Trouble adding air to my tires
Discussion in 'Wheels & Tires' started by batracing17, Oct 20, 2021.
  1. Oct 20, 2021 at 12:44 PM
    batracing17
    batracing17 [OP] New Member
    Tara
    2013 Toyota Tundra
    Hello everyone. I have had Toyota's since I was 15. I started with a 2000 Tacoma, then a 2001 Tundra and I recently purchased a 2013 Tundra.
    I have never had a problem adding air to my tires until now. The valve stem is BEHIND a cutout in the wheel and I can't reach it.
    I ended up putting the chuck on the valve stem from behind the cutout, bringing the hose behind another cutout and attaching it to the chuck, all while air is releasing from the tire.
    I drove my truck yesterday, no problem. This morning, completely flat tire.
    Do they make chucks without an angle? Is this a design flaw or did someone modify and f*** up?
  2. Oct 20, 2021 at 12:48 PM
    Taco-Spike
    Two Trucks
    You have pic's of it? I'm trying to picture it, but my brain isn't computing
  3. Oct 20, 2021 at 1:07 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I think its obvious that we need a pic to understand.
    BravoDeltaRomeo likes this.
  4. Oct 20, 2021 at 1:26 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Yes, you can get tire chucks and gauges with a straight head.
  5. Oct 20, 2021 at 1:40 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Did they put the "beans over the frank" when they installed the tire?
  6. Oct 20, 2021 at 1:41 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome
  7. Oct 31, 2021 at 8:00 AM
    batracing17
    Tara
    2013 Toyota Tundra
    Sorry everyone. Every time I remembered to take a picture, I wasn't near my truck or my phone.
    The first photo is from the top of the tire, looking down. You can't even see the valve stem
  8. Oct 31, 2021 at 8:05 AM
    Refusuck
    Refusuck New Member
    Si Tres
    Arch Cape OR
    2021 TRD Pro
    Rusty sitch - does that valve stem even still function properly?
    Saltyhero13 likes this.
  9. Oct 31, 2021 at 8:15 AM
    batracing17
    Tara
    2013 Toyota Tundra
    I'm pretty good with vehicle lingo but I've never heard of a sitch. I took the cover off just to show you. My left rear tire kept going flat but my dad said it's missing an o-ring and replaced the cover and fixed that
  10. Oct 31, 2021 at 8:26 AM
    15whtrd
    15whtrd Mr. Blonde
    I don’t know if you have an air compressor. I don’t have room for a large one so I got one of these about 10 years ago from Harbor freight. At the time it was like 35 bucks,(now $50) then I got a little hose kit to go with it. It’s been working well enough for me to get the job done and all my cars.
  11. Oct 31, 2021 at 8:28 AM
    15whtrd
    15whtrd Mr. Blonde
    An O-ring under the valve stem cap? That’s the only thing I can picture from your description. If that stopped the tire from leaking air, it’s more likely that your Schrader valve inside the valve stem is leaking. You can also replace that yourself or just take it to a tire shop.
    Black Wolf likes this.
  12. Oct 31, 2021 at 8:29 AM
    Refusuck
    Refusuck New Member
    Si Tres
    Arch Cape OR
    2021 TRD Pro
    Your valve stem looks normal to me - and can be reached by most angled chucks - if your tire is going flat check the valve stem with soapy water to see if it's leaking after you add air. You also need to see if you got a nail or something else causing the leak.
    Oey12 likes this.
  13. Oct 31, 2021 at 8:36 AM
    batracing17
    Tara
    2013 Toyota Tundra
    I have a large compressor but I do like the last chuck you posted. I went to harbor freight and NAPA and asked if they make a straight chuck and they said no
    15whtrd[QUOTED] likes this.
  14. Oct 31, 2021 at 8:38 AM
    batracing17
    Tara
    2013 Toyota Tundra
    I know I don't have anything stuck in my tire. Since my dad put a new cover on the valve stem on the left rear, it hasn't gone down. I will spray the stem and look for bubbles, good thinking.
    The stems didn't look bad to me but the location is driving me nuts. Using a regular 90° chuck, I can't get it locked on
  15. Oct 31, 2021 at 8:49 AM
    15whtrd
    15whtrd Mr. Blonde
    NAPA might not have it because they don’t have a large inventory of accessories. Harbor freight probably didn’t know what you were talking about LOL. But the first one I posted I got from Harbor freight in the hose kit.
    Check this one out from Home Depot. Similar to the inflator chuck at a gas station.
    https://www.homedepot.com/p/Husky-Dual-Foot-Inflator-Gauge-17850HOM/205331827
  16. Oct 31, 2021 at 8:52 AM
    15whtrd
    15whtrd Mr. Blonde
  17. Oct 31, 2021 at 8:54 AM
    batracing17
    Tara
    2013 Toyota Tundra
    I'm pretty sure my dad has one of those. He's got EVERYTHING! Thanks
