TRD Rear Sway Bar Install Question
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Kevfran99, Oct 17, 2020.
  1. Oct 17, 2020 at 8:29 AM
    Kevfran99
    Kevfran99 [OP] New Member
    Kevin
    Lilburn, GA
    '19 TRD PRO
    TRD Rear Sway Bar - Front tint - Caliraised LED Fogs & Light Bar-Bed LEDs-Bed Cover-Wireless Charger
    For those of you that have installed the rear sway bar on your TRD Pro does it require a lift or can you do it on the ground. I know a lift is preferred but wanted to know if it was possible on the ground. TIA
  2. Oct 17, 2020 at 8:32 AM
    On ground, but a jack with Jack stands can help
  3. Oct 17, 2020 at 8:33 AM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Easily on the ground...however my neck and back remind me I am getting old after
  4. Oct 17, 2020 at 8:33 AM
    bluevwfan
    bluevwfan New Member
    Jonathan
    2008 Limited Crew Cab Tundra
    SABM DAP Tune TRD Intake
    I did it on mine ('08 Crewmax) on the ground and mine is stock height.
  5. Oct 17, 2020 at 8:34 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
  6. Oct 17, 2020 at 8:50 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    On your back. With a couple buckets to help as your 3rd arm.
    kittyhawk likes this.
  7. Oct 17, 2020 at 8:59 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    LOL!
  8. Oct 17, 2020 at 10:19 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    YardBird likes this.
  9. Oct 17, 2020 at 10:27 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    On the ground is just fine. Plenty of room for you to crawl under and install everything.
    Kevfran99[OP] likes this.
  10. Oct 17, 2020 at 10:41 AM
    Vector W8
    If you are taking the time to do the rear sway bar, do the front also, Do either the TRD or Sequoia front sway bar you will really notice the difference. It is a great enhancement to the rear TRD bar.
  11. Oct 17, 2020 at 11:19 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Thanks I will take that into consideration after I install the rear.
    Vector W8[QUOTED] likes this.
  12. Oct 17, 2020 at 11:27 AM
    CaptainGrumpus
    Maine
    the rear is a must but the front is more of a “I’ve done all the mods I can think of, I guess I’ll do the front now”.
  13. Oct 19, 2020 at 12:12 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Part just came in so I will be doing this install tonight!
    SuperWhite20 and CaptainGrumpus like this.
  14. Oct 19, 2020 at 12:42 PM
    P-Factor
    P-Factor New Member
    I used zip ties to temporarily hold up u-bolt and saddle bracket (as a third hand) so that I could raise the bar with bushing brackets and hand start the acorn nuts. Otherwise like others have already said, it can be a handful.
    RobertD and YardBird like this.
  15. Oct 19, 2020 at 3:04 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    I’ve always wondered what happens when you run out of mods? Sell and buy a different vehicle and start all over? Kind of like when you run out of home improvement projects....:monocle:
  16. Oct 19, 2020 at 3:40 PM
    CaptainGrumpus
    Maine
    There is always “another” mod lol
    WillTunBlack20 and Black Wolf like this.
  17. Oct 19, 2020 at 3:44 PM
    .......and home improvement projects.......
    WillTunBlack20 likes this.
  18. Oct 19, 2020 at 3:46 PM
    CaptainGrumpus
    Maine
    Improvements and repairs :frusty:
  19. Oct 19, 2020 at 3:51 PM
    Just curious....are your pets kind of zombie acting? Pet S......
  20. Oct 19, 2020 at 3:57 PM
    glowblue
    VA
    Truth. I’ve even contemplated mods to mods like swapping my Kenwood DMX906S for the new 10.1” screen...
  21. Oct 19, 2020 at 4:02 PM
    CaptainGrumpus
    Maine
    He always is. Old crotchety king shit
  22. Oct 19, 2020 at 4:03 PM
    CaptainGrumpus
    Maine
    Now your realllly looking for ways to spend some $$$. The DMX906S is a nice HU but those new 10.1 floating screens are pretty damn nice
    Black Wolf likes this.
  23. Oct 19, 2020 at 4:41 PM
    Burdturger
    Burdturger New Member
    FYI. Make sure truck is level if installing on the ground :oops:
  24. Oct 19, 2020 at 7:51 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    I torqued everything to the specs on the instructions. The u-bolts over the axle came straight across the top but ended up curving down by the time the torque spec was reached
  25. Oct 20, 2020 at 2:29 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    All said and done in 45 mins. Would have taken me about 15-20 with a lift. Easy install just like the video above. Drove it today. Huge difference. Drives way better! And no the brackets aren't crooked. It's just the pic for some reason.
    P-Factor, Rob's Inferno and cp44 like this.
  26. Oct 21, 2020 at 8:30 AM
    cp44
    cp44 New Member
    Aaron
    NoVA
    Tundra TRD Pro
    Hows the ride? Is it harsher? Do you feel more bumps?
  27. Oct 21, 2020 at 8:35 AM
    fbingha
    fbingha New Member
    Bakersfield, CA
    Driving around town, it feels great, don't notice any bumpiness issue.
    Driving 120 miles to Los Angeles, it's bumpy as all hell now.
  28. Oct 21, 2020 at 8:55 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    corners a lot better. Haven't noticed any harshness at all.
  29. Oct 21, 2020 at 2:49 PM
    Progoyle
    Progoyle New Member
    TRD PRO
    Where did you end up picking up the sway bars? Thinking about getting the front/rear for mine.
  30. Oct 21, 2020 at 2:51 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    I ordered mine from the dealer since I get wholesale price and no tax. I paid approx. $220.
