Truck dies at idle and shudders at cruising speed
Discussion in '1st Gen Tundras (2000-2006)' started by Tailingred01, May 1, 2021.
  1. May 1, 2021 at 9:03 PM
    Tailingred01
    Tailingred01 [OP] New Member
    O5 Tundra SR5
    2005 SR5
    Engine dies after being driven for 30 min to an hour when idling at traffic light or at very slow speeds. RPM'S drop to 500 or lower(maybe) and at cruising speeds will randomly start to shudder, almost like a misfire but no CEL. Just had fuel pump replaced and cleaned the TB.
    When it started shuddering today I exited the freeway doing about 60, put it in neutral and coasted while revving the engine. Revved just fine, so I put it back in to D and accelerated back on to the freeway without a problem. No issues the rest of the hour drive back home.
    Anyone else have experiences like this and what fixed it?
  2. May 1, 2021 at 9:13 PM
    ThcAk
    ThcAk New Member
    Talkeetna,Alaska
    2012 Crewmax S/C'd 5.7 pyrite mica,& coming soon 07 rcsb,5.7,4x4 silver sky
    Crewmax- trd supercharger,6" pro-comp lift, amp research electric running boards, air lift bags on the rear, 20" rockstars wrapped with cooper stt pro's.( blown up engine ) RCSB- stock
    How many miles? Sounds like a cat could possibly be bad
    MS22 likes this.
  3. May 1, 2021 at 9:54 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’d test fuel pressure to start..
    Hbjeff likes this.
  4. May 1, 2021 at 10:37 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Fuel relay
    Tailingred01 [OP] likes this.
  5. May 1, 2021 at 10:49 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC tundra lame-o 2wd
    I am assuming they replaced the fuel filter when they did the pump?
  6. May 2, 2021 at 4:35 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    2000 Tundra AC
    Why was the fuel pump replaced? (Just trying to get a full picture of what's going on.)
  7. May 2, 2021 at 5:23 AM
    Professional Hand Model
    Hand Protectors
    Brand of Fuel Filter?
  8. May 2, 2021 at 7:01 AM
    Tailingred01
    O5 Tundra SR5
    185k
  9. May 2, 2021 at 7:02 AM
    Tailingred01
    O5 Tundra SR5
    I would assume the mechanic did this when diagnosing the fuel pump going bad.
  10. May 2, 2021 at 7:03 AM
    Tailingred01
    O5 Tundra SR5
    I would assume so. Guess l will need to verify
  11. May 2, 2021 at 7:03 AM
    Tailingred01
    O5 Tundra SR5
    Because of the symptoms I described in the post.
  12. May 2, 2021 at 7:04 AM
    Tailingred01
    O5 Tundra SR5
    I don't know.
  13. May 2, 2021 at 7:19 AM
    BubbaW
    BubbaW FAA Tweaker
    Bubba
    04 DC LTD 4X4 4.7 V8 DOHC
    GO VOLS
  14. May 2, 2021 at 7:24 AM
    Hand Protectors
    2005 has no ‘fuel filter’ but does have a sock in the tank. See picture.
    The earlier gens have a traditional external ‘in line fuel filter’ in addition to the sock.
    ThcAk, FrenchToasty and Hbjeff like this.
  15. May 2, 2021 at 7:25 AM
    Hand Protectors
    Fuel Filter with 30k miles.
  16. May 2, 2021 at 8:14 AM
    Tailingred01
    O5 Tundra SR5
    Ha! Yeah, yeah... I know.
    BubbaW likes this.
  17. May 2, 2021 at 8:14 AM
    empty_lord
    05 rollover special
    Ah, I figured that pump was replaced before the issues. New parts can indeed be bad.
    Best thing to do is look at live data and monitor fuel Trims, MAF and a/f sensor readings
  18. May 2, 2021 at 9:04 AM
    Tailingred01
    O5 Tundra SR5
    Yeah, wish I had the monitoring equipment for that. Running fuel system cleaner through it today and cleaning MAF too. See what happens.
    empty_lord likes this.
  19. May 2, 2021 at 9:16 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    If you have access to an Android phone or tablet, a $3-25 Bluetooth obd2 adapter and $6 'Torque' app will get you that capability.
    SouthPaw likes this.
  20. May 2, 2021 at 9:33 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    Get a simple monitor like they are sayin. It will save you trips to a shop, one trip will cost more than a cheap monitor
  21. May 2, 2021 at 9:33 AM
    Tailingred01
    O5 Tundra SR5
    I do have an Android phone and I do have the FIXD obd2 tool but I'm not sure I can see real time data. Any particular adapter you reccommend?
  22. May 2, 2021 at 9:53 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Is the Fixd tool a Bluetooth to obd2 adapter, one that plugs into the truck and pairs to your phone?
    If so, download the 'free' version of Torque and see if it is compatible. Many of these adapters are elm327 (chipset) based and can be used with other apps.
  23. May 2, 2021 at 10:05 AM
    Tailingred01
    O5 Tundra SR5
    Awesome! I will do that. Yes, FIXD is a Bluetooth adapter to the phone but works with Apple as well. I'll download that app right now.
  24. May 2, 2021 at 10:33 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If the fuel pump was supposed to be the cause, and replacement didn't help, and no CEL comes up...makes me wonder if this problem isn't transmission related.
    If you don't get any better ideas, try a transmission drain and fill. If the problem improves or goes away temporarily, I would change the transmission fluid completely.
  25. May 2, 2021 at 11:31 AM
    Tailingred01
    O5 Tundra SR5
    I'll check that out. Just curious what would link the transmission to these issues? I know veey little. I try but my knowledge is very small.
  26. May 2, 2021 at 11:36 AM
    Tonka94
    Tonka94 New Member
    2010 Tundra TRD
    This is a long shot, my dad had a similar issue with his. After new fuel pump and multiple trips to the dealer. Toyota called in a master mechanic from out of state and came to the conclusion the ECU was partially unclipped behind the glove box. Again this is a long shot but worth checking out.
  27. May 2, 2021 at 11:46 AM
    shawn474
    shawn474 New Member
    MoCo, Maryland
    I had similar symptoms on an older Honda Accord; turned out it was the ignition switch. Easy fix but not sure if this could be your issue
  28. May 2, 2021 at 12:46 PM
    KNABORES Not so new-ish Member
    2000 Limited TRD Access cab
    Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Westin bull bar with 20" LED Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers trim and tool box
    Couple reasons:
    1. You said the word "shuddering" which is a classic transmission symptom and term.
    2. It exhibited the symptoms while in gear, revved fine when in neutral.
    This does not mean it's your transmission. But it's a reasonable suspicion. Worth at least checking the fluid level, '05 has no dipstick though. Have to check under the truck at the fill plug and only when the trans is warmed up will it give a usable level indication.
    "just had fuel pump and TB worked on" would make them and their associated components my number 1 culprits.
  29. May 2, 2021 at 4:36 PM
    JohnLakeman
    There...That!^^^^
    Incomplete clutch disengagement could cause stalling at idle, shuddering is a classic torque convertor symptom. Eliminate the fuel system as the cause first.
  30. May 2, 2021 at 5:37 PM
    Tailingred01
    O5 Tundra SR5
    I say "shuddering" but it's hard to explain. It's been a while since i experienced a misfiring engine, so it could be that. It's almost like it's missing and then lurching forward .
