Transmission cooler missing…I know I know
Discussion in '2.5 Gen Tundras (2014-2021)' started by ColoradoCub, Sep 27, 2021.
  1. Jan 3, 2022 at 12:25 PM
    #1261
    Terndrerrr
    Terndrerrr guzzling dealer repellent
    Music City
    Dual 5.7s
    TRD Fox, RAS, 285/75 DTs, dual battery, SS3 Pro
    Yeti blocks less of the radiator, but their mounting bracket is more expensive.
    Don’t forget to spray it black with radiator paint. It would be pretty silly to see the word YETI or RTIC through your truck’s grille.
    How many gallons of trans fluid do you have to add for the RTIC?
  2. Jan 3, 2022 at 12:30 PM
    #1262
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    23.3/17ths liters
    Plus two off brand ice packs
    3 tbsp of epsom salt
    2tps vanilla extract
  3. Jan 3, 2022 at 12:32 PM
    #1263
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    We're a Coleman family.
    Hightide and 68rs75z28[QUOTED] like this.
  4. Jan 3, 2022 at 1:14 PM
    #1264
    timsp8
    NY
  5. Jan 3, 2022 at 1:26 PM
    #1265
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    It all makes cents now.
    New years day there was a "boom" in my area. The NWS definitively ruled out thunder and there was no supersonic air traffic. A satellite that watches for lightning saw a flash over Washington county but it wasnt lightning.
    I can now say for certain that the boom was the OP's transmission.
    LS3, Cpl_Punishment and Hightide like this.
  6. Jan 3, 2022 at 2:44 PM
    #1266
    sportbikenut
    sportbikenut New Member
    Chuck
    Pittsburgh Region, PA
    2021 Tundra Limited DC MGM 4x4 (New Oct 2021)
    Traded in 2016 Tundra Limited DC Silver 4x4
    Nope! Jewish space lasers hitting large meteor, causing shower of particles covering the Pittsburgh region. Might have also mixed with the rain causing acid rain. Your motorcycles outside? Ha
    hagrid[QUOTED] likes this.
  7. Jul 7, 2022 at 4:22 PM
    #1267
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    So tfl truck just had a 2nd test a new chev. severado 6.2 pulling 9,600. The first test towing trans. over temped at 285 degrees. 2nd test after so called repair was 255 degrees.
    I seen people on this web site say any thing past 220 degree is bad for your transmission. So is chev. overstating there towing rating?
    14burrito likes this.
  8. Jul 7, 2022 at 5:18 PM
    #1268
    sportbikenut
    Chuck
    Yep. My theory has always been that the domestic mfg's overstate towing capacity while super conservative Toyota understates capacity. Those temps above are too high.
    Terndrerrr likes this.
  9. Jul 8, 2022 at 5:53 AM
    #1269
    blanchard7684
    blanchard7684 New Member
    Saw the same video.
    I'm curious to know what the dealer did to get 30 degrees out of it.
    I'm ok with 255 as long as there is a system to control it there.
  10. Jul 8, 2022 at 6:18 AM
    #1270
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    GM has a lower temp trans thermostat available on the 6L80, unsure about the 8 speed though...which I think is what is paired to that 6.2l. Possibly same part?
    It could be that the same, or close to the same,amount of heat was absorbed into the cooling circuit BUT the upper limited changed simply due to the floor starting lower.
    Original cooling floor was 180, the new tstat changes the floor to 135.
    Quick dig * 6 and 8 speed utilize the same thermostat. So there is your difference IMO.
  11. Jul 8, 2022 at 6:31 AM
    #1271
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Dont worry about trans temps in gm transmissions. Something else will destroy them long before the elastomers fail due to high heat. My buddies is in the shop right now with 50K miles getting a transmission, good thing is he slid right before the power train warranty expired. never towed anything....
  12. Jul 8, 2022 at 6:59 AM
    #1272
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 DC Attitude Black
    A guy at my job has a Escalade. The shop has had it more than him. And I am not joking. They supposedly fix it and a few days later it’s back in for about 4-6 weeks. It’s in right now as a matter of fact.
    Cpl_Punishment likes this.
  13. Jul 8, 2022 at 7:07 AM
    #1273
    blanchard7684
    So a revised thermostat with lower opening temp?
  14. Jul 8, 2022 at 7:22 AM
    #1274
    14burrito
    2014 SR5 CM 4x4 5.7
    Yes
    180 old floor
    135* new floor
    Big difference
    I *think* the full open specs are,
    196 old
    158 new
    Most GM owners bypass the trans thermostat all together (we did). You remove the cap, "flip the pill" and the thermostats been bypassed and fluid flows constantly.
    blanchard7684[QUOTED] likes this.
  15. Jul 8, 2022 at 7:45 AM
    #1275
    blanchard7684
    good info. Thanks.
    14burrito[QUOTED] likes this.
  16. Jul 8, 2022 at 7:55 AM
    #1276
    14burrito
    2014 SR5 CM 4x4 5.7
    If you (or anyone else) want a little more detail on it, the 6L80 TB is "21-NA-199". :cheers:
  17. Jul 8, 2022 at 9:05 AM
    #1277
    Asimov2025
    Asimov2025 Not Sure
    North Texas
    Non-stop mods
  18. Jul 8, 2022 at 1:18 PM
    #1278
    eagleguy
    eagleguy New Member
    Anyone see the latest YouTube video where they test the 21 Tundra towing under adverse conditions to see if it really needs the trans cooler.
  19. Jul 8, 2022 at 2:03 PM
    #1279
    sportbikenut
    Chuck
    Send the link or name to the one you are referencing. Thx.
  20. Jul 8, 2022 at 3:06 PM
    #1280
    eagleguy
    eagleguy New Member
    Just go to You Tube and search for 21 Tundra Trans cooler. I don't have the link at the moment and I am not that tech savy. I think in the end the trans under load reached around 240 which Toyota stated (not me) was in the normal range.
  21. Jul 8, 2022 at 8:24 PM
    #1281
    AGSport
    AGSport New Member
    PA
    21’ AG Sport
  22. Jul 8, 2022 at 8:38 PM
    #1282
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Tundra transmission cooler discussion is like Covid it just never goes away.......
    Retired...finally and EDDO like this.
  23. Jul 8, 2022 at 8:42 PM
    #1283
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    batman900, DZ_, sportbikenut and 2 others like this.
  24. Aug 19, 2022 at 7:48 AM
    #1284
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    Is the Thermal Degradation PID available for the ScanGauge II?
    I looked on the website but couldn’t find it, and tried searching to no avail, TIA.
  25. Aug 19, 2022 at 2:06 PM
    #1285
    Joe333x
    Joe333x Member
    Boston
    I have it on my OBD MX+ but it's not really helpful since I've done multiple drain and fills and I'm guessing it needs to be reset by tech stream, which I have but have never really looked into it. Not exactly sure how it calculates it but have read about people asking the dealer to reset it after a service and they didnt even know how to.
    Spyker[QUOTED] likes this.
