TRD Pro Dashboard TOYOTA trim piece
Discussion in '3rd Gen Tundras (2022+)' started by sjeoid, Dec 11, 2022.
  1. Dec 11, 2022 at 12:49 PM
    sjeoid
    sjeoid [OP] New Member
    2022 Limited TRD Off-road
    Does anyone know if the passenger side dashboard trim piece for the TRD Pro is an available part? Would it be difficult to take out the current trim piece and install it.
    Taikowaza likes this.
  2. Dec 11, 2022 at 1:52 PM
    Lou1947
    Lou1947 New Member
    Tundra 1794
    Go to you tube and you will find a video on dismantling a TRD Pro dash
  3. Dec 11, 2022 at 1:54 PM
    Lou1947
    Lou1947 New Member
    Tundra 1794
    Disassemble entire dash on 2022 toyota tundra
  4. Dec 11, 2022 at 2:15 PM
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    ryanwgregg likes this.
  5. Dec 11, 2022 at 2:20 PM
    Taikowaza
    Taikowaza New Member
  6. Dec 11, 2022 at 2:24 PM
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    55476-0C060-B0 Garnish Instr Cstr $74.45
  7. Dec 11, 2022 at 3:11 PM
    Dmon187
    Dmon187 New Member
    DFW
    2022 Tundra SR5 TRD OFF ROAD
    18x9 Method 316 wheels, TRD skid plate, Cat plate, Heritage grill with color match front end, TRD suspension OEM Lift kit with Toyo Open country At3
  8. Dec 11, 2022 at 4:42 PM
    sjeoid
    Thanks to you all! Another question. Is it possible to replace the center console lid on a limited trim truck with the one like the TRD Pro? The open tray on the top is useless because anything left there flys off when you open the main lid. Really a useless design. Those should all have a lid on the very top that you can actually keep some small items in. Thanks again!
    iiawah808 likes this.
  9. Dec 12, 2022 at 2:30 AM
    RatPanda
    RatPanda New Member
    Ryan
    2022 Tundra 4x4 CrewMax 5.5
    yup, I did the same thing on my SR5 - super simple.
    Dmon187[QUOTED] likes this.
  10. Dec 12, 2022 at 3:49 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    I’m planning on changing mine too, saved this from another thread.
    wmsvol88 and troutback like this.
  11. Dec 31, 2022 at 10:49 PM
    iiawah808
    Oahu, HI
    Did you happen to get this done?
    Do you have the part number for the lid cover?
  12. Jan 30, 2023 at 11:56 AM
    Beardaho
    Beardaho New Member
    23 Limited TRD LR 6.5
    I tried to order the TRD Pro Instrument Panel Garnish and Gloss Black tailgate handle from a dealer parts website and received the message below. Keep in mind that their website wouldn't actually let me configure my vehicle as a 2023 Tundra as the only model available for 2023 was BZ4X. I put it in as a 2022 instead, but also had to add my VIN number. I'm going to try a different parts store and see if that works.
    troutback likes this.
  13. Jan 30, 2023 at 12:57 PM
    montera.built
    montera.built New Member
    Jordan
    2022 AG Toyota Tundra TRD Offroad
    Not to derail the thread, but I find it weird my Limited didn't come with that little space and I'd like to have it. Is there a way to order that different dash piece?
  14. Jan 30, 2023 at 3:34 PM
    firehawk003
    firehawk003 New Member
    You would have to change out the entire front dash. Not worth it, as it is plastic also and not padded like you have.
  15. Jan 30, 2023 at 6:49 PM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    Just order it without the VIN, I had to do that multiple times in the past year.
  16. Jan 30, 2023 at 7:04 PM
    Beardaho
    Beardaho New Member
    Will try that. Thank you!
  17. Mar 11, 2023 at 6:33 AM
    zcardoza1
    zcardoza1 New Member
    Zack
    2022 Tundra Ltd.
    What needs to be done to remove original cluster panel?
  18. Mar 11, 2023 at 8:17 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    It just pulls straight off with the passenger vent attached to it and there is a screw holding those 2 pieces together. Here’s a video of it 3mins in.
    https://youtu.be/kN8QWafqUXQ
    wmsvol88 and zcardoza1[QUOTED] like this.
  19. Mar 20, 2023 at 12:00 AM
    trailhunters
    trailhunters New Member
    Anyone know the p/n for the other 2 small trim pieces surrounding the driver side cluster? TRD Pro matching ones.
  20. Mar 20, 2023 at 6:47 AM
    Taikowaza
    Amazing! Thanks Ryanwgregg!
  21. Sep 8, 2023 at 7:26 PM
    Watszach
    Watszach New Member
    @trailhunters Did you ever find the part number for these two trim pieces?
  22. Sep 8, 2023 at 9:22 PM
    RatPanda
    RatPanda New Member
    Ryan
    GARNISH, INSTR CSTR FINISH PANEL, NO.1. Part Number: 55474-0C130-B0
    GARNISH, INSTR CSTR FINISH PANEL, NO.2. Part Number: 55475-0C130-B0
  23. Sep 9, 2023 at 2:23 PM
    Ash504
    Ash504 New Member
    For the TRD Pro Dash, Is there a way to replace the remaining silver pieces to match the TRD garnish insert? (55476-0C060-B0 Garnish Instr Cstr $74.45). I just purchased a limited and looking to make a few changes
