TSS Wheels / lift help
Discussion in 'Wheels & Tires' started by Blazin_Blue16, Dec 6, 2017.
  1. Dec 6, 2017 at 2:57 AM
    Blazin_Blue16
    Blazin_Blue16 [OP] Huh??
    Mark
    Wells, Maine
    2016 Limited CM Blazin' Blue Pearl
    Hey guys! Looking for some knowledge. I see a few people on here have got the new TSS wheels, and I think I need me a set! I just watched a YouTube video of an 18 TSS that has a setup that I would like to put on my 16 limited CM.
    Ideally I'd like to put these tires, BFG KO2's, but in 305/55/20 (33.2 x 12) on my CM. I don't have a lift/level yet, only due to the fact I hadnt found the wheel and tire package I wanted until I came across these. I think it's going to be the setup I go with.
    That brings the question.. where can I find these TSS wheels in (20 x 9) and at what offset will I need to stuff the 305/55's under it? (Is it even available in an offset that will work?) I can add flares if need be. To fit the 305/55s I will most likely just go with a 3/1 level. I've been thinking a full ToyTec boss kit... But I feel that's over kill for my relatively "normal" driving style, if a 3/1 isn't going to blow my alignments/angles, I'll take the cheaper route. Budget is a considered factor, but the money's there if it really needs to be. I won't do the CMC, and I'm only looking for a subtle lifted look.
    Any help is greatly appreciated!
    This is the screen shot of the setup i saw on YouTube ..
  2. Dec 6, 2017 at 10:20 AM
    Blazin_Blue16
    Mark
    Wells, Maine
    Had some time on lunch break... Found the TSS wheels on TRDparts4u. They are 20x9 with a +50mm offset. Also priced out the Ultimate Lift with Bilstein 5100's so that will give me the 3/1.5 lift I'm looking for.
    Would it be prudent of me to replace the UCA's? And the +50mm offset has me wondering how much clearance I'm going to have with a 305/55 from the UCA as well.
    Thoughts?!
    Thanks!
  3. Dec 6, 2017 at 10:29 AM
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    Welcome from CO. I don't think you need to replace the UCAs unless you go over a 3". There have been a few folks who have sold their TSS 20" rims in the past on Tundras.com. Maybe check Craigslist if you are okay with used.
  4. Dec 6, 2017 at 11:10 AM
    SleeperTRDPro
    SleeperTRDPro The small package good things come in
    Austin, Texas
    I have the TSS wheels on my '16 with the TRD Pro suspension, 305/55R20 Nitto Ridge Grapplers would not clear my UCA without a Wheel spacer so I went with the 295/55R20's instead.
  5. Dec 6, 2017 at 12:28 PM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    yup, 305's will rub on a 20x9 wheel with a +50mm offset.
    I have 295's on the same size wheel and there is a pinky width of clearance to the UCA:
  6. Dec 6, 2017 at 1:32 PM
    Blazin_Blue16
    Mark
    Wells, Maine
    Thanks for the input guys... Looks like I'm going to have to find another wheel option for my BFG's then! Would around a +20mm offset should get me there?
    Thanks!!
  7. Dec 6, 2017 at 2:43 PM
    Netmonkey
    Georgetown, TX
    Yes, +20mm offset will allow 305's to clear the UCA. However, with the wheels pushed out farther, you will have to trim more stuff. If you can get between +25 to +35 offset then you will trim less stuff and still clear the UCA.
  8. Feb 5, 2019 at 6:18 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    So 295 doesn’t rub? Or how do you like them? I have a 2016 SR5 Crewmax with the TSS package 20” rims (285/55/20). Next week getting the Bilsteins 5100 2.5” for front only. It was recommended by my local off road company that does lifts & levels. I’m still trying to figure if i could go taller....or would i need to purchase all different wheels?
