TRD Pro Grill Facelift for a 2014 1D6 Silver Sky Metallic SR5 Off Road
Discussion in '2.5 Gen Tundras (2014-2021)' started by mr_souc, Feb 28, 2018.
  1. Feb 28, 2018 at 11:34 AM
    mr_souc
    mr_souc [OP] New Member
    Joel
    Maine
    2014 Tundra TRD Off-Road CrewMax
    - 3/2" Leveling/Lift - TRD Dual Exhaust - TRD Pro Grill - 32 Inch Light Bar - N Fab Step Rails - Color Match Bumpers - 285/75-18 Terra Grappler G2s
    Hey fellas.
    The Pro grill is the cat's pajamas and all the rage. I finally tossed one into my rig last night and she has has a whole new look.
    I thought I would post up some info for those looking to do the switch and offer up some advise for those who might want to keep the chrome surround (I know, I know, but there are a few of us)
    First off here she be:
    Like the thread title says she's a 1D6 Silver Sky Metallic with the SR5 (chrome) trim/surround which I have opted to keep... for now...
    This is NOT an OEM TRD Pro grill, I found on eBay for $189.00 shipped. Seeing how all I needed was the insert, I did not want to spend the $ for an OEM part. And I gotta say, it looks good, deff a real decent knock off!
    Install was slicker than snot on a doorknob. Took maybe 30 min and one IPA total. Guys have mentioned that removing the inserts will be the tricky part and I gotta say it was not that bad. I snapped off all the taps on the "donor" Pro grill and had that apart in 5 min. I took my time on the chrome surround and only broke off 2 tabs total. This is in a 30 deg cold New England garage mind you :) The insert from the "donor" grill clicked and screwed firmly into place on the OEM chrome surround and I had the whole thing back into the truck in no time.
    All and all, SUPER easy and if your looking to to the TRD Pro grill swap but don't want to break the bank, the one linked below is a great alternative.
    Cheers fellas!
    https://www.ebay.com/itm/Fits-2014-...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
  2. Feb 28, 2018 at 11:39 AM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    Looks good!sounds like you had better luck than some with the seperating lol
  3. Feb 28, 2018 at 11:46 AM
    mr_souc
    Joel
    Maine
    Yessir, just a little finesse and they will come right apart. You just can't force it.
    TundraDude18 likes this.
  4. Apr 7, 2018 at 5:10 AM
    mr_souc
    Joel
    Maine
    Update - Ditched the chrome!
    Dipped the chrome on the front and rear bumpers and added a color matched grill surround with my TRD Pro grill. Overall very happy with the new look.
    Think I need some black headlights now...
    Peteruspl, Mcoop, Part_time and 6 others like this.
  5. Apr 7, 2018 at 6:21 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Looking good. :thumbsup::thumbsup:
    mr_souc[OP] likes this.
  6. Apr 7, 2018 at 7:18 AM
    Looks great!
  7. Sep 17, 2018 at 9:08 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Looks great! I will say that the silversky looks great with chrome surround.That is what im about to do to mine, so im a little bias.
    TundraDude18 and mr_souc[OP] like this.
  8. Sep 18, 2018 at 5:01 AM
    mr_souc
    Joel
    Maine
  9. Nov 28, 2018 at 5:40 PM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    What kind of lift and tire s do you have on that? It looks perfect
  10. Nov 28, 2018 at 7:21 PM
    BIGED1975
    BIGED1975 New Member
    Massachusetts
    2018 Super White Sr5
    Level kit WHeels/Tires Exhaust center console conversion
    so you were able to swap out the grille from/on that aftermarket surround with hood buldge how did they fit?
  11. Nov 29, 2018 at 6:36 AM
    mr_souc
    Joel
    Maine
    I have the on there, and at the time I had Falken Wildpeaks in a 265/75r18. I've since swapped them out for a set of 285/75r16 Nitto Terra Grapplers.
  12. Nov 29, 2018 at 6:37 AM
    mr_souc
    Joel
    Maine
    They fit just fine, no complaints. I have sense moved on for a color match surround and color matched the bumper corners. HERE is that thread if your interested.
    Tiamat likes this.
  13. Jan 15, 2020 at 7:34 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    mr_souc......did that toytec spacer kit change the ride or handling on your truck? Any issues with clearance with those tires on the stock wheels and that lift?
  14. Jan 15, 2020 at 7:55 AM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    Good work, it looks great:thumbsup:
