Trip resetting when key is off
Discussion in '2nd Gen Tundras (2007-2013)' started by STCLegend82, Jan 24, 2018.
  1. Jan 24, 2018 at 6:05 AM
    STCLegend82
    STCLegend82 [OP] New Member
    2008 silver XSP Tundra
    Mostly stock
    Hey guys I'm new to the forum, I am stumped on an issue with my tundra. Every time I shut the truck off the trips, both a and b, reset to zero. There are no oher issues and the oil change reminder is not affected. I'e checked fuses and can' find anything on the web, any ideas?
  2. Jan 24, 2018 at 9:58 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Get a OBDII checker and see if the readiness monitors are resetting at the same time. Scan it when you see the trip meters are reset, but before you start the engine. If the readiness monitors are reset, you may have a bad ECM. If they're OK, you probably have a bad instrument cluster (or at least the part that controls the trip meters).
    Sunnier and TXMiamiFan like this.
  3. Jan 24, 2018 at 10:00 AM
    STCLegend82
    Mostly stock
    Sounds good I'll hook it up tonight and see what happens.
  4. Jan 24, 2018 at 11:43 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO.
  5. Mar 31, 2018 at 7:27 AM
    STCLegend82
    Mostly stock
    Ok just an update, the readiness monitors don't seem to be reset my cheap little scanner just shows that they have been completed. I did finally replace my broken message center switch so I can finally see my avg mpg as well as range and current mpg. My avg mpg is resetting just like my trip a and b miles. I can't determine 100% if it's the ECU, is there any other part that could cause a full reset less than 30 seconds after key off?
  6. Aug 13, 2019 at 7:33 AM
    babingtonmoore
    babingtonmoore New Member
    STC - Did you ever figure it out? This is happening to my 2015 1794. Both a and b are resetting and my driver's memory seat is acting up.
  7. Aug 13, 2019 at 3:09 PM
    _cumdra_
    _cumdra_ New Member
    Devin
    2011 tundra sr5
    Fuel Mavericks 20x10, 30x12.50 nitto terra grapplers 3inch level kit
    Could it be a bad ground on your battery ? Just a thought
  8. Aug 13, 2019 at 4:35 PM
    babingtonmoore
    It's fixed! Found the post below from another Tundra forum....
    OK, here is something weird to try.
    Replace three fuses in the front fuse box under the hood. Replace them even if they look good. All these fuses feed the combination meter one way or another.
    1) IG = 10 amp
    2) MET = 7.5 amp
    3) MET-B = 7.5 amp
  9. Mar 21, 2023 at 1:40 PM
    STCLegend82
    Mostly stock
    So this fixed my issue after a year of giving up lol. Ended up being a popped MET-B fuse. Mine was a 5amp fuse though notna 7.5. If it pops again I'll try a 7.5.
  10. Mar 21, 2023 at 3:39 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Yes that is the problem. Had I been a member back then and know what I know now I could have easily answered this way back when.
    The 2007 wiring diagram list the MET-B fuse as a 5A. It is the battery power fuse into the instrument cluster. Its only reason is to retain memory in the cluster when the key is off. Similar to how radios save preset radio stations.
    With this fuse bad, your cluster is fully losing battery power when the key goes off and forgetting all trip and MPG data.
  11. Mar 21, 2023 at 6:12 PM
    Randy Morton
    Randy
