Toytec Lift 4"
Discussion in 'Toytec Lifts' started by SuperSilverTundra, Jul 27, 2016.
  1. Jul 27, 2016 at 8:24 AM
    SuperSilverTundra
    SuperSilverTundra [OP] i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    does anyone have any info on the Toytec 4"inch lift its a 4" inch front lift (spacer kit) and 2"inch rear lift (block kit) Im about to purchase this soon but I wanted to know if I can fit 35s
    I really want the 6" inch lift but if I go with the 6"inch I wont fit in my parking garage so I decided on the 4"
    if anybody has any info or ideas leave your feedback will be much appreciated
    thanks.
  2. Jul 27, 2016 at 8:37 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  3. Jul 27, 2016 at 8:38 AM
    SuperSilverTundra
    Nick
    correct that's the one
  4. Jul 27, 2016 at 8:39 AM
    csuviper
    Broomfield, CO
    You can fit 35s with minor trimming of plastic on the front wheel well with a 3/1 lift. Might have to do the cab mount chop but may be able to get away without.
    I have 34.5" on mine with trimming of plastic and did not do the cab mount chop.
    @Sean266 has a 3rd gen with true 35's on a 3/1 Toytec Boss kit.
    T-Rex266 and 2cID like this.
  5. Jul 27, 2016 at 8:40 AM
    csuviper
    Broomfield, CO
    Are you 4x4?
  6. Jul 27, 2016 at 8:41 AM
    SuperSilverTundra
    Nick
  7. Jul 27, 2016 at 8:47 AM
    csuviper
    Broomfield, CO
    Ok so you will not need the diff drop and you don't have to worry about the cv angles.
    With any lift over 3" you will need new Upper Control Arms. Highly recommended to get to the 4" height. Stock will be maxed out and your alignment may be off. You can go with a ball joint like the SPC light racing ones for a little cheaper or a uniball like the Total Chaos ones.
    The Toytec spacer lift breaks up the lift height between above-coil and in-coil to reduce the amount of pre-loading and give the best ride.
  8. Jul 27, 2016 at 8:48 AM
    csuviper
    Broomfield, CO
  9. Jul 27, 2016 at 8:57 AM
    SuperSilverTundra
    Nick
    do you think its worth it or should I just go with the 3"inch kit ?
  10. Jul 27, 2016 at 9:05 AM
    SuperSilverTundra
    Nick
    I want to avoid the cab mount chop
  11. Jul 27, 2016 at 9:36 AM
    csuviper
    Broomfield, CO
  12. Jul 27, 2016 at 9:44 AM
    SuperSilverTundra
    Nick
    do you have any pics of how your truck looked with that set up
  13. Jul 27, 2016 at 9:46 AM
    csuviper
    Broomfield, CO
  14. Jul 27, 2016 at 10:05 AM
    SuperSilverTundra
    Nick
    ok so another question I think I might go with the 3" but I see you had 17s do you think it will be a problem if I choose to go with 20s or 18s?
  15. Jul 27, 2016 at 10:10 AM
    T-Rex266 Sushi, and Teslas Staff Member
    No. 17" would be fine too, just make sure you have the proper wheel diameter.
  16. Jul 27, 2016 at 10:34 AM
    SuperSilverTundra
    Nick
    what should I pay to have the 3/1 lift installed?
  17. Jul 27, 2016 at 12:03 PM
    csuviper
    Broomfield, CO
    No problem with 17, 18 or 20" wheels. Just depends on the offset. Try to get something in the range of +30 to +18 to fit.
    @Sean266 i believe has 18" with +20 offset and 35s on a 3/1
  18. Jul 27, 2016 at 12:05 PM
    csuviper
    Broomfield, CO
    Up to you. If you are mechanically inclined its not that hard. If you do UCAs then it is very tough to get the bolts out, may want to have someone do it.
    There are instructions on Toytec website.
