TRD Sway bars
Discussion in '3rd Gen Tundras (2014+)' started by phogallen, Dec 29, 2018.
  1. Feb 13, 2019 at 9:48 AM
    #61
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
    BD Squadron Sport Amber WC Fogs
    I didn’t have any anti seize and was too impatient to wait and get some before installing. I had lube which I used in the bushings. I’ll probably get some anti seize and slap some on when I re-torque after 500 miles or so.
  2. Feb 27, 2019 at 3:23 PM
    #62
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    I cannot get the last of the bolts to grab not sure if aI need to take the whole thing apart and start over.
  3. Feb 28, 2019 at 11:48 AM
    #63
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    Leveling Lift 3"/1.5" (6112 with a CB shim and JBA UCA, and 5160 and Toytec Shackles Nitto Terra Grappler G2 295/60R20 on Blk Fuel Vector Front and Rear TRD Sway Bars Amp Power Step EVO-One Remote Start Black Powder Coated Bumper Caps Colored Matched Front Bulge and TRD Pro Grill Assy RCI skid plate LED interior lights. Added front and rear footwell led lights. Blue LED lit lock/window switch. Black TRD shift knob Toyota Cargo LED Spyder Headlights (LED Hikari Bulb + Re-wired LED bar as DRL) Limo Tint (all around) Relocated Rear Diff Breather Rear Brake Line Extension Debadged
    Are you doing front or rear? For rear, make sure you don't have end link connected to the sway bar. In both case, you must be not jacked up and level ground.
  4. Feb 28, 2019 at 12:01 PM
    #64
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    Thanks I got it finally
    matictundra likes this.
  5. Mar 18, 2019 at 4:39 PM
    #65
    Clifton
    Clifton New Member
    Kurt
    2016 TRD Pro
    Which Hellwig did you get - the one for stock or the one for 2-4" lifted. I have a 2016 TRD Pro, which, as I understand it, comes "stock" w a 2" lift over a normal Tundra. Is that correct, and if so, should I then get the one for lifted? Thanks for any advice.
  6. Mar 18, 2019 at 4:44 PM
    #66
    TheBeast The Beach
    I removed my rear one. It was getting in the way when going off road. It was good for the freeway though when I had it.
  7. Mar 19, 2019 at 7:26 AM
    #67
    DarthMurdicide
    DarthMurdicide Executive Redneck
    South Carolina
    I have a 2" leveling kit on the front, so I bought Hellwig model number 7889, and it fit perfectly.
  8. Mar 19, 2019 at 10:26 AM
    #68
    Clifton
    Clifton New Member
    Kurt
    2016 TRD Pro
    Thanks. My TRD Pro is stock; does that mean it comes lifted?
  9. Mar 19, 2019 at 10:32 AM
    #69
    Makoy339
    Makoy339 New Member
    Super White DC TRD
    Faux Pro
    Pros are 2 inch higher at the front vs. non-Pros.
  10. Mar 19, 2019 at 11:35 AM
    #70
    Clifton
    Clifton New Member
    Kurt
    2016 TRD Pro
    Great. Thank you all!
  11. Mar 19, 2019 at 4:05 PM
    #71
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    2018 Limited CM Cement
    Will the sway bar fit if we have a +1 or +2 shackle in The back?
  12. Mar 19, 2019 at 4:24 PM
    #72
    LT75
    LT75 New Member
    Saint Charles, IL
    2018 White Platinum Crewmax
    Icon 3.5/3 lift, 20” KMC XD wheels on 285/65/20’s.
    Yes
    Travo60 likes this.
  13. Mar 19, 2019 at 4:46 PM
    #73
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    My rear sway bar shipped today from Ekstrom Design! I had him make me extended rear links to accommodate my 8” lift!
  14. Mar 19, 2019 at 4:50 PM
    #74
    phogallen
    phogallen [OP] My Last Mid-Life Crisis
    Kansas
    2019 Black 1794 Fusion Edition
    TRD Pro Grill, front bumper end caps, mirror caps and door handles blacked out. ATC Cap, Cap Pack 6 Gun Drawer, LED lights in CAP, Rhino rails on top, 12 volt accessory plugs. Weathertech floor mats, after market antenae. Ceramic tint film to driver and passenger door. Coachbuilder shims ,+2 shackles, steering kit, bumper shims, Bora 1.25 wheel spacers Bilstein 5100's on mid setting. BW flares with blacked out Route 66 screws. Gloss black powder coated OEM rims and Cooper 295/70/18 ST MAXX. Tech12Volt sound system upgrade...JL C2's doors and C1's on dash, 5 channel JL amp, 2 10inch subs in custom box and DSR1 sound processor...Soundskins in doors and back wall. Trunk and body badges removed. Powder coated tow hooks red. Linex bed lining front bra film and flares along with full ceramic coat. Cramic Pro interior plus windshield treatment. Toyota running boards and TRD anti sway bars in front and rear along with blacked out exhaust tip. TRD door latch cover plates. Full VLED light upgrade puddle, license, interior added footwell plus rear tail light brake, reverse. Added ASM turn signal LED's in front. OPT 7 tailgate light in red. Baja Design amber squadrons wc in front and SR2 Pro's in amber on rear bumper. Filmed reverse light in back, added red shackle on tow hitch and new license plate in front
    Yes I have a +2
    Travo60 likes this.
  15. Apr 15, 2019 at 1:49 PM
    #75
    Tundyfundy
    Southern California
    Magnetic Grey DC SR5 4x4 2016
    Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), BF Goodrich KO2's 275/70/r18, Bullydog GT Tuner, TRD Intake, TRD Dual Exhaust, TRD Rear Sway Bar, TRD Front Sway Bar, TRD Skid PLate with Spacer Kit, TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Wheel Locks, Spare Tire Lock, TRD Wheel Caps, Bed Rail System, Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Blind Spot Mirrors, Interior LED Bulbs, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters, Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor.
    I have +2 and mine hits the leaf springs nearing full droop. Full on rests the springs on my rear sway bar. Sucks. Looking for a fix. I have the +2 coachbuilder shackles and bilstein 5160 on the rear.
  16. Apr 15, 2019 at 4:06 PM
    #76
    phogallen
    Kansas
    I have no issue with the same set up...only 5100's on the back. Call dave at coachbuilder.
  17. Apr 15, 2019 at 5:40 PM
    #77
    Tundyfundy
    Southern California
    I think it’s du
    just spoke with him and he said they’re working on a drip bracket for the rear!!
