Transmission removal?
Discussion in '2nd Gen Tundras (2007-2013)' started by Gonzo23, Jun 10, 2023.
  1. Jun 10, 2023 at 4:22 PM
    Gonzo23
    Gonzo23 [OP] New Member
    2011 tundra
    I have the 5.7 engine with 4 wheel drive…. Getting ready to swap engines… my question is, is it necessary to remove the transmission to swap out the engines?
  2. Jun 16, 2023 at 8:38 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    It's not necessary to remove the transmission.
  3. Jun 16, 2023 at 8:47 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    How did you blow it up?
  4. Jun 16, 2023 at 10:52 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Not necessary to remove. I removed my front wheels to have more clearance as hoist was too low. Watch out for the windshield! Pretty easy to get all tyranny bolts with an array of extensions. Good luck!
    blackdemon_tt likes this.
