TRD front sway bar installation
Discussion in '2nd Gen Tundras (2007-2013)' started by Oz_zy, Dec 10, 2022.
  1. Dec 10, 2022 at 3:39 PM
    Oz_zy
    Oz_zy [OP] New Member
    2016 magnetic grey tundra tss off-road
    Morimoto headlights Morimoto xb led fog light Db custom tundra grill with led Spyder smoked led taillight
    I am about to install the trd front sway bar on my 2016 tundra. From my understanding the trd sway bar is beefier compared to the hollow bar. Can I still use my existing hardware or do I need to get new hardware to fit the trd sway bar
  2. Dec 11, 2022 at 7:33 AM
    MartinBlank
    MartinBlank New Member
    Bruce
    Loveland CO
    2008 Crew Cab Limited
    TRD Sway Bars, TRD CAI, Bilstein 5100's, LED's, plus LED rear Plate backup light, Aluminum oil filter housing, ECGS Needle Bearing upgrade.
    You should be fine. I don't think it's beefier necessarily but it is not hollow like the OEM sway bar the TRD is solid. I used all the old bushings and same bolts, but I have a 2008 so your mileage may vary. It's a really simple install and if you find that you don't have the correct parts, then you can just put the old one back in until you get the right hardware. Honestly, I think you will be fine.
  3. Dec 11, 2022 at 7:35 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I'm not sure it's completely solid. I think the walls are thicker though. In any case, you are good to go reusing stock hardware.
    Oz_zy[OP] likes this.
  4. Dec 11, 2022 at 7:56 AM
    MartinBlank
    Bruce
    Loveland CO
    Ah, well I could definitely be mistaken on that. Didn't mean to put out wrong info. Either way, it's a definite improvement!!
  5. Dec 11, 2022 at 8:10 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra Cement DC
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    I’d make sure you’re on a flat surface with your wheels straight as the bar/connectors can bind and make install hard. But original bolts etc. should be all good to go and sub 30 min install. I personally just started removing all tundra front sway bars as they impede articulation offroad/potholes/etc.
    Oz_zy[OP] and CaptRussia253 like this.
  6. Dec 11, 2022 at 8:36 AM
    Ericsopa
    Ericsopa Old man and the sea
    Sure weighs a lot more....
  7. Dec 11, 2022 at 1:59 PM
    MadMaxCanon
    True but if it was solid it would be like 300% stiffer, I think the trd one is something like 40%?
  8. Dec 16, 2022 at 6:03 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
