TRD Pro console lid upholstery repair - advice needed
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by geddon_jt, Aug 4, 2019.
  1. Aug 4, 2019 at 9:06 AM
    geddon_jt
    geddon_jt [OP] New Member
    Hi everyone, like an idiot I was moving things the other day, came to a fast stop and a computer monitor fell on my soft center console lid and left a perforation about an inch long. It wasn't cut totally open but you can barely see the white padding underneath. It basically looks like an inch long scratch next to the plastic part where you put your phone.
    These things happen and it was my fault. Just wondering if there is some sort of glue or upholstery epoxy that I could use to seal this thing up just to prevent expansion in the future. Im not sure if the cover material is actually leather like the seats or a synthetic upholstery.
    Posting in the TRD Pro forum because Im not sure whether the material used is the same as other trims...
    any help is appreciated! thank you. John
  2. Aug 4, 2019 at 9:11 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I wonder how much a replacement lid would be.
    @Roman is our parts guy.
    And welcome.
  3. Aug 5, 2019 at 7:59 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  4. Aug 5, 2019 at 8:08 AM
    Jim LE 1301 Camaro Lover, SSEM # 11
    Welcome from NY.
    Sorry to hear about the lid.
    @Roman is the parts guy.
    You could check Ebay for a used lid, replacement cover or a slip on material cover.
    Good luck.
  5. Aug 5, 2019 at 8:41 AM
    JoshuaA
    JoshuaA GenX 2.5
    Ontario
    Blacked 2015 going strong!
  6. Aug 5, 2019 at 9:34 AM
    Squatting Pigeon
    Holden
    North Texas
    Luxe Trail Pig
    Watt maker and JoshuaA[QUOTED] like this.
  7. Aug 5, 2019 at 7:19 PM
    Danimal86
    Daniel
    Sacramento, CA
  8. Aug 5, 2019 at 8:34 PM
    JoshuaA
    JoshuaA GenX 2.5
    Ontario
    Thanks! It's easy, use a glue gun, take your time to line up the stitching and let it dry in sections as you go. I probably made it harder on myself by adding thin padding underneath. When you get the cover, lay it out in the sun first so the wrinkles go away and it's more pliable. If you don't like the way you did it anywhere, just pick off the glue and redo that part. It settles nicely over warm days.
    A lot cheaper than the factory leather Limited/Platinum lid. I linked the one with red stitching, I used black:
  9. Aug 5, 2019 at 8:37 PM
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
    Or if all else fails just ask an upholster near you to do it for you I had mine redone to color match my red and it was only 80$. Including material and insall
    GAknight and JoshuaA like this.
  10. Jan 16, 2023 at 6:34 PM
    Skip_TRD_Sport
    Skip_TRD_Sport Less is More.
    2019 Cavalry Blue TRD Sport
    Westin Pro Traxx 4 Step Bars, Bed Mat, Color Matched Door Handles
    I know this is an old thread. What glue did you use? Will a hot glue gun be durable over time?
  11. Jan 17, 2023 at 7:15 AM
    JoshuaA
    JoshuaA GenX 2.5
    Ontario
    The sticks that came with the gun, just buy a decent glue gun. Just checked it out, holding up great and looks the same as above, haven't needed to think about durability at all!
    Sean492 likes this.
  12. Feb 7, 2023 at 9:09 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    Well I ordered a red stiched leather cover to match my TRD Pro red stiched seats. I'm not sure why the Pro didn't come with a red stiched arm rest, but after seeing this the above post I knew I had to do it. So waiting for a warm day and waiting on the covered part. I also found this video. https://www.youtube.com/watch?v=-qT10swLQdw I'll keep you posted on the outcome.
  13. Feb 12, 2023 at 8:40 PM
    TundraTXTSS
    Conroe
    2020 White TRD Pro
    i promised an update, added the leather red tiched cover I found in Ebay, not bad, I'll see how it warms up due to installing it today in 55 deg. temps, I like the red stiching the way the Pro center console lid should have come.If it doesn't tighten up, I'll take to my upholster.IMG_9457.jpg
  14. Feb 16, 2023 at 12:39 PM
    woofhauler
    woofhauler New Member
    Pacifica, CA
  15. Feb 16, 2023 at 3:06 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Mine was peeling BDE6E136-4746-4B39-B477-E689CD515839.jpg Got it recovered for $175
