TRD performance air filter worth it?
Discussion in '3rd Gen Tundras (2022+)' started by charliep, Dec 22, 2022.
  1. Dec 22, 2022 at 2:39 PM
    charliep
    charliep [OP] New Member
    2022 Lunar Rock Tundra TRD OR
    Trying to figure out a way to improve fuel mileage. Are the TRD performance air filters a legit way to possibly pickup a mile or two per gallon on the 3.5 TT? Any other ideas to improve MPGs?
    https://www.ebay.com/itm/234824750167
  2. Dec 22, 2022 at 3:29 PM
    fastarget
    fastarget New Member
    2023 Max Platinum
    With all the controls on these engines these days, you may only see a difference if your current filter is real dirty, dyno testing results would be nice . Maybe, but probably not.
  3. Dec 22, 2022 at 3:35 PM
    mass-hole
    mass-hole New Member
    Filters wont make a difference in mpg. Your stock filters are not taxed just cruising around. Additionally, most intakes that claim to improve MPG's are doing it by tricking the PCM into running leaner, but that is done by changing the flow characteristics around the mass air flow sensor, which the filters wont do.
    The AFE intake does this on my Lexus GX. After installing my intake and datalogging it, my Mass air flow readings were actually about 10% lower. I emailed AFe about it and they said this was intentional.
    "the ECU has a failsafe built in so t you will not lean the engine out too far that it will hurt it. the engines from the factory run a little too "fat", rich when they leave the factory, We just add additional air to lean it out and make it run more fuel efficient and you get a little extra horsepower to boot....."
    TundraWorkHorse and TX210Tundra like this.
  4. Dec 23, 2022 at 6:39 AM
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    I think the turbos are marginally louder but that could also be wishful thinking.
