Truck not starting, though battery seems like it's fine
Discussion in '2.5 Gen Tundras (2014-2021)' started by jquincy, Jan 11, 2020.
  1. Jan 11, 2020 at 7:40 AM
    jquincy
    jquincy [OP] New Member
    Austin, TX
    2018 Tundra CrewMax
    2.5 Fox DSCs (Front + Rear), Icon RXT Leafs, Icon DJ Billet UCAs
    Hey y'all-
    I need some help diagnosing a problem. So I've got a 2018 Tundra that wouldn't start this morning though the battery seemed fine (headlights, dash, interior lights, etc are all working). I turn the ignition and nothing really seems to happen except for a "zzzzzzz" sound from the engine (not a clicking sound). I did notice the past 2 days that it took a bit longer for the truck to start but I brushed it off to colder weather. Any ideas on what may be wrong or things I should check before I get it towed to the shop?
    Potentially Relevant Info:
    Year: 2018
    Engine: 5.7L V8
    Mileage: ~43,000
    Notes: I just drove up from TX to VA (~1,500 mi) last weekend
    Any help here would be greatly appreciated!
    UPDATE: It was indeed the battery. Thanks for all your help guys!
  2. Jan 11, 2020 at 7:46 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    You've probably got a dead cell (loss of conductivity) in the battery. Your 2018 is past due for a new battery based on poll data. Disconnect the battery and attach a voltmeter across the terminals. Your battery should have at least 12.6V. If the voltage is less than that, you can attempt to slow charge the battery. After charging, measure your voltage again after a hour or so with the charger off. If the battery has not charged to 12.6V or higher voltage, have the battery tested.
    texasrho83, AZBoatHauler and r4z0r51o like this.
  3. Jan 11, 2020 at 7:57 AM
    JohnLakeman
    Once you confirm the battery is good, i.e. fully-charged and retains full-charge, you can move on to other possible issues. A dead cell or loss of conductivity is characterized by substantial loss of cranking amps and failure to hold charge. The buzz instead of clicking may say nothing beyond the battery is so discharged, it will not even actuate the starter solenoid.
    r4z0r51o likes this.
  4. Jan 11, 2020 at 8:07 AM
    jquincy
    Austin, TX
    2018 Tundra CrewMax
    Ah gotcha- I'll test the battery and hopefully that fixes things. Thanks for your advice- I'll let you know how it goes.
    JohnLakeman likes this.
  5. Jan 11, 2020 at 9:18 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If it ain't the battery, take it to the dealer and let them mess with it.
  6. Jan 11, 2020 at 9:23 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  7. Jan 11, 2020 at 9:34 AM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    Agreed. More than likely it’s the battery.
  8. Jan 11, 2020 at 9:38 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    another vote for week battery
  9. Jan 11, 2020 at 2:14 PM
    jquincy
    Austin, TX
    2018 Tundra CrewMax
    Yup- y'all were exactly right. It was the battery. Went to AutoZone and got it taken care of. Thanks for your help guys!
  10. Jan 11, 2020 at 2:48 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Battery
  11. Jan 11, 2020 at 3:48 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Another crappy Toyota battery bites the dust. Once they start cranking slow but still start it is time to head to parts store. Both Tacomas gave me that warning but not the Tundra.
  12. Jan 11, 2020 at 3:51 PM
    Tiamat
    Tiamat New Member
    I just purchased a factory 84 month Toyota battery after my 2015 oem started to produce slow start.
    Had no is idea of the quality problems. I
  13. Jan 11, 2020 at 4:22 PM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    Always buy the best Battery and Tires you can find.
    Tiamat likes this.
  14. Jan 11, 2020 at 4:26 PM
    Tiamat
    Tiamat New Member
    Michelins have been outstanding.
  15. Jan 11, 2020 at 5:33 PM
    truefunk
    truefunk New Member
    2020 Cement SR5
    Battery cell dead
  16. Jan 12, 2020 at 5:34 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Great street tires but not aggressive enough for my needs
