@TRI-COLOR FOG LIGHT REPLACEMENT BULB (NEW PRODUCT)
Discussion in 'Lighting' started by Caliraisedled, Nov 4, 2019.
  1. Nov 4, 2019 at 10:16 AM
    Caliraisedled
    Caliraisedled [OP] New Member
    Jake
    Welcome
    Cali Raised Led
    www.CaliRaisedled.com
    Cali Raised LED is taking your fog lights to a whole new level with our tri-color fog light system. These smart bulbs have 3 different settings to choose from: White 6000K, Amber 3000K, and Amber/White Combo 4300K all in the same bulb!
    FEATURES:
    • 7,000 Lumens Per Set
    • CE RoHS A Perfect Light Pattern: Exclusive Arc-Beam Technology - Crafted around the powerful LED Chips to provide the only LED headlight with the CORRECT beam patterns, No dark spots, no short beams, and no scattered beams.
    • Improved heat control with LED driver and built in Turbo Cooling fan to ensure your bulbs last longer than your car! Over 30,000 hours of brilliant continuous light and build up with high quality aircraft-grade aluminum material design for better cooling and anti-dust metal lamp post.
    • Faster ON/OFF with 0 second response time unlike HID and vibration resistant. Easy installation, just plug & play.
    • Low Voltage Protection and High-Precision Constant Current Driver Chip.
    • Built in IC Circuit (Current Regulator) prevents LED Damage from Voltage Variations & Spikes.
    • Totally Waterproof - can be lit up in the water with waterproof rate IP68.
    • Dust-proof with internal constant current CPU.
      https://www.youtube.com/watch?v=a3aA89NOIhU
    SprinterAE86 and Darkness like this.
  2. Nov 5, 2019 at 8:03 AM
    Caliraisedled
    Jake
  3. Feb 5, 2020 at 12:33 PM
    Caliraisedled
    Jake
  4. Feb 13, 2020 at 12:27 PM
    Caliraisedled
    Jake
  5. Feb 13, 2020 at 12:30 PM
    Beau
    Beau De gustibus non est disputandum
    Beau
    2008 Sequoia with a 2022 style
    How do you switch between each color?
    Caliraisedled[OP] likes this.
  6. Feb 13, 2020 at 12:44 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    They cycle between colors when you turn them off then back on.....just like in the video. ¯\(°_o)/¯
  7. Feb 13, 2020 at 1:26 PM
    Caliraisedled
    Jake
    They are on a cycle when you turn on and off your lights with your switch.
    Wynnded likes this.
  8. Feb 17, 2020 at 7:54 AM
    Dimitri
    Dimitri New Member
    Dimitri
    Are these available for the 2nd gen tundras? (2007-2013)
  9. Feb 17, 2020 at 2:51 PM
    Caliraisedled
    Jake
    We just for the 2014+ Tundras.
  10. Feb 19, 2020 at 12:51 PM
    MotoTundra
    MotoTundra The Ocho
    Don
  11. Feb 20, 2020 at 9:28 AM
    Caliraisedled
    Jake
    Unfortunately we do not.
    MotoTundra[QUOTED] likes this.
  12. Feb 21, 2020 at 9:25 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Thanks for the reply.
  13. Feb 26, 2020 at 9:51 AM
    Caliraisedled
    Jake
    No problem please let me know if you have any other questions.
  14. Feb 26, 2020 at 10:46 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Wow! I want it!
  15. Feb 26, 2020 at 11:27 AM
    JimR
    JimR New Member
    Oregon
    2016 Inferno Double Cab SR5
    What wattage do these run at? Is heat buildup in the reflector/housing an issue compared to the stock bulbs?
    In white/amber mode are both LED's at full power, or is it reduced to each for a similar light output to the single color modes?
    Questions I ask after I already ordered a set, I bet these get nice and hot.
  16. Mar 13, 2020 at 12:27 PM
    Caliraisedled
    Jake
    Sorry for the late response, have you been helped with this?
  17. Mar 22, 2020 at 7:21 PM
    JimR
    JimR New Member
    Oregon
    No, but I installed them the other day, good cutoff and super bright, glad I got them.
  18. Mar 23, 2020 at 7:16 AM
    Caliraisedled
    Jake
    Awesome that is great to hear! Please let me know if you have questions.
  19. Jul 21, 2020 at 7:44 AM
    Caliraisedled
    Jake
  20. Jan 15, 2024 at 12:33 PM
    Caliraisedled
    Jake
    Our Tri Color Fog Light Replacement is a easy instillation! It will ensure your bulbs last more then your car with over 30,000 hours :eek2:of brilliant continuous light
