Trd light bar switch wiring
Discussion in '3rd Gen Builds (2022+)' started by Hadsen15, Dec 16, 2022.
  1. Dec 16, 2022 at 7:58 AM
    Hadsen15
    Hadsen15 [OP] New Member
    Trey
    22 tundra magnetic grey
    Can someone tell me which color wires from the aftermarket trd light bar switch connect to the diode dynamics switch for the stage series light bar thanks
    ryanwgregg likes this.
  2. Jan 1, 2023 at 3:28 AM
    LeoYota
    LeoYota New Member
    leonel
    2022 Tundra Limited
    Where you able to make it work? I have same issues here I bought the rough country slim line and the trd switch and don't know how to change it Trd Switch has 5 wires in while the RC has 3
  3. Jan 1, 2023 at 7:29 AM
    On the round switch, I believe the white is hot, blue is load to trigger the lights on, and the black is ground. What company makes the other switch? One wire will be the backlight illumination, another will be for the small light when the lights are on, and of course power, ground, and load. The colors being different than other switches is why we need to know who makes that switch.
  4. Jan 3, 2023 at 7:52 AM
    Hadsen15
    Trey
    Yes if I remember correctly the red/yellow of trd switch connect to blue of dynamic switch….then black to black….trd green to diode white…I had to leave trd white disconnected so the light wouldn’t remain on constantly…I hope that helps!
    iiawah808 and ryanwgregg like this.
  5. Jan 3, 2023 at 7:53 AM
    Hadsen15
    Trey
    Trd switch diagram
    AZxp and ryanwgregg like this.
  6. Jan 4, 2023 at 9:45 AM
    AZxp
    AZxp New Member
    '23 SR5
    Thank you. I may order the rave knockoff now for my DD grille light bar
  7. Jan 4, 2023 at 5:15 PM
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    This is Money. Same way I did mine.
