Truck won't read for inspection
Discussion in 'General Tundra Discussion' started by josh3509, Jun 24, 2017.
  1. Jun 24, 2017 at 10:44 AM
    josh3509
    josh3509 [OP] New Member
    Josh
    2007 Tundra SR5 double cab
    Hey guys,
    I have an 07 Tundra and I just got back from two different places that tired to read the code on my truck so I can pass inspection. They said it goes through just fine until the end and then it will not complete or read past this point. Does anyone have a suggestion as to why this is happening? They said it could be anything from replacing that plug where the reader goes into or possibly the OBD fuse but all the fuses are good. I would appreciate any input. Thanks!
  2. Jun 24, 2017 at 11:50 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Welcome from Western NC!
    I do not know the answer to your question, but another member on here might.
    josh3509[OP] likes this.
  3. Jun 24, 2017 at 1:35 PM
    Mike Tread lightly.
    south carolina
    You might be getting (odb2 not ready) from the ECM?
    If you are just drive it around and it will go OBD2 ready mode so you can pass emissions.
    15whtrd likes this.
  4. Jun 25, 2017 at 6:54 AM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    welcome.. are you throwing any engine codes? Try your own obd2 reader and see if you can reset the ecm..make sure battery poles are clean of build up or corrosion, same thing with the ground bolts at frame, check voltage at battery with truck, it should be at 14 volts. If all above checked ok then unplug the battery for a few hours this should make everything loose all charges plug it back in..this will force the ecm to reset it self. If there's a code that it should've thrown before and didn't it will now..unless you have a bad ecm very seldom happens..
  5. Jun 25, 2017 at 6:54 AM
    xj2202009
    x
    Lutz, Fl
    If none of above worked..move to FL we don't have state inspections
  6. Jun 25, 2017 at 9:26 AM
    NO INSPECTIONS...
    TheBeast likes this.
  7. Jun 25, 2017 at 9:45 AM
    xj2202009
    x
    Lutz, Fl
    We did away with them back in 98 or 99
