Transmission down shifting
Discussion in '2.5 Gen Tundras (2014-2021)' started by kcaustin66, Jun 26, 2019.
  1. Jun 26, 2019 at 11:09 PM
    kcaustin66
    kcaustin66 [OP] New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    We are driving into Eureka Springs area really curvy hilly roads (in the ozark mountains) not going that fast between 35-50 mph and you can feel the transmission down shifting. Ok I guess just feels funny
  2. Jun 26, 2019 at 11:31 PM
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
  3. Jun 27, 2019 at 12:43 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I you're in touch enough to notice such things, then give your Sequential Shifter a try. That way, your transmission doesn't have to shift needlessly up and down just creating heat with an unlocked Torque Converter.
  4. Jun 27, 2019 at 3:51 AM
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    When I’m driving in the mountains I use the S mode and select either 5 or 4. Keeps the truck out of overdrive and from hunting for gears.
    15whtrd and CMB like this.
  5. Jun 27, 2019 at 3:57 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Normal for a gen 3 Tundra.
  6. Jun 27, 2019 at 5:26 AM
    00Tyler10
    00Tyler10 WETT Expeditions
    Tyler
    Bowling Green, Ky
    2020 MGM Tundra Plat 4x4
    PTM Mirror Caps Spray in Bed Liner Window Tint XD Buck 20x9 Wheels 275/65/20 BFG K02s Bamf 10" exhaust
    This
  7. Jun 27, 2019 at 7:32 AM
    15whtrd
    15whtrd Mr. Blonde
    It will do it even more if you hit the tow haul button while in D. It’s actually kind of cool when you’re going downhill, tap the brakes and it will downshift and hold that gear until you touch the throttle. I still use sequential mode most often, especially in the hills.
  8. Jun 28, 2019 at 9:30 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    I know, sometimes transmission clunks the drivetrain while it hunts for whatever gear it wants to be in. Just wonder if that’s going to strain the universal joints and differential and cause them to fail in the future.
  9. Jun 28, 2019 at 9:54 AM
    CMB
    CMB New Member
    Cecil County MD.
    "IT" doesn't have to hunt whatever gear it wants to be in, if you choose the gear that's best, by using S Mode.:thumbsup: The added heat and wear on the Torque Converter, can be greatly reduced with just a tiny bit of effort.
    Ajkkane[QUOTED] likes this.
