Transmission leak
Discussion in '2nd Gen Tundras (2007-2013)' started by Jscrocca, Oct 17, 2021.
  1. Oct 17, 2021 at 8:29 PM
    Jscrocca
    Jscrocca [OP] New Member
    2007 4wd tundra
    6 inch lift. Dual exhaust. Air intake. Tuned.
    Noticed fluid seeping/leaking from the spot in the photos. What is this small insert called in bottom of transmission?
  2. Oct 17, 2021 at 9:35 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    That’s just grommet, it’s for mechanic to see which side is leaking…rear main seal or transmission seal
