Trying to figure out this audio issue
Discussion in 'Audio & Video' started by Thattundradude, Jun 26, 2018.
  1. Jun 26, 2018 at 7:00 PM
    Thattundradude
    Thattundradude [OP] New Member
    Platinum Tundra
    Lifted
    Hi all. I'm trying to figure out what system might have been installed in my tundra. Previous owner took out all his speakers and amps or whatever was installed. Anyone know what i can do the wires look like a mess. 20180626_124031.jpg 20180626_123917.jpg 20180626_124031.jpg 20180626_123917.jpg 20180626_124003.jpg 20180626_123932.jpg 20180626_124035.jpg
  2. Jun 26, 2018 at 7:04 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    That sucks...
    I hate when people do that when getting rid of a vehicle. I had to completely rewire all the audio in my 240sx because the PO did something similar.
    Hopefully a wiring guru will chime in on this one. :thumbsup:
    GNTundra likes this.
  3. Jun 26, 2018 at 7:05 PM
    Thattundradude
    Platinum Tundra
    Lifted
    I bought the tesla style radio unit a month ago, was going to install it but its missing i wanna say all the speakers by the looks of it.
  4. Jun 26, 2018 at 7:07 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Those Tesla style radios are pretty sweet.
    The speakers that were in there must've been decent considering the cut and run removal!
  5. Jun 26, 2018 at 7:24 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I bet someone here has all their stereo stuff after swapping it out. Although this is a good time for a full system build
    B737 and GNTundra like this.
  6. Jun 26, 2018 at 7:49 PM
    Thattundradude
    Platinum Tundra
    Lifted
    Btw this has the JBL or had the JBL speakers and stuff
  7. Jun 26, 2018 at 10:17 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    I installed the Android radio.. and now have an extra JBL radio from a 2017 Tundra.. interested?
    Thattundradude[OP] and GNTundra like this.
  8. Jun 27, 2018 at 6:36 AM
    Thattundradude
    Platinum Tundra
    Lifted
    How much
  9. Jun 27, 2018 at 6:50 AM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    Shipping from Cali. It comes attached with the square bezel that was also replaced there.
  10. Jun 27, 2018 at 7:02 AM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    Looks like you might have the original connecters for the back. Might just need to replace some wires and speakers.
  11. Jun 27, 2018 at 7:04 AM
    Pudge
    CT
    I have a suspicion that the wires for headunit and hopefully the amp are there, but after that I bet the previous owner ran all new speak wire. If that's the case the OP will likely be better off running an aftermarket head unit and amp with new wire to new speakers.
    B737 and 831Tun like this.
  12. Jun 27, 2018 at 7:06 AM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    I hear you, just offering to someone that may need it.
    Pudge[QUOTED] likes this.
  13. Jun 27, 2018 at 7:13 AM
    Pudge
    CT
    Oh man I totally wasn't knocking your post at all. Sorry if it sounded like that
    TFT[QUOTED] likes this.
  14. Jun 27, 2018 at 7:50 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Wow, what a hot mess. This is sad to see.
    Are you going to go aftermarket, or try to replace with oem components? I would get some picture of the wiring behind where the head unit was, and pull that clump of wires under the carpet out, and lets see what we're working with.
  15. Jun 27, 2018 at 9:30 AM
    Thattundradude
    Platinum Tundra
    Lifted
    I have a Phoenix android unit that I wanted to install. It looks like all the connections that were with the aftermarket head unit are still connected
  16. Jun 27, 2018 at 9:41 AM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    That's good that the harness is intact, maybe if you swing into a junkyard you can grab a factory amp from another truck and just cut the wires (long) rather than unplugging it so you can match them color-to-color.
    The door speakers should be easy to figure out because there should only be 2 wires to each speaker.
  17. Jun 27, 2018 at 10:21 AM
    Ryooo
    Ryooo New Member
    Boynton Beach FL
    2014 CM SC Platinum
    TRD Supercharger 4.5 BDS lift 20” Method Standards sitting on 35 Nitto Grapplers Rigid grill top and bottom with lights AMP running boards Fender flares Magnum rear bumper Rear LED bar Air bags with onboard compressor Brake controller Alpine Navi Alpine amps x 2 Focal Separates front and rear 2 x JL 13s in a stealth box behind the back seat LTE cellular booster Rear seat under locked storage Dynamat from ceiling to floor LEDs all over Bed liner Bed rails Paint protector covering nearly the entire front end and more
    I’m selling a factory Navi/stereo and factory amp from a 2014 platinum. Haven’t even listed them yet. Shoot me a message if your interested
  18. Jun 27, 2018 at 10:22 AM
    Ryooo
    Ryooo New Member
    Boynton Beach FL
    2014 CM SC Platinum
    I even have a set of factory 6x9 s also
  19. Jun 27, 2018 at 7:53 PM
    Thattundradude
    Platinum Tundra
    Lifted
    How much for the head unit? If I don't like the android unit I'll sell it and buy yours
  20. Jun 27, 2018 at 7:55 PM
    Thattundradude
    Platinum Tundra
    Lifted
    Might just take it to a stero shop it's a nightmare with wires. Anyone know what amp is good that I can install? Also, are the speakers in the back seat in the factory one too?
  21. Jun 27, 2018 at 9:12 PM
    Ryooo
    Ryooo New Member
    Boynton Beach FL
    2014 CM SC Platinum
    I haven’t quite figured that out yet, if you have a number you think is fair let me know...
    In your situation it may be better to just go aftermarket since everything was already upgraded (and gutted)
    I worked in car audio for quite some time, I recommend a 4 channel amp, Alpine, JL, ADS are my top choices, second would be Pioneer, Sony or Kenwood.
    You may consider a 5 channel and drop a sub behind your seat... or you could do a 4 channel and a mono block for the sub.
    Hit me up if you have questions
  22. Jun 27, 2018 at 9:22 PM
    Thattundradude
    Platinum Tundra
    Lifted
    Isn't there a speaker that can be mounted on the back part of the seats? I saw it on ********* or something.
  23. Jun 28, 2018 at 11:39 AM
    Ryooo
    Ryooo New Member
    Boynton Beach FL
    2014 CM SC Platinum
    Yes, the factory has a sub behind the seat or you can get a JL Audio Stealth box. I have the oem sub box out of mine
  24. Jun 30, 2018 at 7:36 PM
    Thattundradude
    Platinum Tundra
    Lifted
    The stealth box is pretty expensive. What if I get a subwoofer box and add speakers?
  25. Jun 30, 2018 at 9:50 PM
    Danimal86
    Daniel
    Sacramento, CA
    The stealthbox is amazing, but expensive.
    email James at tech12volts, he will set you up. You can get the same speakers in a custom box for a couple hundred bucks less
    Ryooo likes this.
  26. Jul 1, 2018 at 5:49 AM
    treihing
    treihing MAGA
    TR
    Washington State
    2018 Black Limited CrewMax
    Wow OP, the dude you bought they truck from really shredded the wiring. Take it to a good audio shop and get it re-wired. Do not let them splice and dice. Get new wiring so you have no audio/connectivity issues. It will cost you but you will be happier in the long run.
  27. Jul 5, 2018 at 8:04 AM
    Thattundradude
    Platinum Tundra
    Lifted
    Yeah I'm just going to take it to a shop. Whoever owned the truck before should've at least put the old stuff back.
  28. Jul 6, 2018 at 6:25 PM
    Thattundradude
    Platinum Tundra
    Lifted
  29. Jul 6, 2018 at 6:58 PM
    Danimal86
    Daniel
    Sacramento, CA
    Better off not using the dash tweeters and just run a 1" tweeter in the sail panel
  30. Jul 12, 2018 at 9:05 PM
    Thattundradude
    Platinum Tundra
    Lifted
    Anyone got a jbl amp for sale?
