Trailer wiring
Discussion in 'General Tundra Discussion' started by Model A gischia, Mar 26, 2021.
  1. Mar 26, 2021 at 5:05 PM
    Model A gischia
    Model A gischia [OP] New Member
    I changed the 7 pin connector on my trailer and Tundra. Brake and signals work (LED) no tail or running lights. the 30A tow fuse is good and I had the Tow relay checked and that also is good.
    Plugged it into a buddy's truck and everything works.
    Ideas/suggestions?
  2. Mar 26, 2021 at 5:19 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    What year is your Tundra?
    I suspect you have no power on “pin 3” of your truck connector, but using a test light to check that pin and all others for power with only the park / tail lights turned on would be my first step.
