tranny over full, 2002
Discussion in '1st Gen Tundras (2000-2006)' started by 3bears, Jun 15, 2024.
  1. Jun 15, 2024 at 6:50 PM
    3bears
    3bears [OP] New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    so new to me rig. today doing lots of stuff, I noticed on the dipstick tranny is over full. when I bought, i pulled stick and looked at color, nice and red, but did not pay attention to level.
    so I have noticed that the tundras have a separate cooler. unlike the 3rd gen 4runners I know so well. SO on a 3rd gen 4runner you can just pop off a cooler line and do and easy trans flush. Also the 3rd gens are known for stripping the trans pan drain plug. So since the tranny cooler is just on with constant pressure clamps, can I pull one and pump out a quart. ( eyes on ).. if so is the upper or lower the pressure side...can I add a magnafine filter in line
  2. Jun 15, 2024 at 6:51 PM
    455h0le_dachshund
    455h0le_dachshund Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    Did you check it with engine on and trans in neutral? Chocked or with parking brake on, if you don't have a second person to hold the brakes.
  3. Jun 15, 2024 at 7:09 PM
    Grab the FSM and make sure you’re checking the level correctly. Needs to be warmed to around 110-115° or so and you need to run the transmission through all the gears a couple of times. Then put it in neutral (or park, I always check in park) and it should read accurately. If it’s still too full, then drain some out. Or, do a drain and fill and set the level where you want it.
    shifty` likes this.
  4. Jun 15, 2024 at 7:25 PM
    Mr Badwrench
    Mr Badwrench New Member
    ^ this. A quart high on the tranny disptick would probably be about 1" high (that's what she said/no pun intended etc...). It only takes a pint, or just a little more, to raise the level in between the marks on the first gen dip stick, may not be as high as you think.
  5. Jun 16, 2024 at 4:50 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Here’s a pic of mine when I was doing a flush. It shows which line to use. Note that when you first disconnect it, you’ll get some ATF that will run out. Less than half a cup if I remember correctly.
    FrenchToasty and Jack McCarthy like this.
  6. Jun 16, 2024 at 6:20 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    The 5 gallon bucket method is better than the 1 gal container in a drain pan. Haha
  7. Jun 16, 2024 at 9:02 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Actually the gallon container allows him to more accurately judge how much to replace provided he has several of them to rotate under the hose.
    tvpierce likes this.
  8. Jun 16, 2024 at 9:02 AM
    3bears
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    thanks all. yes tranny was hot after a drive to the dump. I checked it in park as my parking brake does not work,
  9. Jun 16, 2024 at 1:30 PM
    shifty` In South Dakota Trouble ain't hard to find
    That's unfortunate, a properly functioning parking brake is crucial to proper, firm braking in these trucks. Get that fixed ASAP.
    ATBAV8 likes this.
  10. Jun 16, 2024 at 7:06 PM
    3bears
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    thanks I dont know where to start on it...the parking brake. Im not used to a pedal parking brake. This is not my daily driver and I dont keep it at home right now, its at work locked up till I get all the bugs fixed
    and being new to this forum, i have trouble with the search system, its not as good as the 4runner forum search
  11. Jun 16, 2024 at 7:18 PM
    Jack McCarthy
    Bill
    North of Boston
    Take the wheel and brake drum off and make sure the star adjuster (hole for adjustment is under rubber plug in 12 o’clock position on the backside of the backing plate) is working correctly. Place drum back on and turn while adjuster is still loose. Tighten adjuster until brakes just slightly drag against drum, place wheel back on as proceed with other wheel.
    Also, make sure the e-brake line is working and taught. If slack exists, you may have to take the bell cranks apart and grease the pins (if they’re frozen; test by pressing on the e-brake and release). If not frozen, grease the pivot pin on the axle to make sure it isn’t holding the cable from getting taught.
  12. Jun 16, 2024 at 7:40 PM
    Start here, this will link to most of what you need to know: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
  13. Jun 17, 2024 at 2:22 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Try searching with google instead...
    "parking brake adjustment site:tundras.com" yields these results
    https://www.google.com/search?client=firefox-b-1-d&q=parking+brake+adjustment+site:tundras.com
    KNABORES likes this.
  14. Jun 18, 2024 at 3:38 AM
    tvpierce
    Maine
    ^^^ This.
    Also, note the black lines... those are one quart increments. I generally pump 2 quarts out at a time.
  15. Jun 18, 2024 at 8:47 AM
    3bears
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
