Trailer Not Recognized
Discussion in 'Towing & Hauling' started by M&MTundra2018, May 11, 2020.
  1. May 11, 2020 at 9:58 AM
    M&MTundra2018
    M&MTundra2018 [OP] New Member
    2018 Tundra Limited
    Appreciate anyone who can offer assistance with this problem.
    2018 Boat trailer is not recognized by the Toyota integrated brake controller. Trailer lights all work 4.0, but I cannot adjust the trailer brakes at all because Tundra display shows "no trailer connected." Multiple other trucks have no issue with the boat trailer, so it seems like the problem is with my 2018 Tundra Limited.
    Local dealership looked at vehicle but couldn't find any issues. Second dealership said it might be a blown fuse but couldn't tell me which one...Does this sound like a TSB 0036-19 issue?
    Shouldn't be this hard! Thanks for any feedback.
  2. May 11, 2020 at 10:08 AM
    Welcome from NY.
    I remember someone posting the same issue about 1 year ago. Try the search bar. Good luck with correcting the issue.
    M&MTundra2018[OP] likes this.
  3. May 11, 2020 at 10:10 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I had my dealer update the firmware. Fixed.
  4. May 13, 2020 at 5:06 AM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    Check your trailer ground. I have had issues since my trailer grounds through the ball hitch. Also, shutting truck off, plug trailer in then start up may help.
  5. May 13, 2020 at 5:12 AM
    M&MTundra2018
    2018 Tundra Limited
    Thanks @stuckinohio I'll try both - truck at second dealership now for hopefully the reflash fix of the firmware - not optimistic.
  6. May 13, 2020 at 5:52 AM
    stuckinohio
    Mark
    oHIo
    2018 SR5 Crewmax
    No problem hope you get it straightened out. Since my trailer grounds through the ball it doesn't provide a consistent ground and makes the Toyota IBC go crazy. I plan to rewire my trailer harness eventually but have been running a jumper wire to help ground to the truck frame better. It's not the ideal solution but allows me to be legal and not get rear ended.
    Is your boat trailer a 7pin or a 4 pin?
    Does the trailer have brakes?
  7. May 13, 2020 at 5:55 AM
    M&MTundra2018
    2018 Tundra Limited
    Trailer has trailer brakes and is a 7 pin. New trailer (2018) so it might be the LED/resistance issue I've seen on this thread earlier.
    But, the trailer ground is always a good place to start t/s. Will let you know how I make out - appreciate the help.
    NewImprovedRon likes this.
  8. May 13, 2020 at 11:30 AM
    M&MTundra2018
    2018 Tundra Limited
    Dealer performed the ECU re-flash with the TSB 0036-19 - no joy - still not recognized.
    Trying the 7 way adaptor next and if that fails the Prodigy RF.
  9. Jun 29, 2021 at 7:57 AM
    Benjammann
    Benjammann New Member
    Did you find the problem? I'm having the same issue trying to rewire a trailer and the truck says "no trailer"
  10. Jun 29, 2021 at 10:17 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
  11. Mar 24, 2022 at 11:46 AM
    Ry24000
    Ry24000 New Member
    Ryan
    Carson, WA
    2019 Tundra SR5 TRD offroad Quicksand
    Debadge, ARE z series top, Ironman Foam cell pro 3" lift, SPC UCA's, ICON vector 5 & Toyo ATIII 285 75R 17, Warn 9.5XP mounted in a Victory Blitz bumper. GTR 1000LM+XTR LP Reverse Light System
    Any updates on this? Mine says no trailer and I can't change the Trailer brake type in the settings menu.
  12. Apr 2, 2022 at 10:50 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    there are issues w/ 2018 models, maybe others that require the dealer to flash/update the controller ecu.
    Trailer Disconnected Message When Towing.
    Research Indicates T-Sb-0036-19 Will Solve The Issue.
    Had that performed at the dealer and have been all good since.
  13. Dec 20, 2023 at 6:18 PM
    Ry24000
    Ry24000 New Member
    Ryan
    Carson, WA
    Did you figure anything out or what?
