Truck dies right after auto start? 2020 tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundyFromDownUndy, May 31, 2023.
  1. May 31, 2023 at 5:52 AM
    TundyFromDownUndy
    TundyFromDownUndy [OP] New Member
    2020 Platinum Tundra
    I have auto start in my 2020 plat tundra and like 4 months ago it started doing this thing where I auto start it, and then it fires up and 2 seconds later shuts off. And automatically tries to start again, which is does and stays in for 2 seconds and shuts off. Then my clicker does a non typical beep in succession. . . Haven't had much time to diagnose it so I just haven't been using the auto start. Not sure where to go from here. Hope someone has some insight! Thanks
  2. May 31, 2023 at 6:41 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Same time happening as the horn is blasting?
    Are you on your factory battery still?
  3. May 31, 2023 at 6:50 AM
    EddieBolt
    EddieBolt New Member
    David
    2020 CM SR5 4x4
    Are you still under warranty? I would take it to the dealer.
  4. May 31, 2023 at 9:45 AM
    yakeng
    yakeng Broke Member
    2020 Tundra 4x4; 2014 Sequoia; Pending 5.7 Eng Failure
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    Your clicker beeps? Do you have an aftermarket alarm?
  5. May 31, 2023 at 10:56 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2017 Sequoia LTD
    Rx350 retrofitted, Morimoto Led fogs. interior and exterior leds swap. TRD drop in filter. Carbon filter delete. Led DRL panels. TRD Shift knob.
    Did you install new radio with idatalink maeatro?
    Anything plugged into the obd2 port right now?
  6. May 31, 2023 at 11:01 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Didn’t even know 2020’s had auto start. Is it only on platinums? My limited doesn’t have it.
  7. May 31, 2023 at 11:15 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I think they mean remote start...
    joonbug[QUOTED] likes this.
