug 28, 2019 at 8:28 AM
    Brian0414
    Brian0414 Doomsday
    Tucson, AZ
  6. Aug 28, 2019 at 3:30 PM
    mopanda265
    2013 4.6 Tundra 2x4
    i cant wait to finish this up with a cat back
    Silverghost likes this.
  7. Nov 24, 2019 at 1:28 PM
    4Phoebes
    4Phoebes New Member
    Stacey
    2010 4.6 Tundra
    Anyone have info on R&R on 4.6 engine?
  8. Dec 10, 2019 at 9:21 AM
    kevinthrw
    kevinthrw New Member
    Kevin
    2017 Toyota Tundra 4.6L Double Cab
    What kind of gains did you get from these long tubes? Was this long tubes with mids and your cats installed?
