Toytec Lift Question
Discussion in 'Suspension' started by ToyotaTundraMike, Aug 15, 2017.
  1. Aug 15, 2017 at 2:11 PM
    ToyotaTundraMike
    ToyotaTundraMike [OP] Not A New Member
    2015 Tundra
    I really like how the pro's look leveled out at 2" up front. Right now I'm on the middle setting of Bilstein 5100's so I'm at around 1.7" up front. I don't want to have to lift the rear at all or go much higher in the front because I don't ever plan on running much bigger tires (I'm at 275/70/18's right now but may run 285/70/18 in the future if there are more options) and don't want it to look like I skipped leg day.
    Would adding just the Toytec Boss Front Coilovers and having them set at 2" be a good option for simulating the lift on a TRD Pro? I'm thinking it would give me the look I'm going for, while also being a huge upgrade on and offroad compared to the Bilsteins 5100's.
    But if I did this, then I wouldn't be able to stick any toytec shocks in the rear because their shocks say they are only compatible if you have atleast 1" of rear lift.....
    Should I upgrade to Toytec Boss in the front at 2" and leave my bilsteins in the rear?
    Opinions/Advice would be much appreciated.
    @ToyTec Lifts
  2. Aug 15, 2017 at 2:24 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Wouldn't be a bad upgrade.
  3. Aug 15, 2017 at 5:02 PM
    scornwel
    scornwel New Member
    2017 Limited 4x4 CM
    6112/5100 Go Rhino RB20s
    Get some 6112s set at 1.9". I did and I'm perfectly level.
  4. Aug 15, 2017 at 5:03 PM
    scornwel
    scornwel New Member
    2017 Limited 4x4 CM
    And the ride is exceptional.
  5. Aug 15, 2017 at 5:13 PM
    ToyotaTundraMike
    2015 Tundra
    I really want some more red underneath the truck to match the rear (and hopefully front if they sell the TRD Sport one) swaybar.
  6. Aug 15, 2017 at 5:19 PM
    scornwel
    scornwel New Member
    2017 Limited 4x4 CM
    I debated that too, but the 6112s were cheaper.
    Good luck and post up later.
    ToyotaTundraMike[OP] likes this.
