TRD SWAY BAR +4 inches for 6"Lift
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tony'sToy, Apr 9, 2017.
  1. Apr 9, 2017 at 1:54 PM
    Tony'sToy
    Tony'sToy [OP] New Member
    Tony
    Savannah, MO
    2015 Toyota Tundra SR5 TRD OFF ROAD
    6" Rough Country lift kit 20" BMF Novakane Wheels 35"X12.50R20 Nitto Trail Grappler MT AIRAID Cold Air Intake Flowmaster Outlaw Exhaust System Bushwacker Pocket Style Fender Flares Recon Projector Headlights (Smoked) Recon 35 Watt Hid Headlights Recon 35 Watt Hid Foglights Recon LED Brake Lights (Smoked) Recon LED 3rd Brake Brake Light (Smoked) Recon LED Tailgate Light Bar(Smoked) Recon LED Big Rig Light Bar (Smoked) Recon LED Bulbs Every Bulb Location Rough Country 30" Bumper Mount Single Row Light Bar. Headlight Revolution LED Interior Light Kit Replaced Every Bulb Blue LED Bulbs Toyota TRD PRO Grille (Black) TRD Shift Knob All Windows Tinted 20% WeatherTech In Channel Window Deflectors WeatherTech Floor Liners Extant Encore Tonneau Cover
    I got my TRD Sway Bar back from Ekstrom Design. They extended my End Links 4" to accommodate a 6" lift. They powder coated my sway bar black to match my truck. They also powder coated my brackets spacers and bolts. It turned out pretty good. Thanks to Daved at Ekstrom Design. One of the nicest guys I have ever talked too.
  2. Apr 9, 2017 at 2:17 PM
    Great job :thumbsup: sweet rig!
  3. Apr 9, 2017 at 3:53 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    2016 Silver Platinum 4X4
    3/1.5 lift. TRD sway bar. Bakflip V1 cover. Fuel wheels w/BFG A/T.
    Looks great!
  4. Apr 9, 2017 at 6:13 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Stealth mode sway bar. :thumbsup:
  5. Apr 10, 2017 at 7:29 PM
    Hasteen
    Hasteen To be continued...
    Justin
    Providence, RI
    2004 DC SR5 Texas edition 2016 CM 1794 edition
    1ST GEN Toytec 3/1 lift kenda 33s on 17x9 RockTrix RT107 BruteForceFab front bumper ----------------------------------- 3RD GEN rough country 6" Toyo 35's on 22x10 Fuel Assault TRDPro Grille
    excuse me if this is a stupid question...
    how'd they extend the end links? i'm also planning a 6" lift is all.
  6. Apr 10, 2017 at 8:37 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    They cut them in half and install a larger and longer steel tube over the Pre existing links and weld it back together.
    Hasteen[QUOTED] likes this.
  7. Apr 10, 2017 at 8:40 PM
    Tony'sToy
    Tony
    Savannah, MO
    They push the End Links Bushings out at both ends. They cut both ends off were the bushing rings were and weld the ends on a thicker longer cut shaft. They sand blast and powder coat what ever color you want. Lubricant the bushings and put back in the ends. If you are getting a 6" lift you will need +4" inches because the 4" rear block under the leaf springs.
    Hasteen likes this.
  8. Apr 10, 2017 at 8:41 PM
    Tony'sToy
    Tony
    Savannah, MO
    The End Links come back 2 times the size . They are a lot more heavy duty.
    Lilly and Hasteen like this.
  9. Feb 5, 2018 at 12:10 PM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    I've been in contact with him today, based on your post here. The black powder coat is the way to go, not crazy about that red.
  10. Feb 5, 2018 at 2:32 PM
    TheBeast The Beach
    looks great
  11. Nov 14, 2018 at 8:22 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
  12. Nov 14, 2018 at 9:03 PM
    DOZER505
    DOZER505 Western TX
    Denny
    2014 Black Tundra Platinum
    None
    Looks great! Love the fuel door! :thumbsup:
