TPMS vs Airing Down
Discussion in 'Wheels & Tires' started by BlackRiverGuy, Jan 9, 2019.
  1. Jan 9, 2019 at 6:29 AM
    BlackRiverGuy
    BlackRiverGuy [OP] New Member
    Chandler AZ
    2019 Tundra SR5 4x4 Offroad
    In Process ARE color matched Z type cap. Pro Comp 3/1 leveling kit. Nitto Grappler 295 70 R18's
    My question is related to the TPMS system and airing down tires when off -roading. I have a 2019 Tundra, was wondering if any damage or long term effects will cause problems with the TPMS system when off roading for the weekend and running much lower pressures during that time. Airing down is something I have not done yet, but plan on doing for future trips based on all of the positive information available for this topic. Any comments would be greatly appreciated.
  2. Jan 9, 2019 at 7:15 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Won’t hurt a thing.
    15whtrd and Stormtrooper81 like this.
  3. Jan 9, 2019 at 7:20 AM
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    Been airing down for years... No issues. You just have the nannies barking at you until you air back up .
    jberry813 likes this.
  4. Jan 9, 2019 at 7:41 AM
    15whtrd
    15whtrd Mr. Blonde
    It will just be a low pressure light on the dash. You can just reset that with the TPMS button by you’re right knee. And then reset it again once you’ve filled back up to the normal air pressure’s. All it is, is a parameter. If it drops below a certain psi after you set it,the light comes on.
    I’d have to look in my manual, but I’m pretty sure you turn the ignition off, hold that button down and turn the ignition back on while holding it for a certain amount of time. There may be a prompt on the dash, I can’t remember exactly.
    Ike74 likes this.
  5. Jan 9, 2019 at 10:46 AM
    BlackRiverGuy
    Chandler AZ
    Thank you for all of the feedback, I will definitely check on the reset to understand how that works. I didn't think it would be a problem, however there are instances when the wife is driving on some stretches, and I didn't want her freaking once she saw the TPMS light, I can forewarn her and let her know it's nothing to be concerned about.
    15whtrd likes this.
  6. Jan 9, 2019 at 9:53 PM
    jberry813
    Lake Tahoe
    Just me shit posting. But don’t push the button.
    If your TPMS is working great, and you air down, a light is expected. But if you reset or recalibrate the TPMS cause you are off-road, and obviously aired down...why the fuck would you calibrate your TPMS as low pressure as standard?
  7. Jan 9, 2019 at 10:01 PM
    15whtrd
    15whtrd Mr. Blonde
    In case they get even lower.:notsure: Or if you just can’t stand warning lights. I personally never reset it.
    OR18TRD likes this.
  8. Jan 10, 2019 at 5:56 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Resetting the TPMS at the lower pressure to turn the light off - In case you get an actual flat you will get a warning. If the light stays on all the time and you lose more pressure you might lose a tire also. So it does make some sense to do it.
    Sonicbluerider and 15whtrd like this.
