True or False? TSS Package option
Discussion in 'General Tundra Discussion' started by CavBlueTexan, Oct 11, 2018.
  1. Oct 11, 2018 at 11:19 AM
    CavBlueTexan
    CavBlueTexan [OP] New Member
    Justin
    Tyler Texas
    2019 TRD Sport 4X4 Crew Max
    A salesman at a dealership just told me that the Tundra with the TSS package, 4WD comes standard with a 2.5" front leveling kit. Is this true?
  2. Oct 11, 2018 at 12:24 PM
    15whtrd
    15whtrd Mr. Blonde
    False. Unless that particular dealer installs one on that package. Even then it’s probably a spacer lift.
    The TRD Pro is the only Tundra to come factory with a leveled suspension lift in the front.
  3. Oct 11, 2018 at 12:30 PM
    CavBlueTexan
    Justin
    Tyler Texas
    I thought it sounded fishy. Thanks for the response!
    15whtrd likes this.
  4. Oct 11, 2018 at 12:33 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Either that or they fail to realize there’s a TRD Pro on their lot listed as “standard”. If that’s the case buy it haha
    Blueknights75 and 15whtrd like this.
  5. Oct 11, 2018 at 12:38 PM
    CavBlueTexan
    Justin
    Tyler Texas
    Wouldn't hesitate for a second!
    15whtrd likes this.
  6. Oct 11, 2018 at 1:24 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Most (if not all) TSS I see look leveled. I will have to look for one that is not. Was thinking that it was part of the package. :notsure:
  7. Oct 11, 2018 at 1:46 PM
    KnuckleHD
    I guess it depends on what TSS he is talking about. Toyota Safety Sense package or the TSS aftermarket package that is available in the southwest region.
  8. Oct 11, 2018 at 1:47 PM
    fatalkhaos
    fatalkhaos New Member
    2019 Tundra TRD PRO CM
    Sway Bar 20x10 Fuel Assault 295/55r20 Toyo AT
    I have quickly found out that in both cases of buying a Tundra... I knew way more than the sales guy or girl.
  9. Oct 11, 2018 at 2:19 PM
    CavBlueTexan
    Justin
    Tyler Texas
    Sorry, I should have clarified.... yes, I am referring to the TSS aftermarket package that is available in the southwest region.
  10. Oct 11, 2018 at 2:35 PM
    fatalkhaos
    They do not come stock that way. It may be a dealer add on or even something they do at port.
  11. Oct 11, 2018 at 2:47 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Not lifted, Gulf States Region only package, waste of money IMO. Local dealer stocks nothing but TSS will even lift them (spacer) and add aftermarket wheels and tires without deducting the wheels and tires they took off. I've seen them there as high as $52k. Only available in SR5 tires are KO2
    Screenshot_20181011-164954_Samsung%20Int_1b1b140bac1cd70fec95c928b0412c72e50ff628.jpg
    KnuckleHD likes this.
  12. Oct 11, 2018 at 2:51 PM
    fatalkhaos
    Similar to the XP XPS and XPSX here in the Southeast
  13. Oct 11, 2018 at 3:31 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    My 2015 tss was not leveled from the factory.
  14. Oct 11, 2018 at 4:10 PM
    Rngr188
    Chad
    Harrison AR
    So right after posting I left the house and saw this example. Not to be critical but for a $5k package this guy replaced his wheels and tires leaving only black badges, a decal, and an exhaust tip. He could have bought a SR5, his spacer lift, wheels/tires, flares, and bull bar and probably been close to that $5k appearance package.
  15. Oct 11, 2018 at 4:32 PM
    fatalkhaos
    In Cali they are notorious for sending SR5 models to DSI putting amp running boards 35s with 6 inch lift and some LRG rims and adding 9999 to the price tag. I just laughed. They did one and put a wrap on it to make it matte black and just sitting on the dealership in Palm Springs the wrap was peeling at the seams but they wanted almost 20k extra.
  16. Oct 11, 2018 at 4:40 PM
    Rngr188
    Chad
    Harrison AR
    This guy bought the truck and did the mods himself to a truck with a $5k appearance package only to remove the majority of it. To each his own.
