Travel trailer Recommendations
Discussion in 'Towing & Hauling' started by TomyTun, Mar 17, 2019.
  1. Mar 17, 2019 at 9:44 AM
    TomyTun
    TomyTun [OP] New Member
    CA
    2016 TRD Off Road, Crewmax, 5.7L Non-FFV
    None
    My family and I don’t mean immediate are starting to look for travel trailers. My dad, sister and I all have Tundras in different models from 2014-2017. For those that were in the same place at one point of fighting the Tundra’s payload capacity, where would you recommend we start for a light-weight trailer? We have up to 40’ ft of side yard storage but guessing we won’t ever be able to take advantage of that kind of length due to our payload numbers. Here’s our trucks below:
    2014, double cab, limited, TRD.
    2016, crewmax, SR5 upgrade, TRD
    2017, crewmax, SR5 upgrade, 2wd 4.6
    Thanks!
  2. Mar 17, 2019 at 11:17 AM
    TomyTun
    CA
    None
    Maybe a better question. Say a dry height weight is 290 lbs. If you take your ice chest, gear bags etc, and put them in the trailer rather than truck, does it have less effect on the payload number? For example, if you had 300 lbs of gear and put it in the trailer rather than bed I’d truck, would it only increase the dry hitch weight of the trailer by say 100 lbs or less?
  3. Mar 17, 2019 at 11:48 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Correct. Adding the gear to the trailer will only put a portion of the weight on the tongue. Depending on where it is loaded in trailer.
    If you had a toy hauler for example and drove a utv into it, you could in theory lower the tongue weight if the entire utv was behind the trailers axles
    Or if you put an extra propane tank on the tongue directly, 99% of the weight is on the hitch
    trayday likes this.
  4. Mar 17, 2019 at 12:28 PM
    TomyTun
    CA
    None
    Ok, so help me walk through this. I checked my sticker on the door and my payload is 1240. I have a 175 camper shell, say 250 lbs for me, 140 lbs for the wife, 30 lbs for the kid and car seat plus an 80 lbs lab. That leaves me roughly 700 lbs to play with. If we go with this particular trailer and the dry hitch weight of 290. I only have 390 left? This isn’t including ice chest, gear bags etc. I’ve never towed anything of this size before, only a small ATV trailer with my quad. I’m kinda in the camp or not nearing my max payload but willing to admit I’m ignorant when it comes to towing travel trailers. Any thoughts or input for a rookie?
  5. Mar 17, 2019 at 12:51 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I think your logic and thinking are correct.
    I have never looked up for the tundra, but when i had my chevy the specs for payload included 250lb assumption for a driver. So if toyota does the same thing, then you have more to spare than you’re calculating.
    Our trucks are huge, but they are also very heavy. So 1200 seems like a small payload, but we alreay weigh almost 6k
    TomyTun[OP] likes this.
  6. Mar 17, 2019 at 12:59 PM
    TomyTun
    CA
    None
    Hmmmm never thought of Toyota including a driver in their payload number, that would be comforting to me knowing this but I’ll check in manual before assuming. I just want to be safe towing for my only family’s sake and everyone else out of the roads around me.
  7. Mar 17, 2019 at 1:10 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Even with e rated tires, i think many many people with half ton trucks are towing way too big of a trailer. Just my opinion but you never want to be pulling too much weight and heaven forbid crash into someone. Attorney will eat you up
  8. Mar 17, 2019 at 3:14 PM
    TomyTun
    CA
    None
    I understand what you’re saying. Hmmm hmmm hmmmm hmmm.
  9. Mar 17, 2019 at 7:46 PM
    Therin7
    Therin7 New Member
    West Tennessee
    2014 Tundra Platinum
    Average 1st time buyer of a camper sells or trades it within 18 months. Really think it through as to what you need and dont need in a camper. With a 1/2ton, I wouldnt want anything bigger than a 27ft ultra light.
    I love my 2018 Jayco 23rls, 4998lbs dry (24ft Camper Box)....but I admit, a couple more feet/storage might* be worth another 400lbs weight if it was more than just me and a dog. This model is actually 27'3" tip to tail, easy to maneuver, and pulled like a dream behind my 16 GMC, havent given it a pull with the Tundra yet.
  10. Mar 17, 2019 at 7:53 PM
    TomyTun
    CA
    None
    We’re looking at a 16’ dual axle Camplite. Dry weight is 3160 lbs.
    ARES35 likes this.
  11. Mar 17, 2019 at 8:01 PM
    Therin7
    Therin7 New Member
    West Tennessee
    You will be fine, buy a Weight Distribution Hitch with Sway Control and load up!
  12. Mar 17, 2019 at 8:11 PM
    TomyTun
    CA
    None
    Yes, plan to. So with a WDH, is it possible to maintain that dry hitch weight while loading all our crap in the trailer, or potentially even reducing it?
  13. Mar 17, 2019 at 8:29 PM
    Therin7
    Therin7 New Member
    West Tennessee
    I'd hate to piss off a Trailering Guru or Engineering Grad, but I dont think it works exactly like that. Tongue weight is more determined by load distribution. BTW, what are you planning on loading? UltraLite trailer have ultralight load ratings themselves. Im limited to 1600lbs additional in my trailer, and you can reach than number faster than you think.
  14. Mar 17, 2019 at 8:37 PM
    TomyTun
    CA
    None
    Nothing too crazy. Ice chest, sleeping stuff, utincles, beer, ya lots of beer. Fishing gear probably too. Propane tanks, batteries on the trailer. Camping chairs, tables
  15. Mar 17, 2019 at 8:40 PM
    Therin7
    Therin7 New Member
    West Tennessee
    There are fantastic videos on youtube regarding WD systems, I recommend Haylett RVs channel, he has a great section on hitches, loading, maintenance, tips, tricks, etc.
  16. Mar 17, 2019 at 8:41 PM
    TomyTun
    CA
    None
    Ok, thanks.
