TRD Oil Filter Ques. Plus Skid Plate Removal Woes
Discussion in '2nd Gen Tundras (2007-2013)' started by socaldiablo, Oct 16, 2021.
  1. Oct 16, 2021 at 4:00 PM
    socaldiablo
    socaldiablo [OP] New Member
    Carlsbad, CA
    2013 White Tundra SR5 Rock Warrior
    Leer camper shell, slight lift kit, TRD Pro BBS wheels
    Just finished the first oil change in my new to me 13' Tundra SR5 with the 5.7 L motor. I opted for the slightly better TRD oil filter part PTR4300081. First off, who the hell was in charge of designing the skid plate? It's beefy but it was quite a challenge removing it and getting it back on. The stupid J hooks threw me off ...wasn't sure how to pull it down with those in place. Kinda manhandled it sideways and it finally came free but that was quite a waste of time playing around with that for awhile. Couldn't get it off, came in side and bitched to my wife about it for a bit, then went back out and finally got it off.
    So upon removing the oil filter canister small cover, I realized I was going to need the canister removal tool, which I did not have. Thought maybe my strap type removal tool would work but there's not enough clearance to use that. So I ran to the parts store and got a Pennzoil version of that tool. Removed the canister and that was fine but when I popped off the existing filter (not a TRD one) and then slid the new TRD filter onto the downtube, it fit rather loosely, which is different than how the existing one fit. I tried to press it down to see if it would catch or fit into place but it wouldn't. For those of you that use the TRD filter, is it correct to just place the filter over the downtube, fill the assembly with some new oil, replace the 2 O-rings and lube them, and then screw the entire assembly back up into where it screws into? Why didn't Toyota just use the traditional type oil filter that all other cars use? It would be way easier with that type.
  2. Oct 16, 2021 at 4:10 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    NewImprovedRon and SouthWestGA like this.
  3. Oct 16, 2021 at 4:43 PM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    RitcheyRch and omgboost like this.
  4. Oct 16, 2021 at 4:53 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Eh, the skid plate gets easier each time you do it. Helps with seeing if there are any other issues at each oil change. I'm at a 10K OCI. I also drain half the coolant every 30k miles so it doesn't bother me much to take it off every 10k miles.
  5. Oct 16, 2021 at 4:55 PM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    Interesting is not the word I would use. But what do I know
  6. Oct 17, 2021 at 4:38 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    It was just "ONE" example, of some very creative ways that some tundra owners have dealt with filter access.
    (a quick Google search will you a number of very creative and cost effective solutions)
    Next time I change my oil, I'll post a pic of my "mod" - a 6"x6", hinged panel, made from the piece I removed, access the filter in 30 seconds.
    WILLINH, BTBAKER and NewImprovedRon like this.
  7. Oct 17, 2021 at 5:49 AM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    I'm wondering why toyota engineers thought it would be a good Idea to aim the oil pan drain plug towards the right tire on the 5.7?
    Messy people like me end up with oil on the tire.
    WVI and AZBoatHauler like this.
  8. Oct 17, 2021 at 7:10 AM
    AZBoatHauler
    So.Arizona
    This drove me nuts. Loved dumping the first few quarts of oil off the tire sidewall. :mad:
    Installed a fumoto valve and stopped the twitching during an oil change.
    WVI, boostedtrdpro, BTBAKER and 2 others like this.
  9. Oct 17, 2021 at 7:21 AM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    I was also a bit thrown by the filter being floppy when you put it on. I went with the Amsoil one that seems awfully close to the TRD version. I looked at some YouTube videos and could see it flopping around when the person when to screw it on and took it as normal. I was hoping for a satisfying seating of the cartridge like on other vehicles I've changed. I'm sure it's nothing and when it's tightened down to spec it's wedged at the top and bottom. I like the rubber seal top and bottom the TRD and Amsoil filter cartridges have over the standard OEM too.
    15whtrd likes this.
  10. Oct 17, 2021 at 7:24 AM
    15whtrd
    15whtrd Mr. Blonde
    After I did my first oil change (and realized how messy those first few quarts were) before I bought (or even heard of) a fumoto valve, I cut the bottom off of a milk jug at an angle to use as a funnel into the pan. It actually worked really well.
  11. Oct 17, 2021 at 7:59 AM
    sportbikenut
    sportbikenut New Member
    Chuck
    Pittsburgh Region, PA
    2021 Tundra Limited DC MGM 4x4 (New Oct 2021)
    Traded in 2016 Tundra Limited DC Silver 4x4
    The suspense.....come on man, crawl under there and snap a pic! I'm curious what you used for hinges and locking tab. A great idea!
    WVI likes this.
  12. Oct 17, 2021 at 8:37 AM
    socaldiablo
    Carlsbad, CA
    OK, so it's not just me. Thanks for the link to the RCI plate. I might add this to my list (quickly becoming lengthy) of upgrades I want to do. I bitch about quite a bit of stuff I work on to my wife and I think she's just pretty much done listening.
    Yes, I realized after most of the oil had drained that some had splashed onto the right front tire and wheel. I bet the same Toyota engineer who designed the skid plate attachment also designed the oil pan drain plug to angle towards the tire. At least this one is not as bad as the one I had on a previous Cadillac Escalade. That one faced completely sideways and so you had to be real careful about where you placed the catch pan and you had to stay underneath and watch it drain so you could slide the pan over as the oil flow would change.
    OK, great. I couldn't find any videos of someone changing the filter and using the PTR4300081. I did look up into the filter placement void and saw a shortish tube that drops down about 1.5-2 inches and so when you insert the cartridge assembly that filter fits right into that and you're right in that it has the rubber seals on both ends so all should be good but thanks for your feedback on this.
  13. Oct 17, 2021 at 8:50 AM
    SouthWestGA
    SouthWestGA New Member
    Oklahoman likes this.
  14. Oct 17, 2021 at 9:02 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    It worked for me.
    The OEM skid is shit anyway. It’s a no brained to me to upgrade.
    TFT[QUOTED] likes this.
  15. Oct 17, 2021 at 1:04 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I cut out the a square and put a removable door on the plate to get to the filter, 4 stainless steel bolts keep it in place. Do a search on it and you will see what other guys have done to the plate.
  16. Oct 17, 2021 at 1:17 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    A5234779-A0FD-44A4-A0C2-92C0E4E7807C.jpg C02CB6A1-3D1E-4E1E-A7C9-91D3E34E8429.jpg
    Here are a couple of pics
  17. Oct 17, 2021 at 2:10 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This ^^^. When either or both ramps fail it will be a failure that structural engineers call: explosive buckling.
  18. Oct 17, 2021 at 3:23 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Yep you ain't the only one, he doesn't even have the rear wheels chocked. and I would bet that the emergency brake isn't even set. Asking for trouble.
  19. Oct 17, 2021 at 4:49 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    o_O Oil on the tire? Never had that happen, as for fit it seems some sit better than others , I uses Wix XP filters (comes with the new seals and drain tool) and a new crush washer picked from from the dealership (I bought bulk since they're so cheap and to have on hand) but with the Wix I haven't had a fitment issue. ;)
  20. Oct 18, 2021 at 7:29 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    What motor are you running?
    On the 5.7, some kind of shield has been necessary to prevent the oil from "roostertailing" out of my blow molded catch can/container and onto the passenger, front tire.
    Glad I happened to be wearing gloves for the first oil change, as I was unprepared, and just had to use my hand as a shield while the oil drained.
    Last change I was at the end of the shop rags and was able to use the empty tube to funnel the oil into the container without mess.
    Dont really want to do a fumoto for the oil pan because Id probably just tear it off on a trail somewhere and become sad... Tho I do have one for draining the filter housing, which I appreciate having.
  21. Oct 18, 2021 at 9:39 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I dumped my skid plate a long time ago... its a continuous trip hazard and snitch at night in my garage, where I hide things...
    GODZILLA and WVI like this.
  22. Oct 18, 2021 at 12:26 PM
    NueveTundra
    Planet Earth
  23. Oct 18, 2021 at 1:22 PM
    COTundie
    Trey
    Pretty things
    You must have a very deep/high walled catch container.
    I've changed a lot of oil on a lot of different vehicles. I've never seen another motor spew oil at quite the angle or rate of the Toyota 5.7
    socaldiablo[OP] likes this.
  24. Oct 22, 2021 at 6:49 PM
    Beastmode1
    Beastmode1 New Member
    Pete
    Great ideas all around!!!!
