TRD Sway bars
Discussion in '3rd Gen Tundras (2014+)' started by phogallen, Dec 29, 2018.
  1. Jan 10, 2019 at 6:35 PM
    SoCal13TRD
    SoCal13TRD New Member
    2013 Tundra Crewmax Limited/TRD RW
    ...thanks, AZ....based on what you just said and a lot of other research I'm going to install the sway bar.
    FYI: Toyota discontinued the TRDPro suspension (Bilstein version) since switching to Fox and I was told the new TRDPro suspension (Fox version) will not work on my 13 even though the old versions (Bilsteins) will. Go Figure. So, I just found a set of takes offs and will be getting them and the sway bar installed by Camelback Toyota in Phoenix...
    Rica25 likes this.
  2. Jan 10, 2019 at 6:37 PM
    SoCal13TRD
    ...thanks SoCal...I hear you...totally get it.
    Rica25 and SoCal8654 like this.
  3. Jan 10, 2019 at 6:48 PM
    AZTundra
    Paul
    Phoenix, AZ
    TRD Pro Grille, Billet Battery Hold Down, Weather Tech Floormats (Front/Rear), Side Steps, BakFlip MX4, AMP Research Bed Extender, Spray In Bedliner, TRD Rear Sway Bar, B&W Adjustable Drop Hitch, TRD Pro Suspension, AMP Research Bed Step
    Not sure if you have a specific service advisor that you use. I bought my Tundra at Camelback Yoyota and have all my service done there as well. Joe Toro is my service advisor and is good to work with if you are looking to find one.
    SoCal8654 and Rica25 like this.
  4. Jan 10, 2019 at 7:05 PM
    SoCal13TRD
    ...AZ, so I live in Orange County, CA. I've never been to Camelback Toyota. The reason I'm going to drive out there and have them do this install is because I cannot locate any dealers in OC who are willing to do it or who are even competent enough to do it...and technically, its not allowed by Toyota for them to do it since the TRDPro suspension kit was not made for the 13s - even though they fit perfectly with no mods - but through the use of these forums I got turned on to Murph (Service Manger) at Camelback and he has no problem doing it for me and they seem to know exactly what they are doing without hesitation - unlike most Toyota dealerships/service depts. in Orange County.
    DiegoC, SoCal8654 and Rica25 like this.
  5. Jan 10, 2019 at 7:17 PM
    AZTundra
    Paul
    Phoenix, AZ
    Well, glad they are helping you out. They are one of the largest Toyota Dealerships in the Phoenix area. I've been using them since I bought my truck in July 2017 and no complaints so far. Sucks that no one is closer for you though. Are you set on using the dealer?....I'm sure just about any off-road shop would tackle it.
    Rica25 likes this.
  6. Jan 10, 2019 at 7:24 PM
    SoCal13TRD
    ...I am 100% dealer-only when it come to servicing my Toyota vehicles, especially with this type of work. The service departments hate me because I am up there ass on double checking their work...so even though Toyota says this Pro kit is not suppose to be on this 13 Tundra I'll feel better knowing a dealership installed them - JUST INCASE - there is a warranty issue.
    Rica25 likes this.
  7. Feb 7, 2019 at 7:16 PM
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
    BD Squadron Sport Amber WC Fogs
    Ok guys, my rear sway bar will apparently be here tomorrow. I'm a mod newb and certainly no mechanic, by any stretch of the imagination. What tools do I need to do the install?
  8. Feb 7, 2019 at 7:19 PM
    nakota
    nakota New Member
    Phoenix
    Tundra234 likes this.
  9. Feb 7, 2019 at 7:38 PM
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
  10. Feb 7, 2019 at 7:56 PM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Aries Side Bars, DeeZee low profile tool box, weathertech mats, TRD RSB
    not the most complex mod that you will do. I just put mine on within the last month. Helpers are a plus. I used a 25 inch 1/2 inch breaker bar for the 19mm trailer hitch mount bolt most forward. I really liked the you tube video that used the "anti seize". the you tube vids will show that the lower link to RSB uses only 1 washer, follow the instructions that show 2 washers on the lower link to RSB. If solo you can tie the RSB to the rear axle with para-cord once all of the links and RSB is loosely bolted together. once all is bolted together loosely then 22mm socket for the upper links, 19 mm socket for the lower links, axle brackets and the saddles for the axle. be careful of the lines/wires around the axles.
    after finished, test, It will be the most thrilling ride on this truck that you will ever imagine. I have 9 curves on a Louisiana highway to the interstate, used to be 35-45 mph, now 55 mph with no sweat, careful though until you get used to the "sportscar handling". Again careful installation and driving you will enjoy the difference.
    Rica25 likes this.
  11. Feb 8, 2019 at 4:44 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    I had my laptop next to my truck and this makes installing the bar a breeze.
    https://www.youtube.com/watch?v=cZdVjObkTLs
    Rica25 likes this.
  12. Feb 8, 2019 at 5:14 AM
    Berettafan
    Berettafan New Member
    2017 CM
    for those of you who don't know this and watch the video----be aware Anti Seize gets on EVERYTHING and NEVER GOES AWAY. it will outlast this planet. a giant asteroid will destroy earth one day and some alien civilization will find silver goo floating around in space.
    and they too will get it all over the place.
  13. Feb 8, 2019 at 6:46 AM
    JeremyGSU
    Jeremy
    2016 Tundra
    I went through about 15 pairs of disposable gloves doing it his way because I kept getting it all over. lol
  14. Feb 8, 2019 at 7:09 AM
    DarthMurdicide
    DarthMurdicide Executive Redneck
    South Carolina
    I bought the Hellwig rear sway bar. Pretty much the same, just doesn't say "TRD", and it's grey, not red. Don't get me wrong, I like all the TRD accessories, just don't have the TRD "theme" on my truck (except for the TRD air filter and air flow accelerator, which are under the hood :)).
    Definitely rides better, especially in high-speed tight cornering. I can see though that it might be a hindrance with "extreme" off-roading.
    Best result from the purchase...I finally had a reason to get a torque wrench! :rofl:
    Prostar 190 likes this.
  15. Feb 8, 2019 at 7:44 AM
    DiegoC
    DiegoC Cardi T
    Diego
    2016 White Tundra Limited ( Wannabe Sport)
    ReadyLift SST 3/1 Level Lift
    I put the TRD Rear Sway Bar on my ruck and noticed a difference for sure. have had no issues with it. I occasionally like to hit the mud and do some donuts....no issues yet. lol
  16. Feb 12, 2019 at 11:41 AM
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
    Did anyone install without using anti seize lub?
  17. Feb 12, 2019 at 12:05 PM
    Prostar 190 White is sooooo Slow!!! MGM RULES!
    I used the silicone base lube that Hellwig sent with mine.
    dmiller likes this.
  18. Feb 12, 2019 at 12:09 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    Leveling Lift 3"/1.5" (6112 with a CB shim and JBA UCA, and 5160 and Toytec Shackles Nitto Terra Grappler G2 295/60R20 on Blk Fuel Vector Front and Rear TRD Sway Bars Amp Power Step EVO-One Remote Start Black Powder Coated Bumper Caps Colored Matched Front Bulge and TRD Pro Grill Assy RCI skid plate LED interior lights. Added front and rear footwell led lights. Blue LED lit lock/window switch. Black TRD shift knob Toyota Cargo LED Spyder Headlights (LED Hikari Bulb + Re-wired LED bar as DRL) Limo Tint (all around) Relocated Rear Diff Breather Rear Brake Line Extension Debadged
    Love the sandals, lol. I do most of my work wearing sandals.
  19. Feb 12, 2019 at 12:10 PM
    #49
    matictundra
    Franco
    AZ
    Always apply the lube provided.
  20. Feb 12, 2019 at 12:14 PM
    #50
    That's what she said! Lol
    dmiller and Rica25 like this.
  21. Feb 12, 2019 at 12:41 PM
    #51
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
    The YouTube vid I watched the guy used an anti seize lube other than the small packet that is included with the kit. Was just curious.
  22. Feb 12, 2019 at 12:48 PM
    #52
    matictundra
    Franco
    AZ
    There are different kind of lubes for different materials. The lube they supply should be the one spec out by the bushing company and hence always use it. You can buy your own but make sure to contact the bushing company for the proper lube spec.
    dmiller and Prostar 190 like this.
  23. Feb 12, 2019 at 6:48 PM
    #53
    Hammy68
    Hammy68 New Member
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    Toytec Leveled, TRD Dual Exhaust, Nitto RGs 275/70/18, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    Is everyone using the anti-seize when installing? Do you really need it if the installation doesn’t call for it?
    Rica25 likes this.
  24. Feb 12, 2019 at 7:20 PM
    #54
    Tracy Perry
    Tracy Perry New Member
    Tracy
    East Texas
    2019 white SR5 CrewMax TSS Off-Road
    Yep... me. But I am going to go back and take them out and put it on them.
    Rica25 likes this.
  25. Feb 13, 2019 at 4:28 AM
    #55
    Berettafan
    2017 CM
    I think its good to use. I hate creaks and locked up bolts. anti seize seems to help with both.
  26. Feb 13, 2019 at 5:01 AM
    #56
    Hammy68
    Hammy68 New Member
    New Hampshire
    Good point- when I install I’ll take the extra time to use it so I don’t regret it later.
  27. Feb 13, 2019 at 6:11 AM
    #57
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
  28. Feb 13, 2019 at 7:59 AM
    #58
    matictundra
    Franco
    AZ
    Ok, what are we talking here, anti seize (which typical goes on threads) or lube (in this case bushing lube)? They are two completely different application, lol.
  29. Feb 13, 2019 at 8:58 AM
    #59
    Inquiringone
    Inquiringone Play Things, What's Your Tundra Used For...
    Ter
    NorCal
    Super White 1794 CrewMax.
    I agree, this mod is extremely easy. You don't need to jack the truck up either. I had mine on in 30 minutes. It took longer setting the torque wrench specs and getting/putting tools away than actual install.
  30. Feb 13, 2019 at 9:45 AM
    #60
    Tracy Perry
    Tracy
    East Texas
    Threads... typically the sticky silver stuff. ;)
