Trans Temps while Towing
Discussion in 'Towing & Hauling' started by fireman_pete, Sep 30, 2022.
  1. Sep 30, 2022 at 8:26 AM
    fireman_pete
    fireman_pete [OP] New Member
    Pete
    2021 SR5 Trail Edition
    I recently got a Scan Gauge III for the sole purpose of monitoring my Trans Temps while I tow.
    My truck is a 2021, CM, SR5, 4x4
    The Scan Gauge shows 2 temps for the Trans. A/T Oil Temp 1 and A/T Oil Temp 2
    Here is what I am seeing, and hope this is normal
    Regular driving around town/freeway (NO TRAILER) after about 20 minutes driving, the Temp 1 is around 210-215, and Temp 2 is 220-225
    Last week, I was towing a trailer (about 6500#) through some short hills, and the Temp 1 got up to 230, and Temp 2 was over 250 in a few cases.
    I notice the Temp 1 does not flucuate too much, the but Temp 2 will go up and down by 20-40 degrees, especially if the RPMs increase under load.
    Long story short, I just want to make sure what I am seeing is normal.
    Thanks!
    ColoradoTJ and BravoDeltaRomeo like this.
  2. Sep 30, 2022 at 8:48 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I just got a OBDlink MX+....so I'll be following this as well.
    Just playing around with mine and deciding what gauges I want displayed and what the max/min should be.
  3. Sep 30, 2022 at 8:56 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Just going uphill will heat the AT temp, our truck don’t have AT cooler, if you tow I think you should get cooler kit.
    Pic is going up the grapevine to LA
    Edit
    Not towing anything, only like 200lbs in bed
  4. Sep 30, 2022 at 8:58 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Are you towing in D? If so, any improvement if you shift to S4?
    BravoDeltaRomeo likes this.
  5. Sep 30, 2022 at 9:01 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Being in either S4 or S5 this locks the converter and helps keep temps down. just an fyi
    Cpl_Punishment likes this.
  6. Sep 30, 2022 at 9:02 AM
    twotrack
    twotrack New Member
    Clint
    Tampa, FL
    2015 Tundra SR5
    in my 2015 normal trans temps are ~195. With a 3500lb TT in S4 i still hover at 195-200, the highest I've seen was on a climb in Colorado and it only rose to about 206. I have a Scangauge II.
  7. Sep 30, 2022 at 9:08 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I don't have mine pinned but just cruising around on a regular day with temps in the 90s my trans gets to 190°
  8. Sep 30, 2022 at 9:09 AM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    Fairly normal from what I see with my 2019, whether it is good or bad is another issue. I tow a couple different trailers, 1.5k and 4.5k. The TC temp, Temp 2, does spike all over. It’s the other one, Temp 1, the pan or actual main tranny that I understand is the one to watch and/or worry about.
    There is a very recent thread here with very well documented temps and an oil analysis at around 30k miles. Temps he got were similar to yours & mine, and oil was analyzed and good. Mine has 50k on its tranny oil and will be sent in for testing before we hit 60k. I am expecting it to be good. If it’s not, I’ll install the tranny cooler.
    The suggestion to try S4 is a good one. If I am not on flat straight road, it keeps my temps down.
  9. Sep 30, 2022 at 9:10 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Pinning def helps from what I've seen.
  10. Sep 30, 2022 at 9:13 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I just don't want it running too cool as I have zero issues shifting gears.
    reywcms[QUOTED] likes this.
  11. Sep 30, 2022 at 9:19 AM
    Pmac
    Pmac New Member
    OP, go to post 18. Ignore the temp info posted by the earlier model guys above, they have a cooler. It’s 19-21 model years, iirc, where they have not added a cooler, you want to pay attention to for comparison purposes. These years have that small puck that functions as a warmer and cooler of sorts and give the higher temps.
    https://www.tundras.com/threads/green-thunder-oil-analysis-thread.94464/
  12. Sep 30, 2022 at 9:35 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I think 1 is AT pan temp and other should be torque converter, TC will move quick and pan temp is slower to temp change
  13. Sep 30, 2022 at 10:19 AM
    fireman_pete
    Pete
    Thanks! I just read the thread, and appreciate the details!
    Pmac[QUOTED] likes this.
  14. Sep 30, 2022 at 11:03 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I am assuming you don't have @Genuine Cooling Systems kit installed. Without it those numbers are consistent without the cooler kit.
  15. Sep 30, 2022 at 11:04 AM
    fireman_pete
    Pete
    Nope, no trans cooler, stock vehicle.
  16. Sep 30, 2022 at 11:07 AM
    Saltyhero13
    Looks about right. In the interiem you can change out the fluid at more frequent intervals if you don't want to add a trans cooler system. I do recommend the kit he offers, it is mostly OEM parts and does a great job keeping temps down around ~200 or there abouts.
  17. Sep 30, 2022 at 11:09 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    it's normal since you don't have the trans cooler.
    I was doing 230 on my daily drive in Houston.
    now, after cooler, I hardly ever reach 195
    Saltyhero13 and ColoradoTJ like this.
  18. Sep 30, 2022 at 2:33 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    Looks normal to me and similar to what I got before the cooler install.
