Toytec Shackles
Discussion in 'Suspension' started by runCMD, Sep 17, 2020.
  1. Sep 17, 2020 at 3:03 PM
    runCMD
    runCMD [OP] BAMF Nerd
    2016 Radiant Red CM SR5 TRD OR
    3/2.5 BOSS lift, 35s
    B41507C4-CEF1-4DE6-9BB3-75F886B2F881.jpg I’ve watched the few install videos I could find, including the coach builder, but I’m stuck. With the frame on jack stands and even releasing the jack on the diff all the way down, my leaf springs don’t want to drop away from the frame any where near enough to get the shackle on there. I’m actually not sure I could even get stock back on. Is it because of my block? See attached picture.
  2. Sep 17, 2020 at 3:08 PM
    timsp8
    NY
    Can you jack up the rear on the frame and see if it moves it in to place? Maybe even add some air to your airbag to separate frame and spring.
  3. Sep 17, 2020 at 3:10 PM
    The block will definitely make it difficult. I dont think you can run that large of a block together with shackles. Did you disconnect your shocks from the lower mount as well?
    Black Wolf likes this.
  4. Sep 17, 2020 at 3:13 PM
    runCMD
    David from Toytec said I could, it’s only a 2”. I did not disconnect the shock, perhaps that’s what’s causing my problem. Just tried the airbag trick and it only got me about a cm of space.
  5. Sep 17, 2020 at 3:14 PM
    Whocares
    Whocares Member
    Disconnect the rear shocks and jack up from rear axle or rear diff
  6. Sep 17, 2020 at 3:21 PM
    runCMD
    That’s the ticket. I feel dumb. Wish these things came with instructions :)
  7. Sep 17, 2020 at 3:26 PM
    They are on Toytecs site.
  8. Sep 17, 2020 at 3:37 PM
    runCMD
    Found the ones for Tacoma which are similar but not the same. I don’t think they mention disconnecting the shock. The only video I found on YouTube the guy installed the new bushings on the frame instead of the spring :).
  9. Sep 17, 2020 at 3:37 PM
    runCMD
    Now on to pressing the bushing off the other spring. What a PITA.
  10. Sep 17, 2020 at 3:39 PM
    TemujinNomad
    TemujinNomad New Member
    The coach builder video also explains which components to remove.
  11. Sep 17, 2020 at 3:52 PM
    runCMD
    In his video he had the shocks out but mentioned it was for other suspension work and camera angles. I didn’t make the connection.
  12. Sep 17, 2020 at 4:38 PM
    runCMD
    Anyone happen to have the torque specs for the shackle bolts?
  13. Sep 17, 2020 at 4:42 PM
    Whocares
    Whocares Member
  14. Sep 17, 2020 at 5:47 PM
    runCMD
    cool - thanks for the help. Found the different torque rating for Toytec elsewhere.
